Can having a broken fuse, stop the bike from working?
WackeyMills This post is not being displayed because it has a low rating (Boring). Unhide this post / all posts.
gavcarter
PostPosted: 17:25 - 11 Jan 2014    Post subject: Reply with quote
yes could be
PostPosted: 17:59 - 11 Jan 2014    Post subject: Reply with quote
How many threads are you going to start about the same trivial problem?
Change the fuse. </story>
WackeyMills This post is not being displayed because it has a low rating (Abusive). Unhide this post / all posts.
WD Forte
PostPosted: 02:57 - 12 Jan 2014    Post subject: Re: Can having a broken fuse, stop the bike from working? Reply with quote
WackeyMills wrote:
Found a broken fuse in the Yamaha YBR 125. When I turn the key in the ignition, nothing happens no lights on dashboard whatsoever. could this be a fuse problem?
It isnt really a 'fuse problem' as long as its the correct rating
What you should be asking is why did the fuse blow?
A short to ground is a common reason.
bikers smell of wee
chrisjose1913
PostPosted: 03:31 - 12 Jan 2014    Post subject: Reply with quote
Yes, it's very likely to be a cause, get a new fuse, that may fix the issue, if it blows again, it could be due to a short in the wiring due too, burning, damp wiring ETC ETC.
1997 CB500
Musketeer
PostPosted: 11:34 - 12 Jan 2014    Post subject: Reply with quote
Did I mention that wrong powerband can increase the voltage? If I was you I would check your powerband asap before it's too late.
By the way.. are you JiveBunny's younger brother?
The last post was made 12 years, 288 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.03 - MySQL Queries: 14 - Page Size: 51.18 Kb
