| G |
 G The Voice of Reason
| Irezumi aka Reuben |
 Irezumi aka Reuben Carrot Top
| bamt |
 bamt World Chat Champion
 Posted: 19:19 - 29 Mar 2014 Post subject: |
I normally use SRAM or KMC chains, avoiding Shimano solely because Shimano 9 speed close with a single use pin, and if you take the chain off you need to get another of those pins.
(If you don't already know, 9 speed chain rivets are peened over, so you can't safely push them out and back in again with a chain tool like you can on single speed and 5 speed chains).
SRAM and KMC have a powerlink connector that can be opened and closed repeatedly - so you can easily remove the chain without tools and replace it, which is useful for general maintenance tasks. I also carry a couple of spare powerlinks in my toolbag on the bike, which means I can easily fix a broken chain at the roadside.
My choice between SRAM and KMC tends to be dependent upon which is on offer at the time; I do high mileage and haven't seen a big difference between them.
SRAM PC951 for £8.49 delivered is probably what I'd buy at the moment. |
| G |
| KLR600 |
 KLR600 World Chat Champion
| G |
 Posted: 00:41 - 30 Mar 2014 Post subject: |
When I put a +10 on the back of my CRM125 I actually had three separate chains in one for a while. Got a feeling there may have been a mixture of O ring and not, too - extracted and revitted with a Whale tool, which I'm not sure you're meant to do either .
However, I'd prefer not to be stranded right now, so new chain on Monday.
Is it possible to 'cleanly' remove chain links on the existing chain (doesn't seem to be a join) or should I just cut it at the bent link? |
| bamt |
| G |
The last post was made 12 years, 163 days ago. Instead of replying here, would creating a new thread be more useful? |
