A guide to road registering your offroader - How I did it.
Bike Chat Forums Index -> Offroad & Supermoto Goto page 1, 2, 3  Next
TwoWheelsDail...
PostPosted: 16:34 - 03 Feb 2014    Post subject: Reply with quote
Very helpful!
MODS PLEASE STICKY!
Suzuki GSR 750 - 33BHP (Restriction Ends 17/12/2014)
KTM Duke 125 - SOLD
www.facebook.com/TwoWheelsDaily | www.twitter.com/TwoWheelsDaily | www.instagram.com/TwoWheelsDaily
PostPosted: 17:08 - 03 Feb 2014    Post subject: Reply with quote
TwoWheelsDaily wrote:
Very helpful!
MODS PLEASE STICKY!
Agreed, it will also assist those who are wanting to register pits, although they would more than likely require SVA as you cannot register as "enduro" Thumbs Up
ian505050
PostPosted: 20:32 - 03 Feb 2014    Post subject: Reply with quote
If you have an offroad bike with lights fitted as standard you just need to tape up the lights for the MOT and then pull the tape of the lights as soon as it has passed. You also need to cover any switchgear for the lights with tape.
I don't believe that you can use a bike with 'daylight restrictions' when its dark until the lighting fitted to the bike has been tested at an MOT centre.
You would also need a rear brake light and indicators fitted to the bike if you was to use the bike atnight i believe.
Any bike with with a 'daylight restriction' can only be used up to 30 minutes before sundown and 30 minutes after sunrise.
PostPosted: 20:37 - 03 Feb 2014    Post subject: Reply with quote
It is an advisory, would you go back to have the head bearings checked? Nope, same with lights.
You would need ALL lights aside from indicators if you were using at night Thumbs Up
stuartt
PostPosted: 20:43 - 03 Feb 2014    Post subject: Reply with quote
i was looking at a 450 crf buildbase , the dealer said theres no way it could ever be registered for the road is that true ?
or could it be registered doing what you did ?
PostPosted: 21:13 - 03 Feb 2014    Post subject: Reply with quote
You can road reg a CRF450, same as iain did.
stuartt
PostPosted: 21:14 - 03 Feb 2014    Post subject: Reply with quote
ok thanks .
PostPosted: 21:50 - 03 Feb 2014    Post subject: Reply with quote
Erm, no again. At any time when you'd use lights if fitted its illegal to ride it.
He is quite right, it does state you can ride half hour either side... Thumbs Up
Highway Code 113 wrote:
You MUST
ensure all sidelights and rear registration plate lights are lit between sunset and sunrise
use headlights at night, except on a road which has lit street lighting. These roads are generally restricted to a speed limit of 30 mph (48 km/h) unless otherwise specified
use headlights when visibility is seriously reduced (see Rule 226).
Night (the hours of darkness) is defined as the period between half an hour after sunset and half an hour before sunrise).
Laws RVLR regs 3, 24, & 25, (In Scotland - RTRA 1984 sect 82 (as amended by NRSWA, para 59 of sched 8))
PostPosted: 22:04 - 03 Feb 2014    Post subject: Reply with quote
Interesting that darkness is defined as starting half an hour after the sun goes down.
PostPosted: 22:05 - 03 Feb 2014    Post subject: Reply with quote
Daytime MOT where the sun never sets Laughing
Legally then, I could jump on my old monkey bike at about 6.40am, )in darkness Laughing ) Then ride to work Laughing
PostPosted: 22:10 - 03 Feb 2014    Post subject: Reply with quote
The police barely know left from right Laughing
Definitely grey though... I'd probably write a quick guide with common questions regarding MOTs and quick fixes. I'd probably get beaten with the quick fixes Shocked
PostPosted: 22:23 - 03 Feb 2014    Post subject: Reply with quote
_Iain_ wrote:
it entirely depends on what the officer deems sunrise and sunset - which greatly varies depending on how much of a cock he's being Laughing
Think the time is defined. BBC new weather site gives the times for a location for example.
stevo as b4
PostPosted: 19:07 - 04 Feb 2014    Post subject: Reply with quote
Excellent how to thread!
My only question is why there is a 900mm min seat height rule and 300mm ground clearance stipulation for road registering an off roader? Surely this will leave a lot of play bikes and less competition derived machinery out, unless this is the intention?
PostPosted: 20:37 - 04 Feb 2014    Post subject: Reply with quote
_Iain_ wrote:
Horn, rear reflector and numberplate for a daylight MOT.
Rear reflector eh? Wink
PostPosted: 23:13 - 04 Feb 2014    Post subject: Reply with quote
_Iain_ wrote:
Yes. A rear reflector is required even running daylight use only.
Not required Wink
MOT, 1.5 under lighting.
Rear reflectors are not required to be fitted to vehicles used only during the hours of daylight, which are fitted with neither front nor rear position lamps, etc. (See 1.1.A)
Although if fitted, should be central Neutral
Party at my place, reflectors need not apply. Dance!
ian505050
PostPosted: 23:53 - 04 Feb 2014    Post subject: Reply with quote
_Iain_ wrote:
Wrong. If it is enduro registered it can have lights legally, merely easier to pass an MOT without them there. Lights have to be E-marked
I am a little confused, i was on the understanding that they had to be taped up.
Again, no. Its an advisory. You dont have to re-mot for a tyre that gets a low tread advisory.
Yes, but you are fitting an component to the bike that the MOT tester is unable to check is safe or legal. Where as the tyre is physically fitted to the bike when the MOT test is performed and the MOT tester can make a decision as he can physically see/check the tyre. You could fit lights to your bike that do not meet the legal requirements or could be a hazard to others.
Nope, if you run lights indicators are optional on an enduro registered bike. You would require sidelight, dip/main beam, a brake light and a tail light all E-marked and the headlight beam would need apropriate adjustment.
cant remember where i read you needed indicators, but i am sure i have seen it somewhere
I am 99% sure this is correct. I am sure there is a legal definition that states time somewhere.
The CRF is fine, any full size motocross, trail or enduro bike is fine. Anything with a ground clearance of at least 310mm and a seat height of at least 900mm is also fine to be road registered in this way as it goes.
ian505050
PostPosted: 23:56 - 04 Feb 2014    Post subject: Reply with quote
Paddy. wrote:
Not required Wink
You may be correct on that one paddy but i am sure it states somewhere that you need a reflector fitted to leave your vehicle parked on a main road on a night. I guess if you park in the garage its not an issue.
PostPosted: 08:54 - 05 Feb 2014    Post subject: Reply with quote
It doesn't say that anywhere, you require sidelights if you park on a road that is marked above 30mph. Thumbs Up
The last post was made 12 years, 227 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.18 Sec - Server Load: 1.31 - MySQL Queries: 13 - Page Size: 165.48 Kb
