Dyno Jet Slide Drill Sizes
Fowlersrs
PostPosted: 19:20 - 11 Dec 2013    Post subject: Dyno Jet Slide Drill Sizes Reply with quote
Greetings all,
Bought myself a bit of a bargain dynojet kit for my 97 srad 750 the other day, was only missing the drill bit for the slides.
No problem I thought, itl prob list the size in the instructions I thought, WRONG!
All that's listed is Slide Drill DD#49, what the feck is that suppose to mean, if anyone is incredible enough to know what size that is, or has a jet kit with that drill bit in it, my god I'd be amazed.
Anyone help solve the mystery?
yampug
PostPosted: 19:59 - 11 Dec 2013    Post subject: Reply with quote
tried searching online for some sort of conversion but had no luck i think the only way you're going to find out is if some kind person on a suzuki forum has the drill in their kit and they can measure it for you, guess they don't want any one knowing what size there secret drill bit is otherwise it would make them redundant.
Raffles
PostPosted: 20:15 - 11 Dec 2013    Post subject: Re: Dyno Jet Slide Drill Sizes Reply with quote
Check this out
yampug
PostPosted: 20:18 - 11 Dec 2013    Post subject: Re: Dyno Jet Slide Drill Sizes Reply with quote
Raffles wrote:
Check this out
i found that page as well but couldn't work out what wire no letter meant?
can't be that can it that would be a drill 0.0730mm thats tiny.
Raffles
PostPosted: 20:22 - 11 Dec 2013    Post subject: Re: Dyno Jet Slide Drill Sizes Reply with quote
Try again!
yampug
PostPosted: 20:28 - 11 Dec 2013    Post subject: Re: Dyno Jet Slide Drill Sizes Reply with quote
Raffles wrote:
Try again!
49/64 0.7656 ? Thumbs Up
edit: fuck knows i give up Laughing
Raffles
PostPosted: 20:35 - 11 Dec 2013    Post subject: Re: Dyno Jet Slide Drill Sizes Reply with quote
I've edited my post to include a link to a different conversion chart that may be easier to understand.
YBR Ric
PostPosted: 20:48 - 11 Dec 2013    Post subject: Reply with quote
1.8542mm
(Folwers rs) If you're in Bristol, Tim Blakemore carrries a full set, he enlarged one of mine when an in between size didn't exist to correct the fuelling.
Ideally the original jet number should be obliterated once altered to avoid any possible chance of confusion at a later date (by a third party).
yampug
PostPosted: 20:55 - 11 Dec 2013    Post subject: Re: Dyno Jet Slide Drill Sizes Reply with quote
ahhh makes sense now. my fault for reading decimal and assuming mm Thumbs Up
looks like someone else was having the same problem https://katriders.com/vb/archive/index.php/t-76050.html
yampug
PostPosted: 21:00 - 11 Dec 2013    Post subject: Reply with quote
YBR Ric wrote:
1.8542mm
i thought it was to drill a hole in the slide not the jet?
Fowlersrs
PostPosted: 07:49 - 12 Dec 2013    Post subject: Reply with quote
YBR Ric wrote:
1.8542mm
I get the logic in this, my only question is. Are we 100% sure that dynojet when listing #49 are referring to the tap drill size?
To be fair it's a good shout, but I need to be 100% before I drill them!
I guess one way to be sure is, my mate has a fireblade kit which has #44 drill but in it, if I measure that with a set of digital verniers it should be 2.18mm correct?
yampug
PostPosted: 10:19 - 12 Dec 2013    Post subject: Reply with quote
^yep sounds logical Thumbs Up
to be doubly sure you could ask on a few forums for people to measure their slide drills
YBR Ric
PostPosted: 10:52 - 12 Dec 2013    Post subject: Reply with quote
yampug wrote:
YBR Ric wrote:
1.8542mm
Ooops, went off on a tangent, the drills for enlarging brass jets are more akin to a minature reamer that's twisted between thumb and finger - definately not suitable for this application.
Several No.49 drill stockists listed on ebay,
starting at £1.21 inc delivery.
Ross46
PostPosted: 10:42 - 13 Dec 2013    Post subject: Reply with quote
What's the slide hole size normally? My zxr400 DJ kit came with a 3.1mm drill bit, think it's coded #31
There is a gap of 6 years, 53 days between these two posts...
iceng This post is not being displayed because it has a low rating (Spam). Unhide this post / all posts.
The last post was made 6 years, 120 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.18 Sec - Server Load: 0.93 - MySQL Queries: 16 - Page Size: 96.53 Kb
