Beach buggy project- car thread
pits
PostPosted: 15:45 - 12 Jun 2013    Post subject: Beach buggy project- car thread Reply with quote
If some of you remember last year I restored a Smart car for a friend, been having a clear out this year and decided that it was time to put my beach buggy on the road, bought it around the dawn of time and it has mostly sat in my garage
And this is a rather long post with a lot of copypasta
Anyway
As I bought it
https://i34.photobucket.com/albums/d112/pitslayer/47b3d622b3127cce9b932085bd110000001.jpg
https://i34.photobucket.com/albums/d112/pitslayer/bug1.jpg
https://i34.photobucket.com/albums/d112/pitslayer/bug3.jpg
Now you think it probably looks good in those photos, but the list of bodges on this buggy is so far never ending, so where we sit now after a week of work
https://i34.photobucket.com/albums/d112/pitslayer/IMG_20130409_150023_zpsfc0c33f4.jpg
Theres silver under the tasteful gold under the tasteful black bleugh and yes that is my beam being held on with long M10 bolts with nylock nuts.
https://i34.photobucket.com/albums/d112/pitslayer/IMG_20130409_150030_zps30bf08e7.jpg
Still need to clean the inside out
https://i34.photobucket.com/albums/d112/pitslayer/IMG_20130409_150036_zpsf80c9dce.jpg
Crack in rear which is one of the big problems with the body, sure some of you will see it as no probs but I hate fibreglassing.
https://i34.photobucket.com/albums/d112/pitslayer/IMG_20130409_150101_zps58b47178.jpg
Gearbox mount, paint it silver so it looks like part of the gearbox
https://i34.photobucket.com/albums/d112/pitslayer/IMG_20130409_150134_zpse70f08ad.jpg
Earth strap/straps
https://i34.photobucket.com/albums/d112/pitslayer/IMG_20130409_150143_zpsb0ef6131.jpg
Corroded flexis
https://i34.photobucket.com/albums/d112/pitslayer/IMG_20130409_150150_zpsbbc81e80.jpg
Black Gold and rusty master cylinder, thanks to whomever paint over the seals
https://i34.photobucket.com/albums/d112/pitslayer/IMG_20130409_150209_zps6ec0b0bd.jpg
1641 in the process of being built
https://i34.photobucket.com/albums/d112/pitslayer/IMG_20130409_150215_zpsffa3e76c.jpg
Fuel line, yes I snapped that by hand, so brittle.
https://i34.photobucket.com/albums/d112/pitslayer/IMG_20130409_150123_zpsd474e9f8.jpg
More to come, hoping to get the body off the chassis to get some cleaning up of the beam and get rid of that black and gold caked on mess.
Current parts list
In stock > 4 x 462.400.10 Wheel Cylinder, Bleed Nipple, Dust Cover, Each
In stock > 1 x 611.440.10 Clutch Cable, Wing Nut
In stock > 1 x 042.023.10 Tinware, Fanshroud, Twin Port, Without Heater, Black
In stock > 1 x 042.201.10 Tinware, Head Shrouds, Twin Port, Black, Pair
In stock > 1 x 042.151.10 Tinware, Front Tray, Bellhousing, Twin Port, Black
In stock > 1 x 042.126.10 Tinware, Rear Tray, Twin Carb, Without Heater, Black
In stock > 1 x 042.140.10 Tinware, Breastplate, Under Pulley, Black
In stock > 1 x 042.500.10 Tinware, Doghouse Tin, Black, 2 Piece Set
In stock > 1 x 042.610.10 Tinware, Heat Exchanger Bottom Tin, Black, 3 Piece Set
In stock > 1 x 716.500.10 Generator, Backing Plate, Black
REAR HUB SEAL KIT 2
ANTIROLL BAR FITTING KIT 1
REAR WHEEL CYLINDER 2
BRAKE MASTER CYLINDER 1
BRAKE SHOE SET 1
REAR SHOCK ABSORBER 2
To order,
Front slave cylinders
Front shoes
Front drums
If anyone is wondering why I only ordered one ARB bush kit, I already have one on the shelf.
