How far will castrol gtx last?
The Artist
PostPosted: 13:55 - 21 Apr 2014    Post subject: Reply with quote
Personally I think oil change frequency is far more important than the brand name of the oil.
mentalboy
PostPosted: 14:04 - 21 Apr 2014    Post subject: Reply with quote
I might change the oil that often if I was ragging an R6 but you should get away with 2000 miles easily on any 125. I change the oil on my Zed every 3000 miles, but I am an oil snob and it only gets Silkolene bike oil.
Make mine a Corona.
Teflon-Mike
tl;dr
PostPosted: 14:07 - 21 Apr 2014    Post subject: Reply with quote
Little Engines have little sumps; they dont hold much oil, so what they do hold has to go round all the moving bits more often.
That's why they have short oil change intervals.
And it tends to be the crap that collects in the oil that does the damage; so doesn't matter that much what fluid is carrying it about.
'Better' oil tends to have better stability under extreme temperature, pressure or load; if cheap oil is good enough to stand temps, pressures and loads on your engine, ent likely to be much help to you.
BUT, for now, don't fret you have left it a 'little' late; the 'reccomended' intervals tend to be on the short side to account for worst case useage.
1000 mile changes.... seems a good interval to me, stick to it, close as you can, but see how crappy the oil is when it comes out; clean white ice-cream tubs are good catch-trays for this; hold the lid behind stream as it flows out, you can often see how much shit is in the oil. You can also see what is in the tub when its drained.
If you are regularly getting very clean oil out the sump, you might be able to relax your change interval a little; but again, keep an eye on the oil colour coming out when you stretch a change.
But hey? They take what, half a liter from dry? Each change? Five liter can will last you ten thousand miles, even if you stick to 1000mile changes!
Stretch changes to 1500 miles, how much you going to save in a year? Probably less than difference in price between brand name and budget bottle!
mentalboy
PostPosted: 14:32 - 21 Apr 2014    Post subject: Reply with quote
All I can say to that is that I'm thankful I only had 2T tiddlers! (1000 miles per change Shocked )
Make mine a Corona.
Bunny Lingus
PostPosted: 16:52 - 22 Apr 2014    Post subject: Reply with quote
I used to use cheap car oil in my standard Cub but I kept getting clutch slip. So I used fully synth expensive bike oil which also caused clutch slip. Pissed me right off & filled up the clutch basket with so much gunkified friction material that I had to chisel the lot out & buy a new clutch & springs. There was a lot of wear in the bore & I bought a 2nd hand barrel & head off eBay as well so now I only use semi synth Rock or Silkolene & change it every 1000 miles like a good boy.
Bunny Lingus & The Flipside Faggots
Teflon-Mike
tl;dr
PostPosted: 17:48 - 22 Apr 2014    Post subject: Reply with quote
PillMonster wrote:
I am covering a lot of miles even more so now it is summer time changing it every 2/3 weeks is just an annoyance.
That's bikes; the level of anticipated user-maintenence has been retailed at the level a 1950's Brit-Twin demended; engineering increasing engine performance, rather than life or serviceability, unlike cars, where performance has remained reletively level at about that of a MKII Cavalier since the 1980's and engineering used to make them as user freindly and undemanding as owning a washing machine.
2500 miles sounds quite a generouse change interval for a 125; but then so does a 2l sump capacity. I think thats about as much as my 750 'four' takes and more than I think Snowies Strada holds; but again; reccomended change intervals for them are both under 2,000miles.
If you are cranking up over 15,000 miles a year, to need to do oil changes that frequently? Well... you are pushing the anticipated envelope of what designers envissaged, which is probably 'average' annual bike miles, around half that. Quite reasonably. Most folk that would do that many miles, week en week out, wouldn't choose a 125 to do it on.
