CG125 question. Frame no
Tamsin
PostPosted: 23:59 - 18 Mar 2014    Post subject: CG125 question. Frame no Reply with quote
Seeing that the GC125 is a common introductory bike, just a silly question for when I go and pick mine up...
where is the frame number stamped? Just so I can check the v5 against it.
its 2001 if that makes any odds
I'm assuming its going to be the front part of the frame, where the forks go through?
davebike
PostPosted: 08:29 - 19 Mar 2014    Post subject: Reply with quote
Stamped on Headstock
May / should have a vin plate possibly on front down tube or again on head stock
Dave
Dave
NC750Xdct + others at work !
[email protected]
Fizzer Thou
PostPosted: 10:27 - 19 Mar 2014    Post subject: Reply with quote
https://i976.photobucket.com/albums/ae246/Sixth_Gear/Bikes1/2001HondaCG125.jpg
Just behind the headlight is the headstock that the front forks pivot should be the number.If it looks as though it has been altered,then walk away.
If you can buy a Haynes manual this will answer many questions
https://i928.photobucket.com/albums/ad122/DrMairax/DSCF1313.jpg
https://www.amazon.co.uk/s/?ie=UTF8&keywords=cg125+manual&tag=googhydr-21&index=aps&hvadid=38885813274&hvpos=1t1&hvexid=&hvnetw=s&hvrand=12059443759353698913&hvpone=&hvptwo=&hvqmt=b&hvdev=c&ref=pd_sl_6xcche5q6n_b
Always have a 'Plan B'
Tamsin
PostPosted: 23:24 - 19 Mar 2014    Post subject: Reply with quote
Got the haynes on order Fizzer Cool
The last post was made 12 years, 210 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.19 - MySQL Queries: 14 - Page Size: 39.73 Kb
