PGO T-rex 50 indicator light problem, fusebox?
Vilhelm65
PostPosted: 18:20 - 20 Oct 2013    Post subject: PGO T-rex 50 indicator light problem, fusebox? Reply with quote
Hello!
On my PGO T-rex 50 (2006) none of the indicator lights works.
When I press the indicator button nothing happens.
I think that a fuse might have burn out, but I don't know where the fusebox is. Does someone here know where it is?
The indicators have nerver worked for me, I have just own the scooter for 2 weeks.
I would be very happy if someone can tell me what the problem might be Very Happy
/ Vilhelm
KymcoRatChop
PostPosted: 02:47 - 09 Nov 2013    Post subject: Re: PGO T-rex 50 indicator light problem, fusebox? Reply with quote
Vilhelm65 wrote:
Hello!
/ Vilhelm
I don't know where the fuse box is (I rather doubt it has one)
More likely is that the indicator relay has gone kaput! For the sakeof a couple of quid on ebay for a generic one it's worthjust checking.
To check if it is the switch - use a multimeter on the wires coming out to checkfor continuity between the input and relevant output wires from the switch.
To check you indicator bulbs - just take them out, visually inspect them, use a couple of wires attached to your battery;
negative to the "shell" of the bulb, and positive to the contact piece on the bottom - light up? no worries!
if they're fine - then it's the relay.
Sorry no-one else replied -I'm guessing it's cos you're on a scooter :/
The last post was made 12 years, 82 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.04 Sec - Server Load: 0.97 - MySQL Queries: 14 - Page Size: 32.74 Kb
