| doombug11 |
 doombug11 Borekit Bruiser
 Posted: 04:14 - 19 Dec 2013 Post subject: Honda CM 125 to CD200 - Carb and Engine Set-up |
Hello there!
So I decided to upgrade my little Honda CM 125's engine, since passing my test and jumping up to a VFR 750 the little bike feels somewhat dangerous out on the open road with my fat arse lumped on it, at 6 foot 4 I rarely get past 55 on any 4t 125 maybe 60 on a nice motorway with a gradient. As my only mode of transport I would like to keep the little bike, its not really worth much so theres no much point in selling it and its great for popping round town, it just needs a bit extra speed! So I heard it was possible to shove a 12v CD200 engine straight in to my bike so found an old one that had been sitting for a while for £45 of ebay.
Looked a bit dirty but it had good compression so thought it was worth a shot, quite handily all the bolts holding old mountings that looked rusted solid in the photos had been coated with grease at some point and came apart really easily so fitting it went really smoothly.Changed the oil, bodged the cables together and using the spark plugs and carb from the 125 set about giving it a kick, got a flash of life on the 3rd kick and it came roaring back into action a few more later. Quite chuffed with that, got ripped off on a dodgy 125 engine back in the summer for 150 quid that pissed oil everywhere (though it kept me mobile whilst i rebuilt its original motor) and another for 180 i got my money back on that blew a spark plug the first time I rode it!!
Sounds really nice, and sat ticking away at idle pretty quickly, sadly the clutch was seized but wasn't a big issue just had to take it out and give it a clean. At first it refused to go into first, though it was pulling away just fine in 2nd so took it for a spin and after a few trips round town it worked itself back in again. While the power is quite decent at the lower revs it doesn't like being revved to high and chokes out as you open the throttle.
So now I've got it in motion I need to set about getting the engine set up properly, I dont have a manual for the 200 so was hoping someone could help me with some specs and settings, namely what spark plugs to use and what valve clearances to set the tappets to. The engine came with a carb but the throttle slide was seized, I'm going to attempt to clean this up and see if it works but it would be great if someone had the specs for the carb, float height, pilot screw turns, jet size etc.. Hopefully get it running nicely!!! |
| temeluchus |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 16:46 - 19 Dec 2013 Post subject: |
Not dropped a 200 Benley into a CM, have dropped one into a Super-Dream. works very well, actually.
360 degree motor is lumpier than the Twin Carb 125's 180 lump. Stock, it punts 15bhp, which is a tad more than the UK spec Super-Dream's 13, tad less than the older 'full-Power' T2's 17. Is up on the 10/11 of the CM and CD125's though, with their 360 Single carb motors... but it is that mid-range that is quite remarkable.
The extra cubes and the milder state of tune, suddenly there is so much 'flexibility' on the throttle. Actually completely changed the handling of the 125 Super-Dream, which needed revs to make thrust, and cornering was a case of tipping in, throttling on, and waiting for the revs to catch up to give you drive.. with the 200 motor, all of a sudden you have 'thrust' available just by opening the throttle, and can actually 'drive' the thing through bends... 'almost'... I say 'almost' like a 'Big-Bike'
Ran it on the CB's twin-carbs, and CDi ignition though, so may have had a tad more power/response, without that tortiouse twin-branch.
I suspect, though that big part of my initial shock at how strongly it pulled, though, was because Benley runs much taller final drive gearing, having only the four-speed box, and a lower top-gear drive ratio.
With twin-carbs and tacho, its pulling strongly to the 125's red line at 11K, and on the 125 Super-Dream gearing, that's enough to nudge the needle at the 80 mark. I suspect it could pull taller cogs, though doubt it would make it much if any quicker... but certainly wouldn't be quite so frenetic. 180-crank 125's like them revs, seems 360-crank 200's dont! On 125 gearing, though 1st is almost redundant, you can pull away in 2nd or 3rd...
So, I'd suggest you might like to mess with sprockets a bit to get the best from that engine. But also, I suspect that single 24mm carb will be rather strangling it.. 26 it should have, or better twins, will make it that much 'free-er'... though fuel consumption will suffer.. still good, but low side of 80 rather than high. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| salem1987 |
 salem1987 Scooby Slapper
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 22:35 - 19 Dec 2013 Post subject: |
| salem1987 wrote: | Tef: Did you use the super dream inlet manifolds im assuming for twin carbs? |
It was a 6v CD200 motor out of a crash-damaged bike. I actually only really wanted/needed the barrels off the motor, as part of a plan to build a short-stroke, big-bore Benley engine, with a 180 degree Super-Dream crank; 'full-power' 125T2 cam, and high-compression CB200 pistons.... ultimately to go in Snowie's 'Pup', so she could make the most of all the work renovating a tiddler, after passing her tests, riding it on 33 restricted. She got the licence, but that engines not been built! And her restriction's up next year!
However, I had one of 'those' moments, like you do, when you cant resist having a tinker... I dropped it into one of the Super-Dreams pretty much 'as was' to see if it ran... it did... so was reluctant to tear it apart, JUST for the barrels... especially as at the time I was still collecting other bits and researching ways to make it all come together and overcome gudgeon-pin niggles.
Consequently it was lying about, when one of the Super-Dream's was giving grief, and I wopped it in as a stop-gap until I could do a top-end on the bugga-mota.
It had a smashed primary drive casing; so I swapped that out for one of a 125 lump, removing the kick-start mechanism to fit it.
I swapped the 6v Benley starter for 12v Super-Dream, and the 6v rotor and generator cover, with its 12v Generator windings; twin CDi ignition windings and triggers, then made up a Y piece with bullet connectors, to put trigger signal from one pick-up to both CDI units, to get 360 timed sparks.
