CG125 Crankcase Gasket + Metal Filings Question
crazymotorbik...
PostPosted: 20:47 - 15 Jan 2014    Post subject: CG125 Crankcase Gasket + Metal Filings Question Reply with quote
Hi,
After getting tired of my CG125 turning my Garden into an environmental disaster area i've finally got round to changing the leaky crankcase gasket.
On closer inspection of the crankcase mating surfaces i have notice there is a few areas where corrosion has got in and pitted the surface ever so slightly. My main concern is I'll get the damn thing back together and it'll leak again.
Would it be OK to use a liquid gasket with the paper gasket? or will the paper gasket alone allow for these minor defects?
Also while striping down the engine i manged to damage the screws holding the oil pump to the crankcase, as a consequence i had to drill them out and unfortunately a few filings made their way into the engine! Doh! I found some of these filings on the crank and bearings.....The crank is still in the engine (As i dont have a puller for the generator) and if possible i don't want to remove the crank. Would it be a good idea to run oil over the crank to hopefully remove said filings or would it be better to remove the crank all together?
Cheers in advance,
Shaun R.
The last post was made 12 years, 288 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.45 - MySQL Queries: 14 - Page Size: 27.99 Kb
