Rebuilt my Yamaha Blue Spot Calipers
Yamahardon
PostPosted: 19:46 - 15 Feb 2014    Post subject: Rebuilt my Yamaha Blue Spot Calipers Reply with quote
Didnt take before pics, but they were stripped due to sticky pistons. 1 locked. They were generally cruddy so were striped, cleaned, poished, cleaned again then re assembled.
Lots of pics below:
https://s27.postimg.org/n4qgv8ob3/P1030204.jpg https://s27.postimg.org/r9ws3ewpb/P1030205.jpg https://s27.postimg.org/fnh9g0yrz/P1030207.jpg https://s27.postimg.org/k83fuyihb/P1030208.jpg
https://s27.postimg.org/3pth7cz67/P1030209.jpg https://s27.postimg.org/4k6u1ws9b/P1030210.jpg https://s27.postimg.org/6xtd6nw27/P1030212.jpg https://s27.postimg.org/lv6fleyof/P1030213.jpg
https://s27.postimg.org/w8y2n64nj/P1030214.jpg https://s27.postimg.org/7eekt3jtb/P1030215.jpg https://s27.postimg.org/ob88z9gr3/P1030216.jpg https://s27.postimg.org/6az1uvojz/P1030217.jpg
https://s27.postimg.org/mpxkl6vwv/P1030218.jpg https://s27.postimg.org/pzbzrnk0f/P1030219.jpg https://s27.postimg.org/jzo8nzz7z/P1030221.jpg https://s27.postimg.org/43zekp8nj/P1030223.jpg
https://s27.postimg.org/ibp39clcf/P1030224.jpg https://s27.postimg.org/kwunwvaq7/P1030226.jpg
Did I go full retard with the copper slip?
unsure if im keeping the red caps yet, goes with the bike but doesnt look good off it lol.
workboots
PostPosted: 22:08 - 15 Feb 2014    Post subject: Re: Rebuilt my Yamaha Blue Spot Calipers Reply with quote
Yes, looks like its on the edge of friction material!
PostPosted: 01:05 - 16 Feb 2014    Post subject: Reply with quote
You can't beat the proper stuff.
No overspray. Wink
This will last years.
https://i104.photobucket.com/albums/m174/howlingterror_2006/DSCF1813_zps42dfa786.jpg
Fizzer Thou
PostPosted: 14:09 - 17 Feb 2014    Post subject: Reply with quote
These are not my blue spot calipers but a customers
https://i666.photobucket.com/albums/vv23/WiNot_Rhencullen/Workshop/Picture383.jpg
But after a good clean they all looked good
https://i666.photobucket.com/albums/vv23/WiNot_Rhencullen/Workshop/Picture384.jpg
As to how much copper grease to use,it would be best to clean off the excess as that will soon get onto the friction surfaces and compromise the stopping ability Confused
Always have a 'Plan B'
Souleh
PostPosted: 14:52 - 17 Feb 2014    Post subject: Reply with quote
By eck, what did you clean the pistons with OP? Came up amazingly shiney.
Blue spots can get a very hard life (These of a FZ6N)
https://souleh.co.uk/G2/var/resizes/Random/20120526_153624.jpg?m=1350856643
Yamahardon
PostPosted: 19:14 - 17 Feb 2014    Post subject: Reply with quote
Yeah in hindsight I did go a bit mad with the grease.
I had been watching this video the night before i went to pick up my parts: https://www.youtube.com/watch?v=tUyGTvLDrt4
and thought I'd give it a go with the aerosol.
I think ill be removing the pads, springs and pins and cleaning them again, then applying a sensible amount of slip to the back of the pads.
Fizzer thou, did you re use the seals? £134.10 yamaha charged me for new ones, i was gutted!
souleh, I used around 4 500ml tins of carb cleaner, i prefer that as it seems to cut through the grime better than normal brake cleaner. Lots of compressed air, many tooth brushes and lots of autosol were used too.
J4mes
PostPosted: 19:20 - 17 Feb 2014    Post subject: Reply with quote
How did you get the jammed piston out? I have to do mine shortly as I have one jammed in!
Won't be paying £135 for the bits either!! Shocked
Yamahardon
PostPosted: 20:10 - 17 Feb 2014    Post subject: Reply with quote
Blue spots james?
Really the only logical way for me was to use compressed air since I have it. block the gap on between the small pistons and pop out the larger ones first, then you can aim the air down the connecting hole between the pistons to get the smaller ones out.
HTH.
J4mes
PostPosted: 20:24 - 17 Feb 2014    Post subject: Reply with quote
Yeh Blue Spots.
Looks like a good reason to justify buying a compressor to the wife! Thumbs Up
stevo as b4
PostPosted: 21:05 - 17 Feb 2014    Post subject: Reply with quote
so you can get the pistons out without winding out the blue plugs on them?
If so I have learn something today, as I thought that you needed a special socket to remove the pistons on these brakes.
Fizzer Thou
PostPosted: 23:31 - 17 Feb 2014    Post subject: Reply with quote
According to www.exup1000.co.uk you can remove the blue/gold/silver anodised plugs but the seals are not available from looking at the R1 parts fiche.
But looking at the XJR1200 parts fiche (I think it is that bike Question ) then the seals are available.
OP.If you still have the old rear seals,may I have them please??
And yes I did reuse the old seals in the caliper rebuild shown above.The bike had only done 30k miles and were perfectly reuseable.
drbaig
PostPosted: 03:53 - 18 Feb 2014    Post subject: Reply with quote
I did mine recently on the thundercat as they were a bloody mess. Binding really bad, I had an awful turning circle.
To get the jammed piston out I clamped the opposite piston with a monkey pliers wrench thingy and jammed a piece of wood between the other two. Then put a bicycle pump with a conical fitment into the banjo hole (I have a good bike pump, I cycle a lot). Pump a few times and it pops the non clamped piston out. I couldn't be bothered making compressor noise at 2 in the morning.
Then you clean them one by one by using cotton, brake cleaner, dental pick, toothbrushes. etc etc. choose your weapon.
Once clean put the new seals in and repeat the procedure. It took me half an hour to clean each piston. Nightmare I tell you.
I honestly have to say I was surprised to see how clean OP's table is. Mine was a mess with brake fluid everywhere. Fork seals and caliper rebuilds are something i do not like doing because of the mess.
yzf 600r Very Happy
Yamahardon
PostPosted: 23:24 - 18 Feb 2014    Post subject: Reply with quote
Fizzer have you got a link to this about the plug seals?
Captain obvious alert but you do know the rear blue spot I've got is the XJR1300/FZS1000 one not the R1 one, don't know if the seals differ but just thought I'd point that out. If u still want them send me a pm.
Did all the shit bit at work then brought it all home when it was clean, She'd kill me if I did all the mess on the breakfast bar Laughing
Yamahardon
PostPosted: 21:55 - 24 Feb 2014    Post subject: Reply with quote
Pads pins and clips removed de greased then re assembled with a sensible amount of slip on the back of the pads. Aerosol copper grease to the back of the cupboard.
Stoppies for fun now
The last post was made 12 years, 189 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.24 - MySQL Queries: 16 - Page Size: 94.87 Kb
