peugeot speedfight 2 non start
jon daniels
PostPosted: 16:39 - 21 Mar 2014    Post subject: peugeot speedfight 2 non start Reply with quote
Hi all and thanks for looking
Right ill give as much info as possible
I have just bought a speedfight 50 2004 which i believe is air cooled due to the apparent lack of water resorvoir.
It did run as it went to the garage and had mot etc , it then sat for a few months and did nothing and the battery discharged itself and wont recharge ( pron dropped cells as stood for so long )
Right, new battery purchased and charged with plenty of just , now when i turn on the ignition i get no dash lights not even the immobilser light ( it doesnt flash etc )
no lights at all , indicators wotks as do the horn , no headlights and nothing happens when you click the electric start.
I have no power going to the started switch either but voltage coming from ignition key and into cdi black wire which goes off with ignition.
I have only the black key and yes mine has the imobilser ring on the ignition however I thought if an imobilsor problem i would get the flashing light on the dash ?
( if I had known about the lack of red key I would have walked away ) but stuck now and would make an interesting project if i can get it started.
More than happy to replace the cdi with a bypass unit if this may be the problem just unsure with the lack of power/lights etc.
the cdi is an aci100
any help appreciated in advance
jon
The last post was made 12 years, 198 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.55 - MySQL Queries: 14 - Page Size: 27.91 Kb
