Permanent charger cables and cigarette sockets.
t121anf
PostPosted: 22:26 - 05 Mar 2014    Post subject: Permanent charger cables and cigarette sockets. Reply with quote
At the moment my bike a cigarette socket wired direct to the battery with an inline fuse. It constantly on, not linked to the ignition, this is how I want it.
Over winter I use my battery charger in "optimate" mode to keep the battery ok.
To use the charger it's a seat off, connect to the battery afair.
This annoys me because
1. I have to remove the seat
2. The crocodile clip type connectors stick straight up so I am loathed to put my cover on for fire reasons (it's a glorified cloth sheet)
I have a set of broken heated grips that have nice connectors on them, like those used on optimates.
If I was to hardware one of these connectors to the battery, and then create 2 leads, 1 for the charger and 1 attached to the cigarette socket. Where would I fit the inline fuse? Would I need one?
bikersupermot...
PostPosted: 22:30 - 05 Mar 2014    Post subject: Reply with quote
you should fit an inline fuse to both leads. it wont do any harm and might save a piece of equipment if something develops a fault sometime.
tinybikes
t121anf
PostPosted: 22:34 - 05 Mar 2014    Post subject: Reply with quote
So as close to the the connector on the leads going to the socket and charger?
For reference these are the connectors
https://www.maplin.co.uk/p/race-pack-lead-male-battery-connector-jg04e
davebike
PostPosted: 08:05 - 06 Mar 2014    Post subject: Reply with quote
If the heated grips were wired to the Battery not switched 12v fine
Otherwise you need to connect the Bike side connector to the battery this should/must be fused
The lead from the charger doesn't need a fuse
dave
Dave
NC750Xdct + others at work !
[email protected]
The last post was made 12 years, 259 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.23 - MySQL Queries: 14 - Page Size: 39.98 Kb
