| kneedown |
 kneedown Nova Slayer
| misscrabstick |
 misscrabstick Crazy Courier
 Posted: 22:49 - 01 Apr 2014 Post subject: |
Here's some proper bad news for you, cam caps are line bored with the cylinder head during manufacture, they are a matched set with the head, one does not replace them on their own.
Those from another engine will not quite line up with the other half of the cam bearing surface leading to the camshaft being pinched and binding with possible subsequent overheating and seizure.
| kneedown |
| misscrabstick |
| kneedown |
| Kickstart |
 Kickstart The Oracle
| kneedown |
| Raffles |
 Raffles World Chat Champion
| kneedown |
| kneedown |
| Kickstart |
| Major Doss |
 Major Doss Traffic Copper
 Posted: 02:07 - 02 Apr 2014 Post subject: |
Is there a number stamped into the bolt head? Use that as tensile reference, but it is also more likely mild steel rather than S/S.
Why not get OEM? Peace of mind for a tenner? If it were my camshaft I were looking after, etc...
Well done for you spannering and spotting btw.  ____________________ Antisocial phucker. |
| stinkwheel |
 Posted: 09:07 - 02 Apr 2014 Post subject: |
Stainless is going to be weaker, more expensive and more brittle than mild steel.
Corrosion is not going to be an issue inside the rocker cover.
As such, there is absolutely no good reason to use stainless for that application. Mild steel is stronger, cheaper and less likely to fracture.
There is also the question of how tight you need to do them up. The torque rating specified is for that exact grade of steel bolt. You risk either over or under-stretching the bolt if you use a different grade which could result in it either snapping or working loose. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Fizzer Thou |
 Posted: 09:27 - 02 Apr 2014 Post subject: |
I used some stainless Allen bolts on my Honda 750 cam caps once.As soon as the engine started two of the heads sheared off as the tensile strength was not the same as the original bolts.
Good thing that they did not go when being red lined
https://i666.photobucket.com/albums/vv23/WiNot_Rhencullen/Honda%20750/My750014.jpg ____________________ Just talk bikes.What else is there?
Always have a 'Plan B' |
| bladerunner |
 bladerunner World Chat Champion
| kneedown |
| YBR Ric |
 YBR Ric Spanner Monkey
| Vincent |
 Vincent Banned
 Posted: 10:32 - 02 Apr 2014 Post subject: |
Using odd bolts could throw the torque settings off so you do well using the original ones.
Any chance you can post a pic of the damaged bolts? I'm a bit confused about "cracked" bolts too  ____________________ Space Is Deep |
The last post was made 12 years, 164 days ago. Instead of replying here, would creating a new thread be more useful? |
