| moppy |
 moppy World Chat Champion
 Posted: 00:54 - 09 Jan 2014 Post subject: Varadero 125 Electrical Woes |
Riiiight then. My 07 Varadero 125 will not start. I hit the ignition button and I just get a continuous clicking noise. I will mention right now that the bike dos have heated grips connected and connected directly to the battery, no relay.
The breakdown guy came over and was able to jump start the bike no problem. He stuck a multimeter on the bike during idle and it was measuring 12.8. I was told it should be 13.8 atleast? He revved it up to 3k rpm and measured again.
He diagnosed this as a shot reg/rec, something I hear is very common on Hondas. I'm assuming the battery is shot too, so my plan is to get a reg/rec, new battery and maybe a trickle charger to keep everything in shape.
If BCF could confirm a few things for me please. First of all, is the reg/rec definitely the issue? The guy who came out seemed to know his stuff, so I assume thats true.
Secondly, could someone find me the reg/rec I need to buy? I've found this which seems to suit the pictures that Honda themselves have put up.
Would that be alright?
Cheers for the help BCF. |
| simonjb |
 simonjb Nova Slayer
 Posted: 01:16 - 09 Jan 2014 Post subject: |
Could well be either especially as the charging voltage is so low, but before you do any of that, rather than waste money if the regulator and rectifier are fine; get yourself a standard battery charger, or better, a maintenance charger (these are useful anyway) and let it charge the battery to full.
Run the bike around a bit (don't put yourself in a situation where you could get stranded), see if the problem reoccurs - make sure that the heated grips aren't drawing any power when they're switched off and the engine is off! Even better, disconnect the heated grips for the time being, just to eliminate them as the cause.
If the problem reoccurs (and the grips are def. not to blame) you've almost certainly got some kind of charging fault, most likely rectifier or regulator. Then you should go about diagnosing and replacing whichever component is faulty. If no one on here will link you to the right component, check with the seller on ebay, and if they say it's the right part, it probably is - if it's not, they're at fault so you can get a refund.
Good luck  ____________________ Current Bike: 2008 Yamaha YBR 125 |
| Robby |
 Robby Dirty Old Man
| jeddy11 |
 jeddy11 Traffic Copper
 Posted: 10:41 - 09 Jan 2014 Post subject: |
As above really ^^ from what i gather from the OP is that the breakdown man revved it a bit then re tested the voltage rather than measuring at the same time as revving to 4-5k ??
That's the key if its all charging correctly the charge voltage should change the more you rev it up obviously. Sometimes the voltage can be misleading until you start revving it up a bit... ____________________ Fuelly My Z1000SX
cbt 06/08/11 mod1 (second go) 01/08/12 mod2 21/09/12
Varadero Viking YBR125>Varadero125>ER6F>Z1000SX !!! |
| moppy |
| moppy |
The last post was made 12 years, 257 days ago. Instead of replying here, would creating a new thread be more useful? |