And that isn't my Pepsi Max, Pepsi Max is disgusting
Colour wise, not sure on VW Sea Green
https://www.vwtype3.anomalous.net/sea%20green%202%20.JPG
Or BMW BRG 312 Elekta
https://img.pistonheads.com.s3-eu-west-1.amazonaws.com/Fullsize/bmw/m5/bmw-m5-267934-1.jpg
Floor pan off
https://i34.photobucket.com/albums/d112/pitslayer/IMG_20130409_190148_zps2c9f9284.jpg
Got to go an locate a master cylinder tomorrow if I can so I can run new brake lines.
Rear brake backing plates mostly built back up, hub seals to be done tomorrow, run some brake lines, get the rattle cans out and get to work painting over any gold that is left.....I was going to sand blast but I need to look at it realistically money is a factor, and I want a new beam so no point spending money on that really.
New rear shocks on, new steering damper on
Gearbox cleaned and painted, unsure on the silver details.
https://i34.photobucket.com/albums/d112/pitslayer/IMG_20130411_172633_zps5d20e35a.jpg
https://i34.photobucket.com/albums/d112/pitslayer/IMG_20130417_180943_zps1a2c638a.jpg
https://i34.photobucket.com/albums/d112/pitslayer/IMG_20130417_180929_zpsc02d9c2d.jpg
Tomorrow I should hopefully have the gearbox etc back in so finish off the brake lines, get the hubs done and the backing plates back on, build the shoes up, body work wise not a lot left to do actually
A lot of these cracks have been filled and covered now, just the big one which is the issue
https://i34.photobucket.com/albums/d112/pitslayer/IMG_20130416_202919_zpsca611b05.jpg
Plucked up the courage to cut my body, cut a hole in the inner side of the tub, then the damage section, fibreglassed from behind,
https://i34.photobucket.com/albums/d112/pitslayer/IMG_20130418_192756_zpsad742cee.jpg
Fibrefilled from the front, sanded back and a light skim of filler afterwards
https://i34.photobucket.com/albums/d112/pitslayer/IMG_20130419_154356_zps649e0e3e.jpg
Some high build as a guide coat to pick up any high points
https://i34.photobucket.com/albums/d112/pitslayer/IMG_20130419_203235_zps898b5a3c.jpg
https://i34.photobucket.com/albums/d112/pitslayer/IMG_20130419_202944_zpsb3d12599.jpg
Will get some more better pictures of the tub when it is lighter, hoping to maybe have the tub primed by the end of the week.
Chassis wise, cleaned it up
https://i34.photobucket.com/albums/d112/pitslayer/IMG_20130420_193039_zps5d777854.jpg
https://i34.photobucket.com/albums/d112/pitslayer/IMG_20130420_193034_zpsf54cf816.jpg
https://i34.photobucket.com/albums/d112/pitslayer/IMG_20130420_193102_zps846bbd72.jpg
Rear end mostly buttoned up now, got to set the final brake line placement and then tighten them up, all new gearbox mounts front and rear, hub seal kits mostly done, slave cylinders on
brakes built up
https://i34.photobucket.com/albums/d112/pitslayer/IMG_20130427_190803_zpsae09cde2.jpg
https://i34.photobucket.com/albums/d112/pitslayer/IMG_20130427_190757_zps5f89d3df.jpg
Engine 90% complete, thwarted by lack of torque wrench to do the flywheel nut up to the correct torque, and another bodge to add to the list
1300 twin hotspot AR coded engine so that puts it 72-75, 12v engine, 12v starter motor....6v fly wheel which has been chewed up by the starter motor.
