Aprilia RS125 Idle problems
tommivercetti This post is not being displayed because it has a low rating (Flame). Unhide this post / all posts.
stirlinggaz
PostPosted: 13:59 - 29 Mar 2014    Post subject: Reply with quote
hi,
i presume your running the standard dellorto 28mm carb?
with the jim lomas exhaust i used a 128 main jet, cant remember the others though (i'll have a look back at what was best carb set up),,,
them wee carbs are very sensitive to the slightest turn of the air/mixture screw. (which is why i always ditched the 28mm for the vhsb 34mm, works a lot better on the rs, i see the 28mm carb as a restriction.)
have you looked at the obvious/usual rs probs?
try it with a NEW spark plug & dont bother with those fancy iridium plugs, just buy 3 copper ones, you wont notice any difference anyway.
try a new BR9, for now.
are you using standard airbox? (with both trumpets open)
& check all your cables, especially the choke.
theres a good carb guide in the stickies, written by resident expert. (kickstart)
so, to sum up : remove carb from bike, strip it & clean it & refit with air/mixture screw at 2 full turns out.
choke working as it should? no air leaks anywhere?
before you stick the new plug in, this is an ideal time to do a compression test. your looking for over 120psi (its handy to know what figure your starting with, for future services) its one of the 1st questions i ask a seller (i've had a few rs125's Very Happy )
fit a brand new BR9 & make sure the battery is FULLY charged. (the rs likes over 12.5v to start) & dont rely on the lcd for voltage, its notoriously unreliable. use a multi-meter.
fresh fuel?
post the results please?
cheers,
GAZ
tommivercetti
PostPosted: 14:15 - 29 Mar 2014    Post subject: Reply with quote
Yes 28mm carb
I have just put a new ngk br10eg plug in
The airbox is standard and both ports are open
The choke spring was broken so i have replaced it, it's definitely returing.
I have removed the carb countless times and cleaned it all with carb cleaner and it stays the same
The battery is brand new fully charged and reads about 12.6 in the bike (not sure about when running but the carb is off at the mo)
The fuel is fresh I just syphened it out of my comuter but even with a fresh tank of vmax it runs the same
I don't have anything to test the compression, but it ran like this before and after a the full rebuild with a brand new wiseco piston and replate of the barrel. So is this still worth checking? I'll see if i can get a compresson tester
Thanks
stirlinggaz
PostPosted: 00:48 - 30 Mar 2014    Post subject: Reply with quote
hi,
the reason i suggested a new BR9 is because its cheap, rotax recommend it & it wont foul as quick as a 10.
who done rebuild? compression should be around 150psi if top end re-built correctly.
i'd be testing this 1st.
most hard starting is caused by fouled plug,low compression or f*cked battery.
the rs is pretty fickle when it comes to the battery, if its not 100% it can cause all sorts of weird issues.
how many turns out is the air/mixture screw? (the wee screw that needs a screwdriver to turn) this VERY sensitive, so only adjust it when engine warmed up & turn it 1/4 turn at a time.
can you get it to increase idle rpm by using throttle stop screw? (the black plastic screw on side of carb body)
cheers,
GAZ
stirlinggaz
PostPosted: 15:00 - 02 Apr 2014    Post subject: Reply with quote
hi,
if its not idling correctly, have you tried putting the choke on?
& what happens when you do?
most carb problems on the rs are caused by guys messing with air/fuel screw, not realising that the smallest of adjustments can f*ck it up.
i cant remember if the 28mm carb has an air adjustment screw or a fuel mixture adjust screw.....(they both adjust in different ways)
if its near the air filter end of the bike its an air adjust screw & turning it anti-clockwise will make it run leaner.
if the screw is nearer the engine end, its a fuel mixture adjust screw & turning it anti-clockwise will richen the mixture. (iirc lol)
wind the plastic screw out a bit, it shouldnt need to be screwed all the way in.
get the engine warmed up (with the air screw set at 2 full turns out, try & get the bike to idle,regardless of rpm. once you have it idling, turn it in to increase rpm, out to lower rpm.
THEN try & set up the air screw turning 1/4 turns at a time, with a bit of faffing about, it should need choke to start & once warmed up put choke off & it should idle at 1500rpm.
now you know why most rs owners go for the 34mm cab, far easier to set up & completes the de-restriction process,
cheers,
GAZ
The last post was made 12 years, 163 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.74 - MySQL Queries: 14 - Page Size: 52.69 Kb
