| bikernoobie |
 bikernoobie Two Stroke Sniffer
| Az |
 Az World Chat Champion
 Posted: 19:34 - 21 May 2014 Post subject: |
Benefits of getting your A1 license at 17:
-You're more likely to get out of that 2 year 6point probation period without any points on a 125, it'll be a lot easier to get 6points on a bigger bike or car.
-No L plates, riders with L plates seem to be treated like retards on the road by car drivers.
-Gives you an idea of what to expect if you end up doing your A2 license when you're 19.
-You can give people lifts on your bike and use the motorway legally (although I wouldn't advice u do either on most 125's).
Negatives of getting your A1 license:
-Cost, an A1 course may cost you around £600 where as your CBT is only £100-120
-You end up riding the same bike regardless of if you do your A1 or just your CBT alone.
Personally, I'd do my CBT first, ride around for a few months, get some advice from BCF, watch Youtube vid's and do my A1 tests without training (£131 for tests and theory) if I had the spare cash.
I'd pick a YBR over the CBF. They'll have the same mpg, have the same riding position and you won't suffer from any rust or any potential fuel pump issues like the CBF's do. YBR's tend to have the better finish and can be picked up for under a grand and will do exactly what you want from a 125 (besides look good).
Edit:
I'd completely discard the YZF125R, it's a waste of money and you pay extra $ for the looks, it's not that much faster than a CBF around town.
An RS125 will most likely benefit from a top end rebuild as soon as you get it, I wouldn't recommend getting one or even considering one unless you know how to ride a 2 stroke properly and can do top end rebuilds yourself.
| pinkyfloyd |
 pinkyfloyd Super Spammer
| bikernoobie |
 Posted: 20:07 - 21 May 2014 Post subject: |
| Az wrote: | Benefits of getting your A1 license at 17:
Edit:
An RS125 will most likely benefit from a top end rebuild as soon as you get it, I wouldn't recommend getting one or even considering one unless you know how to ride a 2 stroke properly and can do top end rebuilds yourself. |
Hi,
Thanks for the detailed reply, just wondering is an A2 test any different from the A1 aside from bike size?
I was under the impression that a cbf is larger than a ybr, is that correct? I also thought that the fuel pump issue had been solved on later bikes (I am looking at 11-12) and would be a simple fix anyway and that the rust could be prevented with simple drying down and spraying wd-40? I prefer the cbf's looks and have also heard that the ybr's gearbox can sometimes be tricker for learners.
One of my friends is set on a rs125, I think he's a bit mental |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 00:05 - 22 May 2014 Post subject: |
You don't have to take any training to self book the tests on your own 125 for A1.
Mod 1 is £15.50 I think, Mod 2 £75; that's £90.50 if you pass both first time; and the ONE advantage Az didn't mention, is its effectively a 'perpetual CBT'; you never have to pay for a repeat to keep L-Plate entitlement; you have full licence and all that brings.
Easy to get your first CBT, planning on not taking tests until... and then something changes plans, and CBT lapses, and you haven't got a licence; so you start over from scratch doing another CBT, and you go so far, and you dont have money so drag it out,or something else happens, and so it goes on, and repeating CBT becomes a habbit, an expedience letting you carry on biking without actually getting up and getting what you want.
If you set a goal, worst that can happen is you don't achieve it; not setting it, you will NEVER achieve it. You have two years you cant do much, but you CAN do A1, so to my mind it makes sense to spend that time at least TRYING to get your A1.
Its better than doing nowt. And as Az has pointed out, there ARE advantages, like getting countdown on New Driver Probation started early.
Not so sure about loosing the L-Plates being a positive advantage in how drivers see you..... At least they fucking SEE the L-Plate to treat you different! But, yeah, riding same bike with and without L's quite regularly, if they DO look, they tend to give you a bit more respect; where if they see an L-Plate its a bit of a red-rag to a bull, and many just HAVE to bully past so you don't hold them up, even if you are actually breaking the speed limit yourself!
But, main 'joy' of passing tests, is just that... feeling of success! The achievement, and validation of not being just some kiddie-come-lately on an L-Plate.
And confidence it brings. You have made the grade and earned your road room; bloke with the clip-board has given you a piece of paper to tell you you are a competent rider, not a complete idiot.
And YES, the A1 tests are EXACTLY the same tests as for A2 or A3, the only difference to those test schemes is you ride a bigger bike.
The Mod 1 course is the same size, shape and same exercises; Mod 2 route the same roads, the expectations and requirements identical; its JUST doing it on a different capacity machine.
