| -Matt- |
 -Matt- World Chat Champion
 Posted: 19:06 - 16 Apr 2014 Post subject: Helmet Camera Charger |
Just thought i'd share this in case its of use to anyone. Have given it a fairly good test today and seems to work fine. My Drifts battery life isn't amazing at about 2.5 hours tops, and obviously if you remember to keep track of it at that point it requires pulling over and removing/replacing with a spare battery.
With a long trip coming up soon and only one spare battery I wanted to try and work out a way I could keep the camera helmet mounted and have it constantly running. I've got hold of a cheap portable mobile phone charger that runs off a few AA batteries, cable tied onto the camera and then cable tied the wiring tightly to around the back of them. To replace the batteries [about 10 hours constant running time per set], you just have to firmly slide the cable tie back a bit and remove the case.
https://i60.tinypic.com/m7yy3l.jpg
https://i59.tinypic.com/2sa0bbd.jpg
https://i61.tinypic.com/iofdl2.jpg |
| j00pY |
 j00pY Nova Slayer
| -Matt- |
| Rogerborg |
 Rogerborg nimbA
 Posted: 19:33 - 16 Apr 2014 Post subject: |
That is... so ghetto.
 ____________________ Biking is 1/20th as dangerous as horse riding.
| Llama-Farmer |
 Llama-Farmer World Chat Champion
 Posted: 19:47 - 16 Apr 2014 Post subject: |
Not bought it yet, but had a friend who recommended THIS* for the GoPro. I've found the standard battery only lasts a little over an hour... as did the smaller 8GB memory cards (the 16GB/32GB cards kept causing loads of problems with the Hero 3, but GoPro now recommend Lexar instead of SanDisk ones, so gonna get a 64GB Lexar card, and film with this external recharger)
* https://www.amazon.co.uk/15000mAh-Portable-Ultra-High-Capacity-External/dp/B00D5T3QK4/ref=sr_1_3?ie=UTF8&qid=1396991038&sr=8-3&keywords=Anker+Astro+battery+pack
He gets 5-6 hours at 720p and 4-5 at 1080p. Usually needs to swap memory cards though.
Only downside is it charges through the micro-USB... and you plug external microphone (or rather headset intercom lead) into the camera so it picks up RT transmissions rather than cabin noise. Not so bad on an airliner flight deck, smaller aircraft cockpit its a waste of noise. ____________________ Current Bike: 1999 Honda CB600 FX Hornet
Next Bike: I want a CBR-RR. And I want an F800 GS-A. And a VFR 800. Can I have all 3?
Dream Bikes: Honda VFR750R RC30, Honda NSR500, Ducati 996 R |
| goto10 |
 goto10 World Chat Champion
| chris-red |
 Posted: 20:07 - 16 Apr 2014 Post subject: |
Why would you want to record for 10 hours? When you are you going to get the time to watch through 10 hours of footage. Quality over quantity.  ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
WANTED:- Fujinon (Fuji) M42 (Screw on) lenses, let me know if you have anything. |
| -Matt- |
| barrkel |
 barrkel World Chat Champion
 Posted: 20:21 - 16 Apr 2014 Post subject: |
| chris-red wrote: | Why would you want to record for 10 hours? When you are you going to get the time to watch through 10 hours of footage. Quality over quantity.  |
I generally try to record every moment I'm on a bike just in case the footage is needed.
I don't like circular buffers that need positive action to retain recent footage. If I have a crash, I might not be able to mark the spot (very easy to forget with shock), and it will get overwritten.
I delete most of it. I spend about 30 minutes on a Sunday flicking through the footage pulling out any interesting bits that happened with my home-made video editor, but that's about it. ____________________ Bikes: S1000R, SH350; Exes: Vity 125, PS125, YBR125, ER6f, VFR800, Brutale 920, CB600F, SH300x4
Best road ever ridden: www.youtube.com/watch?v=s2MhNxUEYtQ |
| barrkel |
| -Matt- |
| -Matt- |
| Llama-Farmer |
| Irn-Bru |
 Irn-Bru World Chat Champion
| -Matt- |
| Irn-Bru |
 Posted: 20:45 - 16 Apr 2014 Post subject: |
Helmet cam (Drift HD 1080), and I did just that, forgot it was plugged it and it knacked the USB connector It ends up getting in the way of riding as well, end up fumbling around and taking ages to set off. Your solution is good, or a battery pack in a jacket pocket is just as good I suppose. ____________________ KTM 990 SMT & Suzuki DR-Z 400 SM |
| TheCatSatOnTh... |
 TheCatSatOnTh... Scooby Slapper
| trist077 |
 trist077 Two Stroke Sniffer
| -Matt- |
| gavbriggs |
 gavbriggs Crazy Courier
| -Matt- |
 Posted: 21:42 - 16 Apr 2014 Post subject: |
Yeah you probably could run it to a pocket fairly easily as an alternative. I mainly just wanted it all on the helmet to save having wires dangling all over the place and make it easier to take it on and off when stopping. I have no inner pockets on my current textiles annoyingly too so it meant i'd have the wires running down and around the outside or into trouser pockets  |
| j00pY |
 j00pY Nova Slayer
| -Matt- |
| The Disapproving Brit |
 The Disapproving Brit World Chat Champion
| Ali in Austria |
 Ali in Austria Nitrous Nuisance
 Posted: 07:07 - 17 Apr 2014 Post subject: |
Like trist077, I use Drift Power Packs https://www.actioncameras.co.uk/drift-power-pack-uk
I actually have 3 but that is to tide me over on a multi week tour when I am filming all the time. Great for charging other equipment via USB as well. The pack is certainly good for about 20 hours. I've had one of them for over 4 years and it is still going strong.
Not sure about The Ghost range but the Drift HD has a second back door which facilitates cable entry for a power lead and Mic Lead. I make them fairly waterproof by using a blob of this stuff at the point of cable entry https://www.actioncameras.co.uk/black-tack?
I do the same with GoPro's by using a Dremmel to make the cable entry on a waterproof case.
A blob or two of Black Tack also holds a cable down nicely and is easily removed without leaving a residue. Just think of it as Blu Tack on an Industrial scale. Useful for mounting the remote on a Tank Bag or cockpit area as well  ____________________ A Petrol Head in The Alps
https://www.youtube.com/user/PensionHausMaria
https://facebook.com/pension.haus.maria |
The last post was made 12 years, 108 days ago. Instead of replying here, would creating a new thread be more useful? |
