| MattyNI |
 MattyNI Two Stroke Sniffer
 Posted: 12:12 - 02 Dec 2013 Post subject: Bike Wouldn't Start |
Hi guys I have been riding my Honda CBF 125 now for almost 2 months with no issues however when I tried to start the bike this morning no engine light or neutral came on when I turned the key.
The bike has not been used from Thursday, I am guessing it is the battery ? any help on how to attempt to get it running would be great guys thanks as I am still a complete newb but trying to learn, had to get the bus this morning
I also checked it was not in gear on side-stand as that has caught me out before
Thanks, |
| Aff |
 Aff World Chat Champion
| -Matt- |
 -Matt- World Chat Champion
 Posted: 12:55 - 02 Dec 2013 Post subject: |
Killswitch isn't flicked on by accident is it had me on a couple of occasions  |
| Teflon-Mike |
 Teflon-Mike tl;dr
Sounds like battery's flat.
You'll need to charge it back up.
DO NOT try and get a jump-start from a car.
Cars have a different type of regulator on thier generator; and if you put jump leads from a car battery to bike battery, the bikes regulator, can try regulating the power from the cars generator... NOT designed to handle such a big generator... they can get rather fried. And your bike is:-
1/ A Honda, who are notorious for weak regulators to begin with
2/ A Fuel Injected Honda... I'd hate to think what over volts might do to that system... especially as its already got a bit of a reputation for not being the most 'robust' to begin with.
It may be possible to 'Bump-Start', pushing the bike down the road, in gear to turn the engine over, and get volts from the generator to make sparks to get engine running... BUT as its a fuel injected bike, I suspect that without electric i the battery to begin with, the fuel injectors wont work, ... so might get you fit, but probably not get bike running.
My advice is TAKE THE BATTERY OUT.... I dont know where it is on CBF; they are normally accessed either by lifting the seat up, or by removing a side-cover; and they are designed to be user-serviceable; so will come out with bikes OE tool-kit. Usually held in with a strap or plate, that may be on a clip or held with a single screw. Then the two battery cables are attached by a screw each.
Once removed, you can charge up on a car battery charger from mains electric; just be careful, that a car battery charger will be rated at perhaps 4 or 8A, and your little bike battery is likely to be around 5Ah where a Car battery will generally be around 70Ah... so it wont take so long to charge, and DO NOT use car 'booster' settings on a battery charger for fast charging or to 'jump-start' a car, that will bang out maybe 90A to turn big car starter motor! That will FRY a diddy bike battery!
OR you can charge on Jump-Leads from a car; making sure that you put + to + and - to - between car and bike battery. (Isolated from the motorbikes electrics, its fairly 'safe' to charge off a car, as oposed to 'jump' start; the car wont be putting its electric through your bikes regulator or injection system; JUST into the battery)
While its out; look at the electrolyte level... battery is clear plastic and full of acid; SO BE CAREFUL.. if it leaks or you spill it, it'll dissolve your cloths! But there's normally hi/lo level marks on the side to tell you if there's enough acid. If not DO NOT top it up with tap-water; needs de-ionised water from motor-factors.
When charged; pop it back in the bike, and bit of luck, away you go.
BUT, query WHY the battery went flat to start with, or this could become a habbit.
Cold winters morning; if the battery is old and tired; the cold can chill the electrolyte in an old battery enough they loose volts, and this is hint you may be due a new one.
Else? Check you didn't leave parking lights on. Has the thing got an alarm that can drain the battery when not in use? What about the brake lamp? Some bikes the brake lamp works whether the ignition is on or not; and if poorly adjusted, or the switch broke, can stay lit and flat battery.
Most likely though; combination of factors; and common one is just not putting as much electric into battery as you take out.... lots of short journeys, where big withdrawal made from battery each time you use the starter motor; not 'paid back' by the engine running for long enough or hard enough for generator to put it all back; after electric to run fuel injection, sparks, then lights and indcators and everything taken off... in fact, on little bike, if you short shift and dont rev it, and spend time sat at idle a lot; lights on, bike can carry on taking out of battery not paying back... a good long 'thrashing' can be quite healthy for a bike from time to time, you kow. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Aff |
| Teflon-Mike |
 Teflon-Mike tl;dr
| Rogerborg |
 Rogerborg nimbA
 Posted: 13:50 - 02 Dec 2013 Post subject: |
| Minty |
 Minty World Chat Champion
| Boxing |
 Boxing World Chat Champion
| MattyNI |
| GeorgeB. |
 GeorgeB. Crazy Courier
 Posted: 14:37 - 02 Dec 2013 Post subject: |
CBF125s don't have killswitches
But yeah, sounds like a flat battery. You'll need to take both parts of the seat off to get crocodile clips on both terminals easily, although the rear seat comes off with the key, and IIRC the front seat has two screws under the rear seat. There's also a cover on the battery which has a few screws. (again, IIRC)
It should start off the car battery after a few minutes. Once you've got it started, disconnect the two clips without letting them touch, put everything back together and take it for a good ride to allow the battery to charge back up.
Good luck! ____________________ Current: '99 Fazer 600 | '99 Range Rover P38 4.6 HSE
Previous: Keeway TX125 | CBF 125 | CB400SF Project Big One
CBT 04/12/12 | Theory 03/12/13 | MOD 1 06/01/14 | MOD 2 13/01/14 |
| Skudd |
 Skudd Super Spammer
| MattyNI |
| Skudd |
 Skudd Super Spammer
| GeorgeB. |
 Posted: 15:12 - 02 Dec 2013 Post subject: |
If the Alarm is an immobiliser too, I think you'll struggle, but it's definitely something to try  ____________________ Current: '99 Fazer 600 | '99 Range Rover P38 4.6 HSE
| Skudd |
 Skudd Super Spammer
| MattyNI |
| GeorgeB. |
| -Matt- |
| MattyNI |
 Posted: 15:28 - 02 Dec 2013 Post subject: |
I am from Belfast prob not that local but thanks for the offer , It was fitted at Belfast Honda the previous owner of the bike had it done not me during a service. on the receipt it just says £99 alarm lol
| -Matt- |
 Posted: 15:31 - 02 Dec 2013 Post subject: |
If you've got a garage/powersupply around - i used to get flat batteries quite often because of a tiny-commute. Popped a pigtail on the battery and put it on charge whenever i can and its been fine for a few years since even with using the alarm 24/7  |
| MattyNI |
| -Matt- |
 Posted: 15:42 - 02 Dec 2013 Post subject: |
I used to do a 2-3 mile commute mon-fri for a while and occasional weekend runs if the weather/time permitted, and that didn't seem to do the batteries any favours so it might be a factor at the least.
The pigtail-power supply things easiest, but if you don't have a garage etc it might not be too much of a hassle to just take the battery out and give it a charge every now and then indoors - on a lot of bikes its just a couple of screws, on others like my current ZX6 its PITFA involving lifting the tank etc  |
| MattyNI |
| GeorgeB. |
 Posted: 15:48 - 02 Dec 2013 Post subject: |
I commute 1.5 miles each way and no problems  ____________________ Current: '99 Fazer 600 | '99 Range Rover P38 4.6 HSE
The last post was made 12 years, 297 days ago. Instead of replying here, would creating a new thread be more useful? |
