found a hole....
mudcow007
PostPosted: 22:55 - 11 Feb 2014    Post subject: found a hole.... Reply with quote
so slowly putting my bandit back together, fitting my new shiny stainless bolts (replacing the coloured in rusty ones) most of the coloured in screws have ptfe on the threads?
anyways...so i put the tank back on after refitting the carbs an notice rust bubbles near where the seat rubs, so prodded bubbles with a screwdriver an it crumbles to leave a 1" hole feck!!
im guessing you cant repair it?
anyone got a tank!?
DMCpro
PostPosted: 23:56 - 11 Feb 2014    Post subject: Reply with quote
Have welded one before empty the tank let it air out for a while then fill with sand and weld it up
Honda CB-1, TS125X
VW Golf Estate
mudcow007
PostPosted: 09:39 - 12 Feb 2014    Post subject: Reply with quote
winner!
right i will ask around to see who can do it
cheers
Robby
Dirty Old Man
PostPosted: 10:04 - 12 Feb 2014    Post subject: Reply with quote
If it has rusted through in one area then the rest of it likely to be weak. You could try brazing a patch on a home if the metal is too thin to use a hobby MIG welder on.
Bear in mind that whatever you do, you'll have to do some painting afterwards.
I would replace it, Bandit tanks can't be that expensive.
As for finding PTFE on the bolt threads, it's a new one on me. Maybe someone has used stainless fittings before and the alloy thread has corroded. I would run a tap down each of the threads, and use a thin smear of copper grease on the new bolts. I also wouldn't use stainless bolts in an alloy engine.
wr6133
PostPosted: 11:13 - 12 Feb 2014    Post subject: Reply with quote
Plenty of Tanks on Ebay for around £60 with best offers taken on them so could probably get for a fair bit less. If you can find a colour match it'd be less hassle than welding the old one.
exuptoy
PostPosted: 11:33 - 12 Feb 2014    Post subject: Reply with quote
I'd never use sand!! Any missed on the clean up could fuck up his engine!
I have welded my petrol tank on my old GPZ. Swill it out with water then fill with water and leave for a few days. I recently made a log burner from an old calor gas tank, when left filled with water, empty out then offer up a naked flame at a distance (tape a match to a piece of stick or something). It'll be ok. I've also welded car petrol tanks after washing out then stood on the tank and dropped a match inside! Laughing
The only problem is when you grind back the weld it ends up being porous. Get it brazed or replace with a SH tank (probably cheaper)
Chaos, panic, destruction....my work here is done
mudcow007
PostPosted: 12:59 - 12 Feb 2014    Post subject: Reply with quote
cheers all, will have a mooch on fleabay anyone know if the 1200 tank is the same?
i wonder if the newer tank (with the sender) will fit so i can have a fuel gauge aswell
The last post was made 12 years, 50 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.29 - MySQL Queries: 14 - Page Size: 51.51 Kb