Dont think that there is any problem with your oil; or that a different oil will solve your problem... Different bike might..... something with shaft drive perhaps? Adjusting the chain as frequently as needed is usually more annoying to more buyers than short oil change intervals.
sickpup
Old Timer
PostPosted: 22:51 - 22 Apr 2014    Post subject: Reply with quote
Welcome to the years 2000+ where modern 650 twins only hold 2 litres and have 7500mile oil change intervals.
This has been a public information broadcast bought to you by sickpup.
Have a nice day.
PostPosted: 22:56 - 22 Apr 2014    Post subject: Reply with quote
I was doing 1000+ a month on the Vara so changed it monthly because I'm far too kind.
I'll do the blackbird every 3-4000.
PostPosted: 23:06 - 22 Apr 2014    Post subject: Reply with quote
Surprised the oil change interval is that frequent on a fairly new 4 stroke.
I would keep an eye on the oil and see how it goes.
Years ago my CB100N (which only had a tiny amount of oil in it) would do about 600 miles on fresh oil before it started to drink the stuff.
Bunny Lingus
PostPosted: 02:36 - 23 Apr 2014    Post subject: Reply with quote
Yeah, so did mine & it stank real bad too. It was kicking out an awful eggy pong from the engine breather. I swapped the 99cc lump for a CG unit. I still have it though. Might do a post mortem one day & see wha'ppen...
Bunny Lingus
PostPosted: 02:49 - 23 Apr 2014    Post subject: Reply with quote
'Bout a litre in most little Hondas. Two pints if it leaks...
smegballs
PostPosted: 16:53 - 28 Apr 2014    Post subject: Reply with quote
I'd go for cheap oil changed often.
I just bought a 5L of Asda's own semi-synth 10W-40 for 16 quid. Plan to do 1000/1500 mile changes on the GN (service schedule is 3000). It's less than a tenner a time for oil + filter.
iooi
PostPosted: 17:21 - 28 Apr 2014    Post subject: Reply with quote
Teflon-Mike wrote:
2500 miles sounds quite a generouse change interval for a 125; but then so does a 2l sump capacity..
I think someone is having a laugh, or so in hand with oil manufactures to scam learner riders out of their hard earned cash.
My Versys (650) has 2 ltr sump. Yet has a 7.5 mile service interval.
So why the hell should a highly under stressed 125 need changing over three times more.
Its screams of fleecing the customer.... Twisted Evil
andym
PostPosted: 18:53 - 28 Apr 2014    Post subject: Reply with quote
I'm on about 8-9 thousand miles on the VFR and still haven't changed the oil (come to think of it I haven't done a lot other than clean and oil the chain) Whistle
PostPosted: 19:14 - 28 Apr 2014    Post subject: Reply with quote
Possibly, but the Varadero probably gives the oil a harder time, being air cooled.
PostPosted: 19:15 - 28 Apr 2014    Post subject: Reply with quote
Do you sit at 80-90% max revs constantly? Probably not. How high does your bike rev? Does it sit at 10k daily?
I changed my Vara 125 oil monthly or 1000 miles, whichever came first. It sat at 11k all day, every day. That is a big ask.
PostPosted: 19:27 - 28 Apr 2014    Post subject: Reply with quote
BodyGuard wrote:
You appear to be mistaken. The varadero is liquid cooled.
Is it? Oh well, ignore that comment then Laughing
PostPosted: 19:30 - 28 Apr 2014    Post subject: Reply with quote
Kickstart just got it handed to him by none other than MrWeldedSprocket.
Everyone, save your work and log off, shit is going wrong.
Bunny Lingus
PostPosted: 20:22 - 28 Apr 2014    Post subject: Reply with quote
I like the idea of nice clean oil going round my engine. ASDA doing semi synth? Cool! I might go in & grab a couple of gallons of that & give it a shot...
smegballs
PostPosted: 20:23 - 28 Apr 2014    Post subject: Reply with quote
I slung it in the GN a few days ago and no clutch slippage. Being cheapo oil I guess the chances of naughty additives is lowered somewhat.
The last post was made 12 years, 206 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.99 - MySQL Queries: 13 - Page Size: 134.84 Kb