Anyway
https://i34.photobucket.com/albums/d112/pitslayer/IMG_20130427_142457_zps9e615f73.jpg
Built up
https://i34.photobucket.com/albums/d112/pitslayer/IMG_20130427_193906_zps20e86eb4.jpg
We decided to have a look at the dashboard and fixing it better to the car, so I placed the bonnet on so it was square and looked right, then put the dash frame in (the bonnet has always been wonky and it annoyed me somewhat) well, here is the reason why
https://i34.photobucket.com/albums/d112/pitslayer/IMG_20130427_210030_zps52bdc932.jpg
Where the dash frame actually wants to be, where the holes were drilled
https://i34.photobucket.com/albums/d112/pitslayer/IMG_20130427_210025_zps0203e393.jpg
https://i34.photobucket.com/albums/d112/pitslayer/IMG_20130427_210038_zps6eda2d93.jpg
Now lets move the dash frame to where the holes were drilled
https://i34.photobucket.com/albums/d112/pitslayer/IMG_20130427_210141_zps05d36662.jpg
And onto the floor pan, so the body doesn't sit straight on the floor, and it had silicone all over it to make it fit, well I cut the silicone off today and put the body back on to assess just how bad the floor pan is, so near side floorpan is an inch too short on width and the offside is an inch too wide on width, the body is almost an inch too high at the rear where the floor has been built up to meet the body and half inch too far forward at the front.
Measure twice, cut once......measure once cut twice......don't measure at all
https://i34.photobucket.com/albums/d112/pitslayer/IMG_20130427_202958_zps2f931242.jpg
Now we are at the present date
https://i34.photobucket.com/albums/d112/pitslayer/IMG_20130607_161727_zps09fbb67b.jpg
https://i34.photobucket.com/albums/d112/pitslayer/IMG_20130607_161733_zps98163308.jpg
https://i34.photobucket.com/albums/d112/pitslayer/IMG_20130607_161742_zpse34d6d49.jpg
Now primered
https://i34.photobucket.com/albums/d112/pitslayer/IMG_20130607_175054_zps3a65610e.jpg
https://i34.photobucket.com/albums/d112/pitslayer/IMG_20130607_165947_zps8bd394b3.jpg
https://i34.photobucket.com/albums/d112/pitslayer/IMG_20130610_163524_zps150ecb55.jpg
Almost ready for paint, happy with the repair on the rear corner
https://i34.photobucket.com/albums/d112/pitslayer/IMG_20130607_175034_zps87847a8a.jpg
https://i34.photobucket.com/albums/d112/pitslayer/IMG_20130607_175059_zps21477bff.jpg
https://i34.photobucket.com/albums/d112/pitslayer/IMG_20130607_175045_zps550ad53b.jpg
https://i34.photobucket.com/albums/d112/pitslayer/IMG_20130611_175954_zps3f2bd1e6.jpg
The body is this wonky, there is no filler here
https://i34.photobucket.com/albums/d112/pitslayer/IMG_20130611_180017_zps9d0cd581.jpg
https://i34.photobucket.com/albums/d112/pitslayer/IMG_20130611_180026_zpsda596b96.jpg
https://i34.photobucket.com/albums/d112/pitslayer/IMG_20130611_180034_zps4a7ab449.jpg
https://i34.photobucket.com/albums/d112/pitslayer/IMG_20130611_180010_zpsf7cde291.jpg
Tiny more filler primer in places and hopefully it will be green by the end of the week.
I also appreciate that Beetles are crap, I will make no bones about it, but I quite fancy something without a roof to drive and I already had this in the garage.
andyscooter
PostPosted: 16:57 - 12 Jun 2013    Post subject: Reply with quote
cool project
complete different colour have a look at the red on my pcx think it would suit that car brilliantly
pits
PostPosted: 21:00 - 12 Jun 2013    Post subject: Reply with quote
andyscooter wrote:
cool project
It's getting there now, few more bits to do can't rush ahead and paint it as I need to set the dashboard frame and all up.
Colour wise it will green I have spent a lot of time trying to get rid of the orange on it, so it wont be going any shade of red or orange.
Just waiting for my mate to hurry up and get over to weld the floor pan edges on
Ollie1995 This post is not being displayed because the poster is banned. Unhide this post / all posts.
Chalky.
PostPosted: 21:12 - 12 Jun 2013    Post subject: Reply with quote
You're a fucking ledge. Thumbs Up
pits
PostPosted: 23:21 - 12 Jun 2013    Post subject: Reply with quote
Ollie1995 wrote:
midlife crisis?
