Mod 1 training day - U Turn woes - Updated with Mod 1 result
ipip
PostPosted: 16:04 - 30 Mar 2014    Post subject: Mod 1 training day - U Turn woes - Updated with Mod 1 result Reply with quote
Did a 1 day big bike conversion/mod 1 training today. Not too bad, a couple of clipped cones, a couple of attempts to beat the speed trap and the road riding was generally all good.
But, the u-turn is my enemy Evil or Very Mad
I either go far too wide, just not applying enough turn, or lean into the turn and (almost) drop the bike, occasionally saving it with a quick dab of the foot. 1 in 10 it's fine and on the dummy, end to end test, I just made it. However, that's not enough for me to be confident.
I think I know what's wrong, I just can't seem to put it right.
Any tips?
ipip
PostPosted: 16:07 - 30 Mar 2014    Post subject: Reply with quote
Spent the day on one of these by the way
BrownTrousers
PostPosted: 16:08 - 30 Mar 2014    Post subject: Reply with quote
Plenty of revs and keep turning your head to look as far back up behind you as possible (in the direction you want to be going) the bike will follow.
Bikers make great organ donors - add your name to the register
Ducati Multistrada 950 | Triumph Tiger 800 XR | Honda CBR500R | Yamaha YBR 125 Custom
lihp
PostPosted: 16:10 - 30 Mar 2014    Post subject: Reply with quote
More practice and training required.
Unfortunately, no amount of reading about it will help, the only thing that will help is getting out there and practicing it.
esullivan
PostPosted: 16:27 - 30 Mar 2014    Post subject: Reply with quote
Plenty of revs. Control your speed by slipping the clutch and using the back brake. The u-turn is a test of your ability to balance those three (revs, brakes and clutch) while looking where you are going.
You will do this manoeuvre almost every day when out on your own, such as when pulling out of parking space or making a sharp right or left. Once you pass your test, no one's going to care if you dab a foot down. It's a perfectly reasonable thing to do. But not while on test.
I failed my first mod 1 on the u-turn (dabbed my foot). On my second, successful attempt, I relied a little too much on the back brake and juddered around the u-turn. Buy, hey, it worked.
I still dab my foot once in a while.
Current: '14 VFR800X Test passed 31/10/12.
Previous: '12 NC700S, '11 CBF 125, '04 SH 125.
PostPosted: 16:32 - 30 Mar 2014    Post subject: Reply with quote
Going too wide is not turning your head 9 times out of 10. Turn that head.
Too much lean, counter it by leaning the other way or even turning your body a little to put your weight on the far side. Takes practice.
The most part is slow control with the clutch, you are working with millimeters of clutch and if you find yourself going a little heavy a tiny dab of the brake.
Or as the boss says.
Just get on with it!
(wont show you what I was riding around on for a bit today but there is a thread going up on it.)
trevor saxe-coburg-gotha
What BrownTrousers said - 90% of it is where you're looking. You've got to look where you want to go, not where you're going. Not down the end of your nose, at the ground, or a few feet ahead of the front wheel. Your head's go to be up, and almost swivelling ahead of where the bike's turning, anticipating the completed manoeuvre.
ipip
PostPosted: 17:01 - 30 Mar 2014    Post subject: Reply with quote
All wise words I know and I do have a habit of looking down. In normal riding my clutch control is pretty good, but getting it all balanced within 7.5m is proving a challenge.
Might go and have a practice on the CBF; more lessons tomorrow.
On a different note, I was loving the stretches of open road where I could make progress without making an appointment for 60/70 Very Happy
DottyDuck
PostPosted: 17:02 - 30 Mar 2014    Post subject: Reply with quote
make sure you get a bit of speed before starting the turn. Remember to have enough revs to prevent stalling and the dropping of the bike and good clutch control. You will get it just stick with it Smile
CBT- 2012 Theory- 18/12/13 Mod 1- 07/01/14 Mod 2- 15/01/14 Very Happy
Old Bike: Zontes Panther 125cc - wrote off Sad Current Bike: Kawasaki ZR7 Very Happy Wub
i.p.phrealy
PostPosted: 18:42 - 30 Mar 2014    Post subject: Reply with quote
Keep your head up and look where you will be going after you've finished the turn, i.e don't look at the lines, look up the "road".
i had the same issue, you need to look where you will be going next and it will click.
marsden1967
PostPosted: 18:52 - 30 Mar 2014    Post subject: Reply with quote
I had my first off practicing a u turn. Someone on here (can't remember who, sorry) recommended going around in ever decreasing circles, then practice u turns after doing a few of them. It worked an absolute treat for me, so give it a go Smile
Ooooh Matron!
current bike(s) YBR 125, ER6 N
covent.gardens
World Clap Champion
PostPosted: 19:00 - 30 Mar 2014    Post subject: Reply with quote
Almost everything has been said already, the only thing I would add is make sure you're not tensing right up when you're on the bike because your nervous, you will struggle with the delicate movements required to balance if your muscles and body is all stiff with fear, relax.
noobRider
PostPosted: 19:46 - 30 Mar 2014    Post subject: Reply with quote
U turn was my nemesis too Sad Lots of good advice here.
