| esullivan |
 esullivan Could Be A Chat Bot
 Posted: 08:41 - 15 May 2014 Post subject: BMW F800GT |
I'm looking at this one for the next bike, it's near the top of the list right now. They are pricey, but not bank breaking, even brand new. There's a used one near me, but I'm probably not looking to buy for some months yet.
Has anyone had one, or the previous ST? How reliable are they? Can they stand up to being outdoors 24/7? I don't have a garage.
I'm looking at it because it seems commutable, more so than a full-sized tourer, but comfortable enough for touring two-up. The main things I'm looking for compared with my current bike is some weather protection, a bit more power when loaded up and I'm getting bored of chain maintenance (so either shaft or belt, like this uses). I will still be commuting on this to work every day, so has to be something I can filter with and park easily.
A used Honda Deauville meets two of those requirements, but not much more powerful than my current bike, while a Pan-Euro is too big and thirsty (I think) to be an everyday commuter. There aren't a lot of non-chain bikes out there that aren't huge tourers or non-commuters like Harleys, are there?
I've done scooters. That's a bit too boring, even for me. But finding a practical bike that meets these requirements is harder than I expected. ____________________ Current: '14 VFR800X Test passed 31/10/12.
Previous: '12 NC700S, '11 CBF 125, '04 SH 125. |
| map |
 map Mr Calendar
| esullivan |
| map |
 map Mr Calendar
| Rogerborg |
 Rogerborg nimbA
 Posted: 11:05 - 15 May 2014 Post subject: Re: BMW F800GT |
| map wrote: | For a commuter have you considered the less cc baby version?. IIRC Rogerborg rates his as it just works. |
Oi!
The F"650"GS has the same basic 798cc engine as the 800GS, ST and GT, detuned a bit on the "650" and "700" so that your pipe and slippers don't blow off. The GT is up-tuned a bit.
They also share an under-seat tank configuration which helps to make them feel lighter than they are.
Mine's returning a claimed 67mpg as a commuter, and that's downgeared a tooth on the front.
The finish on the Rotax engine isn't great. If you're keeping it outside, the GS has a known issue with water ingress buggering up the ignition barrel. I've had no problems, but have ghettoed a cover for it using an aerosol cap.
Oil + filter change for these engines is every 6000 miles, valve clearance check every 12,000 miles. I was quoted £201 including VAT for a valve clearance service from BMW (not that I went with them), although adjustment is a cams-out job.
The GT should be worth a look, I can't actually fault my GS. ____________________ Biking is 1/20th as dangerous as horse riding.
| map |
 map Mr Calendar
| Rogerborg |
 Rogerborg nimbA
| map |
 map Mr Calendar
| Wonko The Sane |
 Wonko The Sane World Chat Champion
The last post was made 12 years, 186 days ago. Instead of replying here, would creating a new thread be more useful? |
