2011 yamaha ybr 125 xenon
Bike Chat Forums Index -> The Workshop via View Category
tuksedo
PostPosted: 19:19 - 19 Apr 2014    Post subject: 2011 yamaha ybr 125 xenon Reply with quote
Hi, was was thinking about getting xenon lights https://www.ebay.co.uk/itm/Xenon-HID-Motorcycle-Headlight-Conversation-Full-HI-LO-H4-Bulb-Kit-6000k-/330709113918 for my yamaha ybr 125 2011, do you think they would fit? i'm not sure what size should they be, either H1 or H4.
I was thinking about these philips bulbs https://www.amazon.co.uk/Philips-12972-XVS2-X-Treme-Vision-Bulbs/dp/B00440CWCG but they're 55w so Its too much.
Any advises?
Regards,
Linas[/url]
RhynoCZ
PostPosted: 19:23 - 19 Apr 2014    Post subject: Reply with quote
https://www.amk.to/images/discussion/original/d74c872e887ddf5fc4428081cf21a12b4d30dd47.gif
gavbriggs
PostPosted: 21:22 - 19 Apr 2014    Post subject: Reply with quote
I've done it on the bandit 1200 but it already had projector lights so the hid slot straight in.
It's also separate hi and lo beam on the bandit.
If you can get em in and correctly adjusted go for it. They are brighter and IMO safer for that reason. You need all the safeness you can get on a bike!!
moonzoomer
PostPosted: 21:37 - 19 Apr 2014    Post subject: Reply with quote
The standard lamp is 35 watt so an increase to 55 watt could overload the wiring and fuse, there is a 35 watt halogen available for the YBR 125 here.. https://www.ebay.co.uk/itm/YAMAHA-YBR125-YBR-125-HEADLIGHT-BULB-BOSCH-SEMI-HALOGEN-UPGRADE-35-35W-/181324923693?pt=UK_Motorcycle_Parts&hash=item2a37cec32d.
If you want to increase the headlamp wattage it is best to install heavier wiring and use a relay controlled from your existing headlight wiring.
simonjb
PostPosted: 21:23 - 24 Apr 2014    Post subject: Reply with quote
I know this is a late post, but in case nothing has already been done, a 55w bulb is impossible without re-wiring or a full conversion kit. IMO 55w's aren't really worth the hassle on a 125. But the 35w conversion kit would work.
You can get a 35w halogen, or xenon-halogen hybrid. The hybrid is not a full xenon arc, but instead a halogen charged with xenon gas. It is however whiter and noticeably brighter than a halogen, and WAY brighter than the stock bulb. The full conversion kit would probably be brighter, but the hybrid bulb doesn't require changing the fitting or a ballast, as it is still a filament. Up to you.
I got mine from here:
https://www.ebay.co.uk/itm/220656857279
It uses the standard bosch fitting, which is the stock fitting on the YBR, so it slots right in, and uses no more power than the stock bulb.
If you haven't sorted it already, hope this helps!
Current Bike: 2008 Yamaha YBR 125
The last post was made 12 years, 210 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   Reply to topic    Bike Chat Forums Index -> The Workshop via View Category All times are GMT
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.41 - MySQL Queries: 14 - Page Size: 44.33 Kb