Took about an hour to swap the genny and stuff off the 125, and slotted straight in the frame like a 125 lump, bolt for bolt, even the cylinder-head steady.
Used carbs and carb-manifolds off the 125, and again, bolted up just like they would to a 125 motor, including plumbing to the stock air-boxes. 125 exhausts went back on, just as they had on the 125 motor. Very tidy 'fit' and easy swap-job.
As said, it completely changed the handling of the bike. The 125 Super-Dream chassis was pretty advanced in its day, with multi-link rising rate monoshock rear suspension, and the brakes are quite impressive for an old tiddler, with the twin-piston floating caliper on the front, if its properly fettled, and better still with a braided line.
On Decent tyres, (Mitchelin M45's) with 125 motor, the Super-Dream was quite an eager and sweet handling little thing, but that engine never gave you much 'drive'. Best way I can describe the difference was that after riding it with the 200 in it, it was like SUDDENLY it had found the missing ingredient, and you could actually make it drive through a corner, and get that handling working for you, where before, it was like you were merely 'coasting' through them.
Gawd knows what Honda were up to when they made the cruiserified CB 'Two-Fifty' with a single carb 53x53 Benley engine, and the CD250U 'not Benley' with twin CV carbed version of that engine.
A Big-Bore Benley motor in a Super-Dream chassis is a very nice confection. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| doombug11 |
 Posted: 00:18 - 21 Dec 2013 Post subject: |
So here's where I'm at with this little project, I took the cd200 carb apart to see if it was possible to clean it up but the slide was seized solid, hit it with WD40 and a bath of petrol but it was wedged in there good. So decided as I have 3 other spare PD series carbs I would just force the slide out to recover the needle, jets and float and put them in another body. The slow jet was corroded in solid and annoyingly had no screw or bolt head to grip onto so was forced to leave it be, I'm only going to damage it forcing out so had to use the 38 slow jet from the 125, but I did recover the 110 main jet and needle. Annoyingly I hadn't thought the slide itself would be different but it is of course a heavier weight, too damaged from my extraction method I used the lighter throttle slide from the 125.
So in the end I ended up with a Frankencarb, put it back on the bike and took it for a quick spin round the country lanes. Engine ran really well, a little slugish on the lower end of the throttle this time most likely due to the wrong slow jet but it was no longer choking out when you opened it up. My word though that has made a difference! Just like you said Tef the mid range power transformed the bike, really pulled it through the corners, though being a CM frame and not the superdream it was of course still a bit wobbly!! I'm not sure quite how fast I got it either, the needle just bounced frantically between 60/70, though it still felt like it was accelerating, certainly faster than its ever travelled before!!
So with the little test ride over I need to sort out various bits, ideally I really want to go with this twin carb set up you guys are discussing, going to have to hunt myself down a pair in the new year, if I cant find any I'll just get a refurb kit for the time being. Had to order a clip-on air filter too, easier than trying to re-plumb it to the air box and I prefer the look of them anyway!
My biggest obstacle is the sprocket alignment, the counter-shaft looks to be about 10mm shorter than the one on the CM engine. From what I've been researching online it looks like my best bet is to get a fabricator to cut the teeth of one sprocket and the centre out of another and weld them together, when I eyed them up the offset looks to be exactly the width of one sprocket so should work I hope. Asides from that there appears to be people who are willing to make them but its pretty pricey!! Though I don't really want to have the chain jumping so I'm going to have to sort this one out. |
| andymech |
 andymech L Plate Warrior
| salem1987 |
| andymech |
| doombug11 |
 Posted: 12:20 - 16 Jan 2014 Post subject: |
Had some hefty essays to be written this last month so hadn't had a chance to tinker with my little CM. Also had to wait a few weeks for my local bike shop to order in a clip on air filter, when I got this I took it for a quick ride to see how it was running and after a few miles it started to run like like a bag of shit, constantly stalling and needed full revs to get you going or it would kangaroo out on you. Went to make an adjustment on the pilot mixture screw and the bloody thing wasn't there!! (I forgot to put the spring in )
Got it home and the next day I finally got through the 42 slow jet I ordered and a new throttle cable. Fitted everything on, including a spare pilot screw with spring , naturally the pattern throttle cable was completely wrong, but I've finally got this little bike running well Ticks over nicely, runs well all the way up the powerband and doesn't half shift compared to the 125!
Had to piss about for a bit with a couple different gear change levers, the engine is slightly wider so for the CM lever to work it had to be positioned too low, I've got big arse feet so had to stamp on it with my heel to change down! So ended up using a random one I found in a box of spares, looks rusty and has a bodged handle but works a treat
Asides from a proper fitting and non-fucked throttle cable (I would like some consistent engine breaking!!!) All there is left to do now is sort out the gearing. Think I'm gonna go for 16-17 on the front, it has a bit too much acceralation right now, like you had Salem it tends to rev it self mental at 60+. Probably experiment first before I get an off-set sprocket made up, their quite pricey!! Got a friend who offered to attempt one, confident he can balance it but I'm not so sure!! Looking at 60 quid for one from the states or 80-100 quid labour from a local machine shop depending on how long it takes. Could just run it as is but at these prices for a small Honda sprocket my mates offer is looking rather tempting!
Here's a couple of pics of the old girl.
https://i802.photobucket.com/albums/yy309/doombug11/pic1_zps35d0fea8.jpg
https://i802.photobucket.com/albums/yy309/doombug11/pic2_zpsd794eec8.jpg ____________________ 1999 CBR900RR, 1984 CM200 (previously 125) |
The last post was made 12 years, 273 days ago. Instead of replying here, would creating a new thread be more useful? |
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 1.05 - MySQL Queries: 14 - Page Size: 77.59 Kb
