Moto Guzzi Strada R.I.P. ?
noobRider
PostPosted: 21:12 - 12 Mar 2014    Post subject: Moto Guzzi Strada R.I.P. ? Reply with quote
Setting out this morning for Oxford from Somerset, just got onto the A303 and I opened it up and I heard a small "knocking" noise and felt a small vibe, especially when throttling off. Stopped to have a look and couldn't see anything but thought I'd better abandon going to Oxford and gently head back home. Got to about 5 miles from home and suddenly BANG, the rear wheel jumped, and I was left free-wheeling down a long hill. Engine sounded fine but no drive.
At the bottom of the hill:
https://i.imgur.com/Vb3eWBU.jpg
There's a huge hole between the gearbox and the shaft drive.
https://i.imgur.com/R0izK4i.jpg
The universal joint on the drive shaft has exploded it's way through the casing. I've got it to my local bike shop to see how much to fix it. This might be the end of the old girl. It was turning into such a beautiful day too Sad
Licence: Nov 2012, Bikes: Suzuki GN125, Moto Guzzi Strada 750, Triumph Sprint ST 955i x 2
AnPhonEh: I need plans, I need contingency plans also, I need back up contingency plans
Shaft
PostPosted: 00:55 - 13 Mar 2014    Post subject: Reply with quote
Is that a smashed main casing, or just an extension housing?
From what I can gather, UJ failure isn't uncommon, so it's a fair bet that parts are stockpiled by specialists.
The rest of the bike looks too good to scrap, even if it means sourcing a complete used motor.
PostPosted: 01:06 - 13 Mar 2014    Post subject: Reply with quote
Are they down as a service item (they were on some Guzzis in some markets - remember reading an article complaining about the cost of this service item every 16000km or so in an Aus magazine).
Shaft
PostPosted: 01:21 - 13 Mar 2014    Post subject: Reply with quote
*Additional* I should stress, it's a very long time since I last looked at one of these, but I think the UJ is in a bolt on housing that isn't part of the main engine case.
The give away is the join and socket head bolt I've highlighted
https://i1235.photobucket.com/albums/ff426/zedheadchap/R0izK4i.jpg
Could be a bit of labour time involved, but you might be lucky with parts costs, if secondhand parts can be had.
PostPosted: 01:38 - 13 Mar 2014    Post subject: Reply with quote
Looking round I found an online parts list of a (I think) similar engine.
https://www.harpermoto.com/parts-by-motorcycle/1990-2000-moto-guzzi-motorcycles/v-75-pa-nuovo-tipo-750-1996-2001/transmission-cage-en-v75-nuovo.html
Looks like it is a rear casing on the gearbox.
hmmmnz
PostPosted: 08:07 - 13 Mar 2014    Post subject: Reply with quote
its much like the modern bmws the shaft drive uni's have to be replaced periodically, because of them snapping or wearing,
the older ones didnt because they are submerged in oil,
you'll need a new arm and atleast the universal joint,
not the end of a bike by any means, but, could be expensive
the humans are dead
I kick arse for the lord
noobRider
PostPosted: 08:42 - 13 Mar 2014    Post subject: Reply with quote
It looked pretty bad at first but it is a bolt on casing for the UJ. I couldn't see if there was damage further up inside. I'm hoping it won't need a new arm but it probably will. It does look costly.
Thanks for the link Kickstart.
_mjs_
PostPosted: 23:51 - 13 Mar 2014    Post subject: Reply with quote
Best of luck with it, that's a nice looking machine you have Thumbs Up
noobRider
PostPosted: 22:41 - 21 Mar 2014    Post subject: Reply with quote
So far it's looking like:
Replacement swing arm (a whole chunk was blasted out the bottom)
New U/J
New cover
Replacement drive arm & housing
Hopefully the drive from the gearbox is ok
£600 in parts alone, some of them used, to fix a 20 year old bike Sad
Shaft
PostPosted: 23:51 - 21 Mar 2014    Post subject: Reply with quote
Forget about the age of the bike, it's more to do with how much you like it, the overall condition and how much you would have to spend on a worthwhile replacement.
If the rest of the bike is solid, you now know about a major weak point and what to do about stopping it from happening again, so you shouldn't encounter that problem in the future.
I remember reading your thread from when you bought it and you clearly like it, you also know you aren't going to find another one in a hurry, so what's the alternative and how much do you think it would cost to find a bike that isn't likely to give you another big bill?
From a practical point of view, it might make sense to go with a 'better the devil you know' approach, plus if you don't fix it, it's worth the sum of eff all, so you've done everything you've ever spent on it.
Being a nostalgia freak, I would also be swayed by the rarity value, there's nothing like pulling up at a meet, knowing you aren't likely to see another one.
PostPosted: 23:53 - 21 Mar 2014    Post subject: Reply with quote
When you fix it can you put a gaiter over the UJ somehow to protect it?
Shaft
PostPosted: 23:56 - 21 Mar 2014    Post subject: Reply with quote
I'm pretty sure they already have one, the issue seems to be one of out of sight, out of mind.
Regular greasing should be on the service schedule, but I think it's something that's often overlooked, much like changing the oil in the bevel box.