So, final benefit; if you pass A1 on your own 125... you are onto a flyer if you then want to upgrade.
- You ought need less training to do either an A2 or A3 course; as you have confidence gained you can already pass the tests.
- You know the ropes; so turning up at test, you should be less nervous, have all the right paperwork, etc etc etc. Its just a formality re-doing what you already done.
- Either is just an 'upgrade' to licence entitlement; A1 will have secured your Theory/Hazard pass and as said, no need for a CBT, so you wont have to worry about how long is left on either cert, or have to hold fire to get certs before you start training for A+ tests.
Last thought on training:
Lessons is for life... not just for licences
I always reckoned that every hour of training, learning to do it right, right at the start, was worth a day, a year down the line.
Mainly because, having been riding a year, you become less responsive to being taught, and habits become engrained and harder to break.
Meanwhile; value of training is hard to see, other than in licence you get; BUT, you don't count crashes you don't have, and when you first set out, THAT is when you are most likely to make mistakes and do most of your falling off.
So, if you follow CBT with the odd lesson on your own 125, its good learning, and unlike an A2/A3 course where to be on the A2/A3 bike you have to have an instructor watching you, and be paying them for their time to watch you wobble; you can go away, practice to your hearts content for price of petrol on bike you already have.
Gets you into good habits straight away, and just ONE nugget of learning you pick up from lessons, COULD be the one nugget that saves.. if not your life, at least a whole lot of pain hassle and money in repairs.
Two years is a long time on a motorbike; a lot of riders only ride regularly for a couple of years; then they get a car as every day transport, and if they come back to bikes, often not as every day transport but as a leisure pursuit.
Its somewhat ironic, then, that so many quite often put them selves at most risk, riding the most often, doing the most miles, in all weathers, when they would get the most benefit from a bit of learning; then when they DO go get some, its to get a licence under DAS... just to go ride a few miles a year on Sunny Sundays, not battling half awake commuters in cars!
So if you can afford it, training is GOOD!
And if you can massage some money for lessons out of your budget, its a good place to put some spend; you'll get more value from a lesson that saves a crash, than you will from a crash-hat that 'might' save you a little hurt when you do have one.
While if you think you are likely to go for A2 training when you are old enough, IS worth thinking about pulling that forward, and getting it early, so you can get benefit from it straight away... I mean, you wouldn't wait until you had got a bike up to 60 before you put your crash-hat on, so leave it until you want to take tests to get the training in?
So, end of the day your call; BUT, Do your CBT, get your bike and gear sorted, but give some thought to further training, and have a crack at getting your A1; even if you FAIL you will learn something, and its a darn site cheaper failing A1 tests on your own bike, than failing A2 or A3 when you are paying for a school bike to do it. So you really don't have a lot to loose at least trying for it; and while rewards may be marginal, they are there, and they are helpful. IMO at least. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Az |
 Posted: 00:51 - 22 May 2014 Post subject: |
| bikernoobie wrote: | Hi,
Thanks for the detailed reply, just wondering is an A2 test any different from the A1 aside from bike size? |
The tests are identical, it's just a different bike you'd use. A larger more powerful bike.
To be more specific, you'd be on a bike that produces (possibly restricted down to) 35kw/47bhp, have a power to weight ratio no more than 0.2kw/kg and is at least 395cc.
| bikernoobie wrote: | I was under the impression that a cbf is larger than a ybr, is that correct? I also thought that the fuel pump issue had been solved on later bikes (I am looking at 11-12) and would be a simple fix anyway and that the rust could be prevented with simple drying down and spraying wd-40? I prefer the cbf's looks and have also heard that the ybr's gearbox can sometimes be tricker for learners |
There's not a noticeable difference in size, it's just the fairing on the CBF which makes it look bigger. Just google "ybr 125 cbf 125" and a lot of images will pop up of the two bikes side by side.
E.g. https://www.motocykl-online.cz/img/galery/motocykly-honda-cbf125-2009_22.jpg
You've certainly done your homework and you're right, most fuel pumps would of been fixed under warranty and you can protect the CBF from rust by covering it in ACF-50 (not WD40, WD40 is no where near as good as ACF-50) before the winter starts.
If you really have your heart set on a CBF i'd go for one but a YBR will require less maintenance (oil topping up and ACF-50 smothering) and can be bought cheaper.
