Torc Ground Anchor In Shed
cagiva gezzer
PostPosted: 17:27 - 03 Nov 2013    Post subject: Torc Ground Anchor In Shed Reply with quote
Some photos of how to put a ground anchor into a shed. It took me a number of months to get around to doing this. Partly working out how to cut a neat hole in the shed base, partly how to secure a ground anchor and mainly what one!
1) Hole cut with oscillating multi tool (on offer in Argos)
2) Anchor from Security for Bikes and I can't recommend them enough.
3) Complete, reassuring, instructions came with the anchor.
So, how I installed my injection resin kit into the shed. This of course assumes you have a concrete base and you're not trying to bolt it into mud..
Look under the shed for where the bearers run and make a good judgement. Locate the nails inside the shed to help you find them.
https://i67.photobucket.com/albums/h294/supercitybity/Ground%20Anchor/1_zps9c34bcc9.jpg
Place round anchor in position and measure up.
https://i67.photobucket.com/albums/h294/supercitybity/Ground%20Anchor/2_zps507fde11.jpg
Cut out a tester hole. Partly to see how the new tool works / cuts. Luckily got it just in the right spot!
https://i67.photobucket.com/albums/h294/supercitybity/Ground%20Anchor/3_zps351ecdd5.jpg
Cut out the access hole full size. Cut sections of wood to box in the new hole to keep the cold / mice out. Little did i know these would be extremely useful later..
https://i67.photobucket.com/albums/h294/supercitybity/Ground%20Anchor/4_zps4ea942f3.jpg
Secure new bearers under floor and place anchor in desired spot. I drilled one hole first and the anchor drifted slightly. You can see in this photo that I boxed the ground anchor in with spare wood. This allowed you to use the base plate holes to guide the drill bit and keep it all square. Notice the cheap hammer drill. It survived and I wasn't concerned it if died during duty as it's £20 from argos. It would have cost me the same to hire one for HSS. It sparked, groaned, smelt and squealed. But it survived!
https://i67.photobucket.com/albums/h294/supercitybity/Ground%20Anchor/5_zps48ed69f3.jpg
https://i67.photobucket.com/albums/h294/supercitybity/Ground%20Anchor/6_zps6b542d04.jpg
Holes complete & cleaned out with hover / air hose. Note the tester hole in the middle to see if the drill can cope..
https://i67.photobucket.com/albums/h294/supercitybity/Ground%20Anchor/7_zps0d178cda.jpg
Instructions for the resin read twice over. All items in easy reach. All items clean. And we're off with the scary injection resin, which wasn't actually that bad! Resin in the holes, bolts in the holes, bearings in the bots and leave for a day.
https://i67.photobucket.com/albums/h294/supercitybity/Ground%20Anchor/9_zps79e8ed87.jpg
The finished product. The resin dulled the stickers as a bit too much was used in some of the holes. Feels secure, very secure.
https://i67.photobucket.com/albums/h294/supercitybity/Ground%20Anchor/10_zpsd9f92dcc.jpg
Pete.
PostPosted: 17:41 - 03 Nov 2013    Post subject: Reply with quote
Nice job, but I would have made the support box slightly smaller than the hole you cut so you had a ledge to fit a lid over the hole.
a.k.a 'Geri'
jaymos
PostPosted: 10:40 - 04 Nov 2013    Post subject: Reply with quote
Up there for thinking, down there for dancing. Very Happy
PostPosted: 18:23 - 04 Nov 2013    Post subject: Reply with quote
Still got the offcut? Use a hinge and add a batten to the frame. Voila you have flappage.
[edit] I see you have already damaged your flap. Tut Tut Never wreck a flap.
The last post was made 12 years, 307 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.49 - MySQL Queries: 13 - Page Size: 44.76 Kb