Eh? How do you have a midlife crisis when you're 14 you bum spackler? The reason I am doing it is because I can, why can I do something like this, because you can't, you're incapable of doing anything useful
Are you mad that I spent less money than you on a tin of spray paint and got a better finish than your quite frankly embarrassing attempt at restoration, I don't like to toot my own horn to be honest but I restored car last year in about 2 months and it was better than when it left factory......you have covered a bike frame in black paint and porridge in the same amount of time
I understand why you have posted and attempted to have a dig, and be funny but it is lulzy.
Cheers Chalky Mr. Green
oldpink
PostPosted: 00:22 - 13 Jun 2013    Post subject: Reply with quote
always wanted a sand rail kit to build
would love to put a 1L bike engine into one of these
https://img.photobucket.com/albums/v325/wildcatkit52/Piranha/RickSchenkerPiranha9.jpg
but hats off to you thats quite a project and rebuild Thumbs Up
pits
PostPosted: 17:37 - 13 Jun 2013    Post subject: Reply with quote
I don't even think a Ducati V twin will have enough torque to push mine down the road, mate of mine is building sort of a sand rail type thing, well it's a beetle chassis he has just built a roll cage around, putting a 2ltr Type 4 in the arse.
Aff
PostPosted: 17:53 - 13 Jun 2013    Post subject: Reply with quote
Nice one, enjoyed the Smart thread.
Posting for updates. Very Happy
Electric Bike Project
oldpink
PostPosted: 17:57 - 13 Jun 2013    Post subject: Reply with quote
https://www.youtube.com/watch?v=xCpqIdUEWL0 Thumbs Up Thumbs Up
and thats a 600cc engine
pits
PostPosted: 18:02 - 13 Jun 2013    Post subject: Reply with quote
Ollie1995 wrote:
You're 14? News to me... Also I spent the grand total of £0 for that paint lol. Miserable Cunt.
Well if I am 14 I am doing considerably better than you are with both paint and porridge for starters I know that you don't mix the two...ever.
Bless you, one day you may succeed at something.....lol
pits
PostPosted: 18:17 - 13 Jun 2013    Post subject: Reply with quote
Ollie1995 wrote:
Says some faggot who's bought a gay beach cruiser as a midlife crises. Attempts repairs but fails miserably and thinks they can paint when it just looks like an aged orange piece of shit.
Ollie, umadbro u real mad.
So what failed attempts at repairs? I assume you're trying to get a rise out of me but considering the shells is black....and now white I can only assume your eyesight is as good as anything else you do.
As for painting, this is what your bike looks like
https://www.brownfido.com/DogPoop102.jpg
That's dog shit if you didn't guess, I am saying your bike looks like dogshit, and it's bent like you, your bike is bent dogshit.
And here is something I painted a few years back
https://i34.photobucket.com/albums/d112/pitslayer/VFR/Photo0524.jpg
It's ok to be butthurt though Ollie, you're a failure and lets face it if you were any sane persons child you would have been thrown in the bin with the afterbirth Wink
usomad though.
pits
PostPosted: 10:23 - 11 Jul 2013    Post subject: Reply with quote
Not forgotten about this, been waiting for a few bits should get some more frequent updates now as the hard part is over.
