marauder gz 125 07 plate goes click on start up
Mark the Hat
PostPosted: 17:39 - 07 Jan 2014    Post subject: marauder gz 125 07 plate goes click on start up Reply with quote
OK my marauder GHz 125 on a 07 plate has charged battery, fuel, been standing for about a year but goes click when try to start it up. Am a total novice so please keep it idiot proof
wr6133
PostPosted: 18:30 - 07 Jan 2014    Post subject: Re: marauder gz 125 07 plate goes click on start up Reply with quote
You check the battery is actually holding a charge (with a multimeter)?........ as what you describe sounds like a dead battery
misscrabstick
PostPosted: 18:50 - 07 Jan 2014    Post subject: Reply with quote
What WR said I think. Try getting a jump start off someone with jump leads, GET POLARITY RIGHT!
Walloper
PostPosted: 19:05 - 07 Jan 2014    Post subject: Reply with quote
Disconnect the battery leads, clean all connections, re-connect and try again.
Possibility of the battery being gubbed if it's been stood.
Even though a 'charged' battery indicate 13.5 Volts it may not be able to push the stored energy out.
A battery has to be tested in more than one way.
Open Cell Voltage is the easy one you check by conecting a DC volt meter between the + and - posts and read the voltage.
The difficult but more important test is called a High Rate Discharge Test.
This test the battery efficiency at pushing out amps watts and volts and stuff.
To do that you connect a DC voltmeter as before to read the Open Cell Voltage.
Then you apply a load to the battery and watch the voltage drop. A good battery should be able to hold more than 10 volts for a few seconds.
On a gubbed battery the voltage will dive into the low 3s and 4s after the same time.
It is a bit of a specialist test which is also a bit risky if you don't know what you are up to.
The load can be simply the effect of the starter being held on for the test.
Bike in gear, rear brake held on and push to start.
Only if the bike can start in gear. Most bikes have an safety interlock to prevent this.
The alternative is to take the battery to a garage who can test it. Some Halfords places can do it.
The last post was made 12 years, 315 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.09 Sec - Server Load: 0.33 - MySQL Queries: 16 - Page Size: 40.21 Kb
