 ian3mith Borekit Bruiser
 Robster World Chat Champion
 Posted: 15:56 - 19 May 2014 Post subject: |
30-40 mins... don't let nerves be the killer! chill out and good luck!  |
 Az World Chat Champion
 Posted: 15:59 - 19 May 2014 Post subject: |
IIRC it's just under an hour long from beginning to end. You start off with getting your eye sight checked (typically asked to read a number plate in the car park) and then the examiner will continue with some basic questions about motorcycle maintenance and changes you may need to make to the bike when taking pillions.
After the questions and eye sight check, the examiner will check the radio works and then you start your test on the road. At any point you will be asked to do an independent ride (it could be at the beginning, at the end or in the middle of the test) where you're asked to follow signs to a specific place. Most of the test is you being followed by a motorised sat nav, he tells you directions and you follow them.
Good luck  |
 Posted: 16:01 - 19 May 2014 Post subject: |
ok thanks guys  |
 mase101 Nitrous Nuisance
