Sachs ZX enduro
PostPosted: 12:10 - 08 Feb 2014    Post subject: Re: Sachs ZX enduro Reply with quote
Does the bike have to be 125cc?
How tall are you?
DTs really aren't that short, for the record.
Fladdem
PostPosted: 14:19 - 08 Feb 2014    Post subject: Reply with quote
From my experience dt's have soft suspension, they aren't that tall. But if you have little legs, then it may be a struggle. I'm 6'4" with a 35" inside leg so I can't speak but my mate who's about 5'6" rides an EXC125 Six Days fine. And my other mate who's shorter than me can ride my 250 fine. I reckon you'd be able to live with it, just use your head when putting a leg down. Smile
P.
PostPosted: 14:27 - 08 Feb 2014    Post subject: Re: Sachs ZX enduro Reply with quote
MC wrote:
I'm tippy toes on my XR I assume they're too big.
Tut Tut
Lean off more. My TTR600 was TALL and I slide a cheek off to reach the floor. Laughing
P.
PostPosted: 14:43 - 08 Feb 2014    Post subject: Reply with quote
Get a lighter bike Wink
Or eat more pizza.
PostPosted: 14:46 - 08 Feb 2014    Post subject: Re: Sachs ZX enduro Reply with quote
I've got a couple of inches on you but I tend to wear 30" trousers too.
Probably got a few lbs more.
You should be fine on a 'proper' enduro bike - shift yourself over a bit when you come to a stop. While the seat is high, the suspension is soft.
The bloke I got my KTM300 from was shorter than you and had a shorter shock on it - you can lower the forks a little too.
If you're not looking to use it for a road bike, I'd wait until you pass your test and get a proper enduro bike. There was a road reged KTM for under a grand I saw recently. So, so much more bike than a DT engined road bike.
PostPosted: 22:46 - 08 Feb 2014    Post subject: Re: Sachs ZX enduro Reply with quote
Oops, I actually meant off-road.
Do you plan to use it off road at all?
I've seen XR400s with both sets of wheels go for £1400 or so in the UK.
A good for years ago I got a DR600 supermoto for £635, got a DR600 with normal wheels for £600. Similar weight to the DRZ, a tad more power and a bit flatter delivery with a bit more low down/midrange.
Seen KLX650s up for around a grand.
KLX300 worth considering too.
PostPosted: 22:26 - 09 Feb 2014    Post subject: Re: Sachs ZX enduro Reply with quote
XR400 is kickstart only.
KLX was just rebadged DRZ.
If it's just for the road, then I'd stick to supermoto - they tend to be a bit lower too, thanks to smaller tyres.
This would make an interesting choice:
https://www.ebay.co.uk/itm/251425274475
It's kick start only and a competition bike. But the WR400 was known for it's reliability - steel rather than titanium valves which the later bikes had and it's not quite as light as the KTMs and Husabergs etc.
I'd stick to passing your test (even if you don't first time), but if you do decide you want a not-tall 125, I could possibly be tempted to part with my NS125 engined 50cc Supermoto - it's a chunk shorter than a 'normal' one as well as being a bit lighter. Slowly getting it MOTable as it still needs a few bits (like an air filter that actually fits.)
But a bigger engine makes more sense for most things.
PostPosted: 18:05 - 10 Feb 2014    Post subject: Reply with quote
Depends on the bike very much.
On the 2 strokes it's not a problem unless you're a complete wuss Smile.
4 strokes can be more of an issue - but it's generally a question of the bike being set up properly.
I ended up selling my FE501 partly because I couldn't get it sorted to start nicely on the road legal exhaust (needed for enduros). Once spent a continual half hour failing to kick start, gave up and rode a friend's bike.
Is this going to be just for fun, an 'only' bike, used for commuting?
The bike might be a reiju? Sine similar make.
PostPosted: 19:07 - 10 Feb 2014    Post subject: Reply with quote
Which CCM has a 50 mile range?
60 miles commuting cuts out a competition bike as a decent option.
I'd be thinking DRZ400 personally (incidentally, the CCM404 uses the DRZ engine, but with better spec kit.)
PostPosted: 20:46 - 10 Feb 2014    Post subject: Reply with quote
Most of the CCMs are mediocre at best.
I would put the XG650 firmly in the 'commutermoto' category. It's heavy and slow.
But that doesn't mean it's a bad road bike for your needs.
The last post was made 11 years, 244 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.43 - MySQL Queries: 13 - Page Size: 116.23 Kb
