Whoever decided it would be a bright idea to buy a CBF ...
Screw Loose
PostPosted: 13:47 - 19 Mar 2014    Post subject: Whoever decided it would be a bright idea to buy a CBF ... Reply with quote
Hit a problem today,
the faster I ride the faster my indicators flash.
I.e. at idle: flash ............ flash ............ flash ............
At 30mph flash .... flash .... flash .... flash ....
at 70mph flash. flash. flash. flash
even at 30 it goes ridiculously fast.
How in the holy hell do I fix this, dont have a clue about electrics ...
MBK Nitro 50cc -> CBF 125 <\s>
CBT: February 2012 - Full licence August 2013
davebike
PostPosted: 13:52 - 19 Mar 2014    Post subject: Reply with quote
Indicator relay is the probable fault
Clipped to the inside of the left hand "tank fairing" in front of the tank
Dave
Dave
NC750Xdct + others at work !
[email protected]
PostPosted: 14:08 - 19 Mar 2014    Post subject: Reply with quote
Think. Why would the relay be acting differently at different road (i.e. engine) speeds?
Because it's getting a different voltage.
So the regulator isn't regulating.
It is a Honda, after all.
Verify with a multi-meter, replace if necessary. Expect blown bulbs and or fuses and a cooked battery if you continue to ride it.
Islander
PostPosted: 14:10 - 19 Mar 2014    Post subject: Reply with quote
I'd be measuring your charging voltage at the battery terminals. It should be around 14v @ 3-4000 rpm.
smegballs
PostPosted: 14:53 - 19 Mar 2014    Post subject: Reply with quote
I imagine you are right. I also despair at the thought of fitting bi-metallic strip indie relays as OE in this day and age.
misscrabstick
PostPosted: 14:59 - 19 Mar 2014    Post subject: Reply with quote
Voltage regulator has gone crazy I think, leave it and you may boil your battery and blow bulbs and damage electricals, get it checked asap.
PostPosted: 16:13 - 19 Mar 2014    Post subject: Reply with quote
ECHO
Echo
Echo
echo
echo
echo
mikesaa309
PostPosted: 17:05 - 19 Mar 2014    Post subject: Reply with quote
This is due to the indicator relay/flasher unit whatever you want to call it.
Had this issue with mine, my original one went missing not sure if it just fell off or if some sad ass wipe decided to pinch it at college as it's easily accessible from inside of the front left fairing. Brought some cheap shit one for 3 quid and whenever I was going fast the indicators would flash like fuck then would slow down the flash rate as I slowed down.
Brought a still cheap but slightly more expensive one for 7 quid and it's perfectly fine.
And just to clarify the original one is perfectly fine. If you brought the bike second hand then maybe the owner brought the cheap shit one which for me was a cylindrical one. The one I have now is rectangular. I know shape doesn't make a difference but just saying if it's a cylindrical one then it's most likely the cheap shit one I had on it.
PostPosted: 20:36 - 19 Mar 2014    Post subject: Reply with quote
Fair enough, your relay was probably picking up extra energy from crossing lay lines.
janner_10
PostPosted: 21:05 - 19 Mar 2014    Post subject: Reply with quote
Why? Tried, tested & cheap.
smegballs
PostPosted: 16:14 - 20 Mar 2014    Post subject: Reply with quote
Dat current (therefore voltage and load) dependant flash-rate.
panrider_uk
PostPosted: 16:43 - 20 Mar 2014    Post subject: Reply with quote
Tsk.
PostPosted: 17:35 - 20 Mar 2014    Post subject: Reply with quote
But it lets you know that your regulator is hosed, if you've got the wit to apply ten seconds of reasoning rather than throwing a fancy electronic relay at it and riding in happy ignorance.
Islander
PostPosted: 17:39 - 20 Mar 2014    Post subject: Reply with quote
You and your high expectations, eh? Rolling Eyes Razz
bamt
PostPosted: 19:28 - 20 Mar 2014    Post subject: Reply with quote
But it lets you know that your regulator is hosed, if you've got the wit to apply ten seconds of reasoning rather than throwing a fancy electronic relay at it and riding in happy ignorance.[/quote]
It also lets you know that a bulb is blown. Obviously we all check the rear indicators before every ride and at every fuel stop on a long ride, don't we?
The last post was made 12 years, 210 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 1 - MySQL Queries: 14 - Page Size: 88.16 Kb
