Tank swap
bypass2
PostPosted: 21:54 - 16 Apr 2014    Post subject: Tank swap Reply with quote
Hi. does anyone know if a cb 200 petrol tank will be a straight fit on a cm 200. Thanks
-Matt-
PostPosted: 22:44 - 16 Apr 2014    Post subject: Reply with quote
Not 100 percent as I haven't worked on either bike. Going from the parts fische's here
https://www.cmsnl.com/honda-cb200-general-export_model16412/partslist/F05.html#results
Part# 17050354000EC [CB200 tank part number]
It appears probably not, as all the tank parts number for the CM's here are different.
https://www.cmsnl.com/honda-cm200_model199/
Is it to replace a rusted tank - I managed to fix up a rusted SB200 tank on deaths-door into working order [just Laughing]. Might be easier and cheaper to look down that route if parts aren't easily available to replace it.
bypass2
PostPosted: 23:37 - 16 Apr 2014    Post subject: Reply with quote
Thanks -Matt- just thinking about ace bars cb 200 tank cafe racer seat on the cm 200 or just ace bars caferacer seat and use the cm 200 tank. Any Ideas any one
Teflon-Mike
tl;dr
PostPosted: 01:18 - 17 Apr 2014    Post subject: Reply with quote
Held on with two rubber door-stops in C cups at the front, and a single bolt at the back.
Most tanks from back-bone frame bikes can be made to fit other back-bone frame bikes, with a little adaptation.
CB200 and CM200 aren't all that closely related; but back-bone length will be close, so cup to bolt length should be close.
Worth a shot. Some-times trying it is the only way to answer such questions... or a tape measure....
bypass2
PostPosted: 22:43 - 18 Apr 2014    Post subject: Reply with quote
Thanks for the reply Teflon-Mike. looking at the price of a cb200 tank i might just stick with the cm 200 tank and ace bars and cafe racer seat now.
The last post was made 12 years, 183 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.71 - MySQL Queries: 14 - Page Size: 43.85 Kb
