Bikecams and AVI file sizes - what is going on?
Andy_Pagin
PostPosted: 15:41 - 07 Feb 2014    Post subject: Bikecams and AVI file sizes - what is going on? Reply with quote
Specifically I've just started using a Vivitar DVR480 cam on my commute.
The journey time's anything from fifty minutes to an hour and a half, and the resulting .avi video is usually about 2 to 3 gig.
However on the first day of the tube strike I had a really fast run into London until I hit Shoreditch when I ended up at a more or less complete standstill for about twenty minutes followed by a slow crawl to the car park.
The total journey times was about an hour and a half, but the .avi file hit the 4.3 gig limit and the camera stopped after fifty minutes.
So why the vast difference in file size when the only difference in the journey was an exceptional amount of stationary time?
CaNsA
PostPosted: 15:55 - 07 Feb 2014    Post subject: Reply with quote
VGA: The video clip size is higher and the quality is better when the resolution is VGA than that is QVGA.
QVGA: The length of recording is longer when the resolution is QVGA than when the resolution is VGA
theres your answer that i found after 3secs of looking in the manual.....
RTFM motherfucker
PostPosted: 16:26 - 07 Feb 2014    Post subject: Re: Bikecams and AVI file sizes - what is going on? Reply with quote
Were you stuck next to a group of dancing clowns?
doggone
PostPosted: 17:06 - 07 Feb 2014    Post subject: Reply with quote
I suppose it's possible that properly resolving almost stationary surroundings uses a lot more space than the 'blur' of things whizzing past.
You should try a simple test with it on the table or running round the room for 5 minutes. Laughing
Andy_Pagin
PostPosted: 17:47 - 07 Feb 2014    Post subject: Reply with quote
RTFM motherfucker
Don't really get that, here's the details for two files 1hr3mins and 1hr8mins.
The big one 1 hour 8 mins 4Gb
RIFF (little-endian) data
AVI
640 x 480
30.00 fps
video: Motion JPEG
audio: uncompressed PCM (mono, 22050 Hz)
The small one 1 hour 3 mins 1.9Gb
AV
640 x 480
30.00 fps
video: Motion JPEG
PostPosted: 18:51 - 07 Feb 2014    Post subject: Reply with quote
Andy_Pagin
PostPosted: 09:31 - 08 Feb 2014    Post subject: Reply with quote
No clownsPCSOs, just the usual central London rush hour street scene.
PostPosted: 16:40 - 08 Feb 2014    Post subject: Reply with quote
Could be something as basic as lighting levels couldn't it? If it's darker there's less detail. Won't that affect compression levels?
WD Forte
PostPosted: 22:08 - 08 Feb 2014    Post subject: Reply with quote
Dunno
maybe its just not that good?
maybe the firmware is a bit iffy and doesnt handle the encoding and allocating memory very well?
the fact you can fit a 16Gb card but it will only record up to 4.3 gigs
in one go isnt very impressive.
bikers smell of wee
Andy_Pagin
PostPosted: 22:49 - 08 Feb 2014    Post subject: Reply with quote
The 4.3 gig limit is a limit of the Fat32 file system.
WD Forte
PostPosted: 01:00 - 09 Feb 2014    Post subject: Reply with quote
Ride faster?
bikers smell of wee
barrkel
PostPosted: 02:23 - 09 Feb 2014    Post subject: Reply with quote
tl;dr: it's because your camera has a cheap video encode chip that makes it more expensive to record still pictures than moving pictures.
Motion JPEG is a concatenation of JPEG files. It has no inter-frame compression; it is no cheaper to compress a fixed, unchanging picture than a succession of completely different frames. Quite the opposite, in fact, when it comes to motion.
JPEG compression is normally quality oriented rather than bitrate oriented. That is, you choose how much precision you're going to cut off, but if the image has high information content, you'll still have a lot of data. Encoders do not generally have file size targets, such that they change the quality to fit the image in a particular size.
Sharp, focused images of static scenes with lots of detail have high information content. Road has texture, bricks, windows, people, etc.
Blurry motion - especially when captured by a cheap cmos sensor - has low information content. Road turns into a smoother grey / black streak, bricks are blurrier smudges, etc.
To demonstrate this, I took a standard test image in PNG format - Lenna - and saved it with Photoshop, Quality 9, "Baseline Standard". It came out at 111KB:
https://i.imgur.com/Gg2bAUi.jpg
I reopened the PNG and applied a radial zoom - simulating motion blur - and saved with the same JPEG settings, coming out at 62KB:
https://i.imgur.com/oqeVTtM.jpg
Imgur has re-encoded the JPGs, but the space differential is still there (in fact, it is larger). The first, unblurred image is 81KB, the second, blurred image is 38KB. Blurry images - like successive frames recording motion - are as much as half the cost to store.
Andy_Pagin
PostPosted: 13:10 - 09 Feb 2014    Post subject: Reply with quote
Thanks for the full technical explanation. I only paid twelve quid for the camcorder so I can't complain.
The last post was made 12 years, 284 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   Reply to topic    Bike Chat Forums Index -> The Geek Zone All times are GMT
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.86 - MySQL Queries: 14 - Page Size: 80.22 Kb
