YAMAHA YBR 125 FUEL LEAK
djmarcopolo
PostPosted: 17:13 - 14 Oct 2013    Post subject: YAMAHA YBR 125 FUEL LEAK Reply with quote
Hi all, im a compete newbie to biking as I spend my evenings modifying cars and going to car shows all year but the wife has got into bikes from buying a scooter last year and then buying the yamaha a few months ago as she has to travel 50 mile round trip to work each day.
All my mechanical knowledge is self taught by dismantling cars and rebuilding them over a number of years but bikes are a whole new thing to me and never really got involved in them before.
I have done some work already like new chain and sprockets, oil change, fitted new tyres by hand but its just developed a fuel leak for no apparent reason
there is a pipe coming from the base of the float chamber on the carb that just runs down to near the rear wheel with just a metal insert in the pipe with a hole at the end and holes drilled along the length
The fuel is just dripping out of there, I have rebuilt a couple of boat engines with carbs but none of them had a pipe from the base of the float chamber
can anyone shed some light on it, what it does etc and is this going to be a carb rebuild and its just dirt in there or something more serious i like to find out before i dismatle it all lol
Thanks in advance
Quote Me Happy
PostPosted: 17:16 - 14 Oct 2013    Post subject: Reply with quote
It sounds like a stuck float. There could be a bit of dirt in there. Before you strip it down try giving it a decent 'tap' with something like a screwdriver handle to try and free it up.
It's never worked for me but some people have had success that way. Failing that, remove the float bowl and see what's up.
djmarcopolo
PostPosted: 17:22 - 14 Oct 2013    Post subject: Reply with quote
so that tube from the base of the float chamber lets excess fuel run out then if the float doesnt sit perfectly ???
Normally stuck floats let fuel out the front of the carb but does this little extra piece on the float chamber just stop that happening ??
YBR Ric
PostPosted: 21:49 - 14 Oct 2013    Post subject: Reply with quote
What you're unable to see inside the float chamber is that the metal connector where the plastic tube is fitted onto extends vertically up inside the float bowl and the tip of it stops a little way above the normal fuel level.
If the fuel valve fails to shut fully because the float becomes stuck or the fuel valve itself leaks then the additional fuel entering the float bowl is able to exit via this metal tube rather than causing additional problems by entering the inlet tract and or combustion and from there drain down into the sump.
The last post was made 13 years, 34 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.38 - MySQL Queries: 14 - Page Size: 39.45 Kb