Chassis rails needed replacing, the old ones were crap made out of 3-4 bits of box section badly cut and welded together, pretty rubbish way of doing it, so came up with another much neater way
Started off with some 20x50 box and started cutting it out
https://i34.photobucket.com/albums/d112/pitslayer/Buggy%20build/IMG_20130710_143632_zpsf271babd.jpg
https://i34.photobucket.com/albums/d112/pitslayer/Buggy%20build/IMG_20130710_143650_zps9e4ea696.jpg
https://i34.photobucket.com/albums/d112/pitslayer/Buggy%20build/IMG_20130710_144026_zps58550f55.jpg
https://i34.photobucket.com/albums/d112/pitslayer/Buggy%20build/IMG_20130710_143724_zps98365a3d.jpg
https://i34.photobucket.com/albums/d112/pitslayer/Buggy%20build/IMG_20130710_144009_zpse8c43200.jpg
To give you an idea of the curve from one end to the other
https://i34.photobucket.com/albums/d112/pitslayer/Buggy%20build/IMG_20130710_150302_zpscad05655.jpg
Tacking it in
https://i34.photobucket.com/albums/d112/pitslayer/Buggy%20build/IMG_20130710_150243_zps45e8c772.jpg
Better, I can't see daylight through the body and the chassis rails now, and it also shows how badly built the floor is, the rail is where the body needs to sit, the floor pan is where it used to sit on the old rail
https://i34.photobucket.com/albums/d112/pitslayer/Buggy%20build/IMG_20130710_152420_zpscf25c576.jpg
https://i34.photobucket.com/albums/d112/pitslayer/Buggy%20build/IMG_20130710_152435_zpsb8237b5b.jpg
Same on the otherside
https://i34.photobucket.com/albums/d112/pitslayer/Buggy%20build/IMG_20130710_163923_zpsf9a14eab.jpg
https://i34.photobucket.com/albums/d112/pitslayer/Buggy%20build/IMG_20130710_150247_zpsbc9d2cee.jpg
https://i34.photobucket.com/albums/d112/pitslayer/Buggy%20build/IMG_20130710_162328_zpsfcf86c16.jpg
These are now set to the shape of the body, as opposed to the body being set to the shape of the floor pan
https://i34.photobucket.com/albums/d112/pitslayer/Buggy%20build/IMG_20130710_163941_zps69a38036.jpg
https://i34.photobucket.com/albums/d112/pitslayer/Buggy%20build/IMG_20130710_163913_zpsc405bbd8.jpg
There might be an update later today with some paint going down.
pits
PostPosted: 14:21 - 11 Jul 2013    Post subject: Reply with quote
Sit rep...it is now green....am I happy with it...well no not really, but it is what it is and it will never be 100% correct
Firstly I as you will see, I know longer have a spray booth, dust is a contender here, a very big one.
My gun has gone walkies meaning I had to use the back up gun, wrong nozzle and generally gives a shit finish.
The body is 30 years old and well just ruined, so I know I am slapping lipstick on a pig, it leaves me with few options, but the main one at the moment is another coat, a flat down and clear coat it.
In an ideal world I would have had it re-gelcoated, but it isn't and to be honest it's just a car for mucking about in, I don't really care.
That said the colour is lovely, but you can see the state of the gun just from its spray "pattern" it's a pattern, it's not the pattern it should be, I would class this pattern as "all over the place"
https://i34.photobucket.com/albums/d112/pitslayer/Buggy%20build/IMG_20130711_133822_zps4701fbc1.jpg
https://i34.photobucket.com/albums/d112/pitslayer/Buggy%20build/IMG_20130711_133804_zpsa1dd81b6.jpg
https://i34.photobucket.com/albums/d112/pitslayer/Buggy%20build/IMG_20130711_133811_zpsd903f78b.jpg
second coat on
https://i34.photobucket.com/albums/d112/pitslayer/Buggy%20build/IMG_20130711_135224_zpsbda4a4e3.jpg
https://i34.photobucket.com/albums/d112/pitslayer/Buggy%20build/IMG_20130711_135242_zpsb6a52499.jpg
https://i34.photobucket.com/albums/d112/pitslayer/Buggy%20build/IMG_20130711_135214_zps713940b0.jpg
https://i34.photobucket.com/albums/d112/pitslayer/Buggy%20build/IMG_20130711_135234_zps54e336e7.jpg
Bonnet didn't come out well, we had technical problems during the paint, hence the general finish, luckily you can't see the epic run in the front where the gun blocked up and then unblocked itself, this is why I like using my gun, it's reliable, it never blocks up it never leaks, it never fires 1000litres of paint out in one go.
https://i34.photobucket.com/albums/d112/pitslayer/Buggy%20build/IMG_20130711_145034_zps383c5a4b.jpg
https://i34.photobucket.com/albums/d112/pitslayer/Buggy%20build/IMG_20130711_145030_zpsdef0f03f.jpg
Actually I lied, this is what happens when your gun decides to stop working for a second then fire the remainder of the pot out at your bonnet, that will get repainted with the dash I think.
https://i34.photobucket.com/albums/d112/pitslayer/Buggy%20build/IMG_20130711_145043_zps3bffdeaf.jpg
https://i34.photobucket.com/albums/d112/pitslayer/Buggy%20build/IMG_20130711_145141_zpsfa8b12c7.jpg
Not bad though, it is being rebuilt on a shoe string in a dirty workshop, everything on it isn't worth spending time on sadly as just about everything has been badly neglected.
