Honda cbr 125 not starting
Jonny491
PostPosted: 19:55 - 01 May 2014    Post subject: Honda cbr 125 not starting Reply with quote
Hi guys, I have a 2006 Honda cbr 125, ive owned it just over 2 months now. Today I got it serviced I rode it home and it was fine. Then about half an hour ago I thought id quickly go to the local shop roughly about 1.5 miles away so I went there and it was fine. I finished in the shop and I went to it and it wouldn't hardly start. I eventually got it started and when riding it home it was like it was struggling to rev then once I got it home I thought I should try starting it again and now it doesn't...
Can anyone please help me or have and ideas what could be wrong?
Honda cbr 125 2006- Sold, Current 2012 yamaha XJ6N
PostPosted: 19:57 - 01 May 2014    Post subject: Reply with quote
Open the fuel cap and try again.
Jonny491
PostPosted: 20:01 - 01 May 2014    Post subject: Reply with quote
what the actual fuel filler cap?
PostPosted: 20:22 - 01 May 2014    Post subject: Reply with quote
Yup.
Service means they have likely lifted the tank, there are 2 arse fuck air lines, utter cunts to get back in.
Open cap and start it.
Jonny491
PostPosted: 20:23 - 01 May 2014    Post subject: Reply with quote
alright il give it a go, thanks a lot:)
Jonny491
PostPosted: 20:41 - 01 May 2014    Post subject: Reply with quote
ive just tried it with the fuel cap open and still doesn't start Sad
PostPosted: 20:47 - 01 May 2014    Post subject: Reply with quote
Does it spin fast enough on the button and have you pulled the choke lever out and held it there?
Jonny491
PostPosted: 20:50 - 01 May 2014    Post subject: Reply with quote
yeah its spinning around fast and enough and yeah I have
Odd, can you bump start it ok?
Jonny491
PostPosted: 20:55 - 01 May 2014    Post subject: Reply with quote
not it doesn't bump start either...Sad
PostPosted: 20:57 - 01 May 2014    Post subject: Reply with quote
Fuel or spark then my friend.
Would call up the place that serviced it to come and sort it.
If it was me though, I'd remove the tank and check the vacuum pipe on the tank which goes to the fuel tap. Without that, the fuel will not flow.
It is a bitch of a bike to work on, so I do not envy you. Laughing
CarlosCBR
PostPosted: 20:59 - 01 May 2014    Post subject: Reply with quote
Sounds like the vacuum pipe may have slipped off the fuel tap. Have a look under the tank and see if you notice the bottom pipe not connected. It's a stupid kind of cone design and easily slips off if not clipped on properly.
Jonny491
PostPosted: 21:02 - 01 May 2014    Post subject: Reply with quote
ah alright I checked the spark and that seems to fine, and yeah il ring him first thing in the morning. Ah alright how do I check if the vaccum is working? and hahah alright thanks for the help anyway mate
Jonny491
PostPosted: 21:12 - 01 May 2014    Post subject: Reply with quote
ah okay cheers il have a look in the morning
PostPosted: 22:30 - 01 May 2014    Post subject: Reply with quote
Wot Paddy said but there should be a 'prime' setting on the fuel tap to fill the carb with fuel without it needing a vacuum.
Triumph Sprint ST 1050
PostPosted: 06:57 - 02 May 2014    Post subject: Reply with quote
There is no fuel tap on this, yeah, annoying isn't it.
It just does it all itself, you get a fuel gauge.
The last post was made 11 years, 343 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.74 - MySQL Queries: 13 - Page Size: 86.1 Kb
