| retrobiker |
 retrobiker Renault 5 Driver
| Bezzer |
 Bezzer World Chat Champion
| Raffles |
 Raffles World Chat Champion
| retrobiker |
| Pete. |
 Pete. Super Spammer
 Posted: 10:08 - 30 Mar 2014 Post subject: |
If it does anything it'll just drive the threaded part into the fork leg. Shouldn't do any harm just to replace it. ____________________ a.k.a 'Geri'
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 10:13 - 30 Mar 2014 Post subject: |
Drilling steel screws out of ali is not un-do-able. Main problem is not that they will necesserily get screwed in and split the case, but that the drill will 'ride off' the screw and you will end up drilling into the case not the screw.
Trick is to flat the sheared face with flat-file to give least chance of drill flexing off center, then center punching accurately and drilling very straight, very carefully to go down the centre of the screw and not run off into the threads or alli.
Ie: leg off the bike, in a vice and done with a pillar drill, for preferance.
BUT, I'd follow Bezza's advice. I rarely bother with the drain plugs, to get the oil out. Loose the cap, drop the leg, turn it upside down to drain, then flush & fill. The real 'crud' that sediments at the bottom of the leg rarely comes out the drain plug anyway.
So if it ent a real problem - dont risk making one trying to fix it. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| gavbriggs |
 gavbriggs Crazy Courier
| retrobiker |
| G |
 G The Voice of Reason
| Raffles |
| G |
| gavbriggs |
| Islander |
 Islander World Chat Champion
| Islander |
| G |
| retrobiker |
| gavbriggs |
The last post was made 12 years, 178 days ago. Instead of replying here, would creating a new thread be more useful? |