Licence: Nov 2012, Bikes: Suzuki GN125, Moto Guzzi Strada 750, Triumph Sprint ST 955i x 2
AnPhonEh: I need plans, I need contingency plans also, I need back up contingency plans
G30
PostPosted: 20:33 - 30 Mar 2014    Post subject: Reply with quote
High revs, clutch control, look where you want to go. Always do left-to-right u-turns, well I would assume the test is always left-to-right even though you may a right-to-left u-turn on the road when no one is about then go across to the left side or just turn around in a 3 point kinda manner at the side of the road. Practice makes perfect. Go go go.
KTM RC390 -- Kawa ER6f -- Yam YZF R125 -- Yam YBR 125
yen_powell
PostPosted: 20:38 - 30 Mar 2014    Post subject: Reply with quote
Move your bum off the seat a little, opposite side to the direction you are turning.
XT1200Z and a DR350 in bits
Robster
PostPosted: 21:52 - 30 Mar 2014    Post subject: Reply with quote
Don't go mega slow, remember when the engine revs its helping hte bike stabilise - having a gyroscopic effect, so loadsa busy engine and clutch.
btw, nice bike to learn on! bit powerful no?
Rigga
PostPosted: 22:14 - 30 Mar 2014    Post subject: Reply with quote
Loads of revs and get your knee down Thumbs Up
Erm, ignore the knee down comment.
Current bike: Honda CBR 1100xx
Ribenapigeon
PostPosted: 14:34 - 31 Mar 2014    Post subject: Reply with quote
Make sure you go forwad a bit before the turn to get momentum then as others have said TURN YOUR HEAD. If in doubt as with most situations on a bike, give it some beans!just try not to doughnut it. Having said that if you can doughnut a Uee and get it on video you could probably make back the test fee by sticking it on youtube Smile
map
Mr Calendar
PostPosted: 14:45 - 31 Mar 2014    Post subject: Reply with quote
covent.gardens wrote:
Almost everything has been said already...
...as said some good advice but I'll add my Penny Coin 's worth....
I hated U-turn and only really nailed it on the morning before my test. Test passed BTW. I did a DAS course but was practising every night on the 125 around the local side roads.
As said, high revs and clutch control and rear brake. Keep throttle constant. As also said, look where you want to go. One of my mistakes was looking just in front of the (front) tyre.
Don't be afraid to actually turn the bars.
It helped me by putting my weight on the pegs. I felt more planted and the bike less likely to tip over or me just stick a foot down.
Also remember you don't have to start turning from a standstill. IMO that's guaranteed to be wobbly. You can ride forward a little and then turn (unless they've changed the goalposts/rules on that?). Just remember the lifesafer before the turn.
Best of luck Thumbs Up
j.silvs
PostPosted: 14:48 - 31 Mar 2014    Post subject: Reply with quote
a few things that I found made it easy:
1. Look where you want to go and not at the line/kerb
2. Use your hips to turn
3. If the bike feels unbalanced then it means your going too slow. Speed up bitch
HTH
Sabs
PostPosted: 16:27 - 31 Mar 2014    Post subject: Reply with quote
Looking where you are going to go is was the big point for me. I've only ever ridden in lessons, not got my own bike yet so am very inexperienced. For some reason I concentrated a lot on right in front of me but once I managed to look where I wanted to things like the U turn went a lot easier. Same for figure of 8.
My Photos
Theory in the bag, Mod 1 passed 28/3/2014, Mod 2 passed 9/4/2014 - Let loose
Kawaski ER6-f
Andy_Pagin
PostPosted: 17:05 - 31 Mar 2014    Post subject: Reply with quote
Strange choice of school bike, Fazers aren't the easiest bikes to U turn and the lack of bottom end torque doesn't help with the low speed stuff.
Matt B
PostPosted: 18:08 - 31 Mar 2014    Post subject: Reply with quote
Quite a lot of schools used them though, looks like some still do. Never as common a sight as a GS500 at the test centres but a lot of instructors liked them for DAS work.
Fazers aren't hard to U turn and low end torque has nothing to do with the type of slow speed control that you perform on Mod1. It's about keeping the revs up, slipping the clutch and dragging the rear brake.
ipip
PostPosted: 17:44 - 14 Apr 2014    Post subject: Reply with quote
The bad news? I took the Mod 1 the day after posting this and failed on putting a foot down during the U turn Sad
I also didn't make 50kph on the 2nd swerve avoidance.
The good news? Did it again today and passed with a clean sheet Very Happy
I haven't booked Mod 2 yet, but I know there's a test slot available next week...
Sabs
PostPosted: 18:42 - 14 Apr 2014    Post subject: Reply with quote
Congratulations Smile
Go for the mod 2!
My Photos
Kawaski ER6-f
The last post was made 12 years, 143 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.18 Sec - Server Load: 0.95 - MySQL Queries: 13 - Page Size: 129.26 Kb
