What grease on caliper sliding pins?
stevo as b4
PostPosted: 18:47 - 03 Apr 2014    Post subject: What grease on caliper sliding pins? Reply with quote
On Car brakes, I've used copper grease every time on sliding calipers, but I have heard that this is not really the correct product for the application?
Would RG2 grease be better or worse? And if neither of them are suitable, then I'll use Castrol underwater grease left over from my outboard motor re-build. Laughing
Lastly does anyone have any reccomendations for those small enduro bags that strap or bolt onto the rear fender/carrier? I'm after a small bag, but something that either has straps and Velcro or popper's or just bolts through the fender instead?
CaNsA
PostPosted: 18:48 - 03 Apr 2014    Post subject: Reply with quote
I give them a dip in some copaslip.
gbrand42
PostPosted: 18:51 - 03 Apr 2014    Post subject: Reply with quote
I just used what I had lying around, some halfords high melting point grease. Seems to be ok so far. Use copper slip on the pad retaining pins threaded bit and the caliper bolts.
Yamaha RD50M, Honda C90, Yamaha RS100, Yamaha RD125LC, Honda XL125 V9 Varadero, Honda NT700VA, Honda VFR800X, Honda CRF1000L, Honda ST1300 Pan European
bugeye_bob
PostPosted: 19:48 - 03 Apr 2014    Post subject: Reply with quote
you can buy proper brake grease now, Ceratec.
https://www.ebay.co.uk/itm/like/190935863753?limghlpsr=true&hlpv=2&ops=true&viphx=1&hlpht=true&lpid=108
I use the red one but its the same difference.
_mjs_
PostPosted: 21:12 - 03 Apr 2014    Post subject: Reply with quote
Never tried it myself but I've heard silicone paste is the best thing for car brakes.
MattEMulsion
Red rubber grease or silicone lubricant should be used on caliper sliding pins, but in the real world a bit of copper slip doesn't seem to hurt. They say that copper slip reacts with the rubber and causes it to swell but I have not personally had any trouble with using it.
Yamaha YZF-R6
Islander
PostPosted: 21:38 - 03 Apr 2014    Post subject: Reply with quote
I use a silicone grease that doesn't damage the rubber boots.
Pete.
PostPosted: 06:00 - 04 Apr 2014    Post subject: Reply with quote
I use either LMP or moly-d, depending on which pot is on top of the other, or if I'm feeling extravagant then waterproof grease. It's just a lubricant between two sliding surfaces, the fact that it's near some braking components doesn't mean you need red rubber grease or that ceratec anti-squeal stuff. They have specific applications net required here.
a.k.a 'Geri'
davebike
PostPosted: 07:15 - 04 Apr 2014    Post subject: Reply with quote
RG2 is good so is any type of brake grease there rubber and alloy safe
Don't use copperslip it rots the rubber gaiters and adds to the ware on the alloy body
Yes copper slip was WAS recommended 15 years ago
Dave
Dave
NC750Xdct + others at work !
[email protected]
PostPosted: 08:19 - 04 Apr 2014    Post subject: Reply with quote
I use moly grease because it's a high load, low movement, metal-on-metal application.
Graphite grease would also be appropriate.
stevo as b4
PostPosted: 17:18 - 04 Apr 2014    Post subject: Reply with quote
Thanks everybody! Smile
I'll just stop giving it anymore thought and slap some RG2 on. I think underwater grease is a bit OTT for a bike that doesn't really go anywhere and certainly not underwater unless I run out of road next to the canal! Laughing
I've never had a problem with copperslip on car sliding calipers and didn't know it can affect rubber either? graphite paste sounds like an ideal product if you were being very anal though!
Dave M
PostPosted: 15:06 - 05 Apr 2014    Post subject: Reply with quote
Can Ceratec be used on the back of the brake pads?
Tamsin
PostPosted: 16:55 - 05 Apr 2014    Post subject: Reply with quote
Only on the friction surface Twisted Evil
For legal reasons, I must point out that you should never put and grease/oil/lubricant on the friction surface of brakes
Dave M
PostPosted: 17:06 - 05 Apr 2014    Post subject: Reply with quote
Very Happy
kramdra
PostPosted: 23:00 - 05 Apr 2014    Post subject: Reply with quote
Rubber boots that are designed to hold grease are somewhat resistant to grease. I would be very sceptical of red rubber grease and doubt it would last very long.
bugeye_bob
PostPosted: 23:06 - 05 Apr 2014    Post subject: Reply with quote
yes fine
CaNsA
PostPosted: 23:22 - 05 Apr 2014    Post subject: Reply with quote
What rubber where and what body where?
I dip my caliper pins in copaslip, the pins dont move one fixed into position.
PostPosted: 11:12 - 06 Apr 2014    Post subject: Reply with quote
The pins that locate the pads don't move (although the pads do move a tiny bit on them), but on sliding calipers the large pins the caliper slides on do have to put up with a fair bit of movement.
mentalboy
PostPosted: 12:08 - 06 Apr 2014    Post subject: Reply with quote
I've always used a high melting point Aluminium/Zinc grease, seems to hang on better than copper grease
Make mine a Corona.
The last post was made 12 years, 239 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.17 - MySQL Queries: 16 - Page Size: 103.59 Kb
