Pitted metal, filler primer?
skatefreak
PostPosted: 19:47 - 13 Oct 2013    Post subject: Pitted metal, filler primer? Reply with quote
Quick question.
The lower portion of the forks on my NSR are somewhat pitted (not the important part mind you) and I am wondering what to do to restore them...
https://www.bikechatforums.com/files/dsc_0581.jpg
I have no idea how they got like this, look like they have been pained in the past as the other fork has some paint peeling off it.
I do have access to sand blasting so can work it back to good metal however the sand blasing will no doubt result in a fairly rough surface as well sooo.
Would a filler primer be good enough not just to fill and smooth over the surface but also hold up to the abuse the front of the forks are subjected to?
If no what other options do I have here?
Any thoughts would be much appreciated.
Best regards
-Jvr
skatefreak
PostPosted: 09:50 - 15 Oct 2013    Post subject: Reply with quote
Bump?
Any thoughts anyone?
Best regards
-Jvr
mudcow007
PostPosted: 10:03 - 15 Oct 2013    Post subject: Reply with quote
is that just not the surface of the ally from the cast?
so its not pitted its just not smooth
i maybe wrong though
get em polished that would smooth em out
skatefreak
PostPosted: 14:07 - 15 Oct 2013    Post subject: Reply with quote
Iain,
you may be onto something there.
I just assumed that they had degraded as the top is smooth (where the red writing is) but its rougher below.
I suspect I may have just derped here.
Will have another look when I get home.
Cheers for the thoughts guys.
-Jvr
The last post was made 13 years, 33 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.28 - MySQL Queries: 14 - Page Size: 45.26 Kb