Theres no point in having an amazing floor pan, which will cost me a couple of thousand to do nicely and a rubbish body, just like there is no point in having an amazing body and rubbish floor pan.
When money allows I will have the floor pan rebuilt and the body gelcoated, but for something I want on the road in a few weeks, it'll do.
fatjames
PostPosted: 14:11 - 12 Jul 2013    Post subject: Reply with quote
My pc screen in work must be shit. Paint looks great from this end!
Great job mate. Keep us posted.
trevor saxe-coburg-gotha
PostPosted: 18:29 - 12 Jul 2013    Post subject: Reply with quote
Nothing says great day at the beach like stagnant pond green.
PostPosted: 18:44 - 12 Jul 2013    Post subject: Reply with quote
The person doing the work in those photos has the oldest arms and hands I ever saw on a 14 yr old Smile
SQL
PostPosted: 19:42 - 12 Jul 2013    Post subject: Reply with quote
So do you frequently inspect 14 year olds?
Police Laughing
Paint looks better that my old pug, I painted it with house paint and a roller.
pits
PostPosted: 20:19 - 12 Jul 2013    Post subject: Reply with quote
some pics of it in the day light, happier but I still flatted it down and going to put another coat on when it cools down
https://i34.photobucket.com/albums/d112/pitslayer/Buggy%20build/IMG_20130712_120018_zpsd1ec496a.jpg
https://i34.photobucket.com/albums/d112/pitslayer/Buggy%20build/IMG_20130712_120048_zps1bbc6d18.jpg
https://i34.photobucket.com/albums/d112/pitslayer/Buggy%20build/IMG_20130712_120039_zpsb8aefea7.jpg
https://i34.photobucket.com/albums/d112/pitslayer/Buggy%20build/IMG_20130712_120026_zpsda6eb971.jpg
https://i34.photobucket.com/albums/d112/pitslayer/Buggy%20build/IMG_20130712_120051_zpsdc984e18.jpg
https://i34.photobucket.com/albums/d112/pitslayer/Buggy%20build/IMG_20130712_120034_zpsb2e20803.jpg
pits
PostPosted: 21:27 - 24 Aug 2013    Post subject: Reply with quote
Well I wasn't in the mood yesterday felt awful, then out of nowhere mates turned up, next thing I know
https://i34.photobucket.com/albums/d112/pitslayer/IMG_20130824_003511_zpse9865e53.jpg
Followed by
https://i34.photobucket.com/albums/d112/pitslayer/IMG_20130824_010537_zps9eda4d7c.jpg
https://i34.photobucket.com/albums/d112/pitslayer/IMG_20130824_012315_zps4b777417.jpg
Got some bits turning up next week for it hopefully.
sidewinder
PostPosted: 21:53 - 24 Aug 2013    Post subject: Reply with quote
Looks great especially on a low budget Thumbs Up Can't help thinking a scooby lump would go well in it Very Happy
prawny1
PostPosted: 09:31 - 25 Aug 2013    Post subject: Reply with quote
Would be a shame not to ditch the swing axle in favour of irs whilst you have the body off.
I think these always look better with the side pods for the body too imo.
hellkat wrote:
pits
PostPosted: 09:38 - 25 Aug 2013    Post subject: Reply with quote
Side pods are not available to buy anywhere, and IRS conversion is money.
The chassis is rubbish in the grand scheme of things and not worth spending any money on other than making it safe to use.
The last post was made 11 years, 362 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.69 - MySQL Queries: 14 - Page Size: 161.41 Kb
