Suzuki Gs125 1984 Indicator fault
jaz9000
PostPosted: 12:58 - 31 Jan 2014    Post subject: Suzuki Gs125 1984 Indicator fault Reply with quote
Okay so I’ve had this on the road for about a month now but due to the nature of the fault I have only just noticed it. My indicators will only work if I have my main beam on, and will sometimes work if I have my sidelights on. This is annoying because I have to ride with my head light on all the time. Also I have noticed that the idle drops a lot when I turn my lights on, if I don’t have the idle set to around 2000 when I turn my lights on the bike will cut out. The indicator relay is good, it’s got a new spark plug, battery and the charging voltage is spot on under load and when not under load. So what’s the crack? Any advice would be appreciated.
The Artist
PostPosted: 17:31 - 31 Jan 2014    Post subject: Reply with quote
IIRC 1984 has no starter motor so the battery is small, 4Ah or something.
Have a look at the wiring. May have been modified by someone. If it looks like someone has hacked away at it to change it, you might want someone good with electrics to help you.
Could be your reg/rec fried and doing something weird, loading up the engine but not charging the battery properly. What is voltage with bike off and when charging?
jaz9000
PostPosted: 21:28 - 02 Feb 2014    Post subject: Reply with quote
The voltage when not running is 12.5v and when at idle about 13.5 when the lights are on. On a side note I know this probably would not make a difference but my Gs does have a starter motor. I did a bit of testing today and the relay is getting power when the lights are off and the engine running, but the indicators do not work.
Some people say im a bit crazy... i dont disagree:)
jaz9000
PostPosted: 12:52 - 07 Mar 2014    Post subject: Reply with quote
So its been a while since ive tried sorting this but the other day i replaced the rectifier and it did have an effect and now i have a new problem. Now my indicators will work with the lights off but i have to tap my brake first. When i say tap i mean i only have to apply the brakes for a split second then i can let go and the indicators will stay on until i disengage them. This is becoming extremely annoying. From what i can see on the haynes wiring diagram the brake switches, light switch, indicator switch are all connected which looks like a common line, which i know is energised all the time so the fault is either between the negative side of the relay and the switch or god knows... Brick Wall
Any Ideas?
The last post was made 12 years, 259 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.35 - MySQL Queries: 14 - Page Size: 40.04 Kb
