GPZ500 - Weird starter noise
Nipedley
PostPosted: 09:50 - 27 Apr 2014    Post subject: GPZ500 - Weird starter noise Reply with quote
Hi guys,
I picked up this bike for a friend and have been doing some basic servicing on it before he picks it up from me.
It's a Kawasaki GPZ500s, 1994 and done 51,000 miles.
It starts fine but when it takes a few kicks of the starter to get the bike going, occassionally the starter makes this snapping noise and you can feel a vibration go through the bike. It's strange because it doesn't always make it, and the starter motor continues to turn over and does fire the engine. Can I presume something to do with the starter clutch?
I recorded it below, it doesn't show in the video how loud the 'snap' of it can be, but you can hear the sound. The snapping sound is at 0:25 (it took me that long to get the bike not to want to start!)
https://www.youtube.com/watch?v=e3ziLXrdaWw&feature=youtu.be
Any suggestions would be great.
Scotsman37
PostPosted: 09:54 - 27 Apr 2014    Post subject: Reply with quote
Are you sure that's not from the top end of the engine with such a large tapping noise, as it could be the valves?
Plus, the trouble starting could be due to old fuel/carbs jets needing a thorough clean out, but you could try removing the air filter and spray Motul Carb cleaner while it's running plus put some fuel treater iinto the tank too. Plus, have you inspected the spark plugs?
i.p.phrealy
PostPosted: 10:01 - 27 Apr 2014    Post subject: Reply with quote
my Honda VT500 does that too, it's just the starter motor failing to engage. nothing to worry about as the next time you hit the button it goes.
Nipedley
PostPosted: 10:03 - 27 Apr 2014    Post subject: Reply with quote
The bike sounds fine once it's running, though a valve clearance check should probably be on the to do list Smile
Is there anything that can be done to stop it? The bike still turns over and starts fine but it's a little unnerving
Thanks guys
Nipedley
PostPosted: 10:21 - 27 Apr 2014    Post subject: Reply with quote
Thanks guys, so I've got the following to check-
Possibly running on one cylinder? It wasn't when I rode it back to my place, but that could explain a few things now. I actually put new spark plugs in, so I'll check those and see what the story is. I'll also check both sparks.
Pull and clean the carburettors ( was hoping not to with the coolant lines running underneath, but there you go )
Valve clearance check
And hopefully the starter snapping is nothing too serious, when the bike is happy and starts on the button you don't hear it anyway, it's just when you have to have the starter motor kick for a while that the noise comes up.
Cheers guys Smile
The last post was made 12 years, 207 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.57 - MySQL Queries: 14 - Page Size: 47.73 Kb