PostPosted: 00:04 - 22 Mar 2014    Post subject: Reply with quote
Think the service schedule says to replace the UJ fairly regularly (although probably largely butt covering on the part of Moto Guzzi).
noobRider
PostPosted: 00:26 - 22 Mar 2014    Post subject: Reply with quote
It's got a rubber gaiter surrounding it: one of the things that needs replacing. I had been thinking of getting something smoother, with more power, better protection and luggage, but it has grown on me so I think I'm going to have to fix it. I don't think I'll ever see another one in the flesh.
trevor saxe-coburg-gotha
PostPosted: 05:47 - 22 Mar 2014    Post subject: Reply with quote
OT I know, but what's that really rusty bit?? Corrosion's definitely got its teeth into that by the looks.
331X2
PostPosted: 08:50 - 22 Mar 2014    Post subject: Reply with quote
What's the cost of the parts individually if you don't mind me asking? Any chance the UJ is of standard dimensions that you could pick up from an engineering supplier?
I'm assuming the bulk of the cost is the second hand casings?
noobRider
PostPosted: 10:41 - 22 Mar 2014    Post subject: Reply with quote
Parts are hard to come by. Roughly:
Used swing arm (prob from a Nevada) £150
New UJ: £200
Used drive arm & housing: £250
I don't know if a standard UJ would do it.
The rust I hadn't noticed until I took the close-up pic. It's not as bad as it looks I think. I'll have a closer look.
331X2
PostPosted: 15:17 - 22 Mar 2014    Post subject: Reply with quote
This thread on another forum makes reference to the UJ's possibly being a standard part, the bloke is based in NZ but it might be worth a little more investigation.
Are you planing on getting it stripped any time soon? You need to fix it, it's too pretty to die Crying or Very sad
stevo as b4
PostPosted: 17:31 - 22 Mar 2014    Post subject: Reply with quote
Agreed! She might be 20years old, but it's still a very good looking bike, and it must be put back on the road, even if you have to wait a while to afford it/sort out spares.
It's in very good condition, much better than many 5year old daily ridden machines!
PostPosted: 18:35 - 22 Mar 2014    Post subject: Reply with quote
In agreement with Shaft re the age/rarity of it and fixing it will probably keep you from buying another generic bike Wink
Although, £600 will buy you a dog of a bike rather than fixing your old girl, but I'm sure you know what one you want Wink
Teflon-Mike
tl;dr
PostPosted: 13:05 - 26 Mar 2014    Post subject: Reply with quote
20 years old is young for a Guzzi.
Personally, little doubt, even at £600 initial estimate, with the 'double the time, double the money and add a bit when you start lifting spanners to it' expectation of the reality, I'd still be trying to sort it myself, if it were mine... which it wouldn't be... braunstonite I share bed with would have nickedit... though undoubtedly I'd still be the one trying to fix it!
On which topic... I REALLY think you ought to fix it up yourself.
You bought it. You broke it. Its your duty to put the old girl back in order. Remember, you don't 'own' an Italian motorcycle, you merely have the privilege of paying for their upkeep!
And besides; Snowie is still looking for a Small-block Guzzi 'Project'... or in other words, more scrap to keep me up to my armpits in EP90!
And if you advertise it 'spares or repairs' she WILL find it! And I wont hear the last of it! She actually went and had a look at a V65C last week, and I was dreading what she might bring home! Three years, now, she's been looking, and she's almost as desperate for a lost cause, as I am to keep finding new reasons not to give one house-space!
However, if its any help; you MIGHT be able to get the arm and housing rebuilt with ali weld. Been a few years, but when we had the V35; 3&1/3 and 350SS in the 'fleet'; I was introduced to a bloke that had similar perversion for Wops and was an master of molten metal; had to take him one of the pistons for the Morini, which he crafted a new dished crown for, ISTR, but seem to remember he did cases and arms and well, pretty much anything that was hard to get and other wise nie on beyond economical replacement. Curiousely, my uncle discovered him after smashing up a microlite and having to get spars repaired; fixing light aircraft was his 'main' business; which might be a lead to follow up to find similar specialist.
Irezumi aka Reuben
Carrot Top
PostPosted: 01:19 - 27 Mar 2014    Post subject: Reply with quote
Dont normally pos in here but that bike looks far too good and interesting to get rid of! Fix it. Very Happy
Pictorgraphicalfantastical
anthony_r6
PostPosted: 18:38 - 29 Mar 2014    Post subject: Reply with quote
_Iain_ wrote:
What? Shocked
Mike, have you properly lost the plot recently? I've read the entire post twice and I'm still not sure how we got from a Guzzi driveshaft to making pistons & finished on microlights.
Theres a site called Gutsibits or simmilar. Have a word with them - they're very good at sourcing pretty much anything Guzzi & deal in used parts too.
Makes sense to me. He met someone who makes shit out of metal when sourcing a replacement part was too expensive. The guy makes pieces for microlights, that is his main business, but did some other metal-works on the side.
noobRider
PostPosted: 19:40 - 29 Mar 2014    Post subject: Reply with quote
Teflon-Mike is right. I do feel responsible for her and she deserves to be on the road. I've had parts from Gutsibits before and that's where these quotes came from. I'm probably going to get her fixed up, although I've got negative money right now.
If Snowie is desperate for a small Guzzi I might pass her on. I have been thinking about getting something with a bit more oomph.
The last post was made 12 years, 187 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.18 Sec - Server Load: 1.47 - MySQL Queries: 13 - Page Size: 140.47 Kb