Although, on the other hand, I had a CBF125 for 11months from new and not that much rust accumulated on the bike and I had no problems what so ever with the bike besides the fact that it drank oil on a weekly basis, so if you do get a CBF check the oil levels weekly maximum or daily if you can be arsed. |
| dydey90 |
 dydey90 World Chat Champion
| Baffler186 |
 Baffler186 World Chat Champion
 Posted: 09:22 - 22 May 2014 Post subject: |
If your heart is set on the CBF (looks wise) don't let the fuel pump issue worry you that much. if it does need replacing (and mine didn't) a new one is IIRC £90, and you could fit it yourself in 20 minutes.
As for licenses - all good advice has been given, just up to you to decide what's best for you. Personally I always felt like a student with L plates on, even though I was 32, so passing my tests, like Teflon Mike says, is a real sense of achievement. ____________________ Current: 2009 SV650 S, 1990 Kawasaki GT550
Previous: 2009 CBF125, 1998 GSF600, 2004 FZ6 Fazer, 1978 CB400a Hondamatic |
| bikernoobie |
| Rogerborg |
 Rogerborg nimbA
 Posted: 09:56 - 22 May 2014 Post subject: |
Sensible chap, you'll do well.
I'd suggest:
Turn 17
Do your CBT and insist on it being on a geared 125, otherwise you might as well have done it on a moped at 16.
Get a 125. If you want big, try and find a decent Varadero 125 in budget. However, keep an open mind and don't pass up any Japanese branded 125 in good condition at a bargain price.
Book and pass your theory test while getting some riding experience.
Have a look at the module 1 videos on YouTube. Book your module 1 test yourself. It's only £15.50, you might as well have a go.
If you pass, consider booking module 2 yourself. That's £75, so is a bigger gamble. However, if you pass, you've then got yourself a motorcycle license. Yes, it's A1, but that means no more CBTs, no more theory tests, no more L plates (until you do A2 and then A tests), and the clock starts running on your 2 year "new driver" probation. It's in the bank and you'll know that you can do it again at 19 and then 21.
The licensing regime looks burdensome, and it is, but that's the game as it stands. Winners win, losers complain about the rules.  ____________________ Biking is 1/20th as dangerous as horse riding.
| bikernoobie |
| sidewinder |
 sidewinder World Chat Champion
| sidewinder |
| Ayrton |
 Ayrton World Chat Champion
 Posted: 23:23 - 23 May 2014 Post subject: |
I owned a cbr125 and i'm over 6ft. Found it pretty comfortable unless i was sat on it for more than 2 hours, but the only time that happened was when i got lost . I suggest you find a dealer and sit on one before you remove it from your list, a few friends who where my height and taller liked it, while some didnt.
As for the ybr, my brother had one and they are pretty robust. It will do around the same mpg as a cbf and most other 125's |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 12:22 - 24 May 2014 Post subject: |
| bikernoobie wrote: | Thanks all, I think the most likely course of action would be getting the cbt and sitting on that for a few months before attempting the A1 either without lessons or with a few depending on my finances |
Confucius say; when stood at bottom of mountain, waiting for the ropes to arrive; enjoy the view; don't chuck yourself at the cliff-face, trying to get a few steps ahead.
CBT is Compulsary BASIC Training.
It is VERY basic. You don't need to know fuck all before you do it, other than that you know fuck all, so be open to learn.
You will start with an introduction talk; and be told such 'obvious' things as;
- you need to have a licence
- you need to have insurance
- you need to wear a crash helmet
And other legal requirements; and these topics will then get expanded on, and you'll be taught that not only do you have to wear a crash helmet; but it also needs to be properly fastened... and like I said it really is very very basic, BASIC; instructor will teach you how to fasten a crash hat strap!
That will lead in to a bit of more technical stuff about choosing a helmet, and fact that motorbike helmets have to be to approved standards, and you ought to be told what those standards are and how to find the approval markings on a hat to check when buying; and lead into other advice on riding wear, like leathers and water-proofs; boots, gloves and Hi-Vis, 'and stuff'.
EVENTUALLY... you'll get to look... note, 'look'... not touch; not ride, just 'look' at a motorbike! And instructor will point out things like the wheels... the tyres; the brakes; the switches; etc, and then go through things like pre-ride checks.... like making sure tyres aren't flat, and have tread on them.... some basic maintenance, like checking the oil and chain tension....
Then if you are really good boy... they'll let you wheel the bike around the car-park, and you'll be tought the 'propper' way to man handle a machine around, and how to take one off its stand, and put it back on.....
THIS is how BASIC Compulsory BASIC Training is.
And tip; all you need to know is that you know fuck-all. DON'T 'shut down' when the instructor shows you something that looks SO bludy obviouse, and chomp at the bit thinking "Yeah, yeah, but WHEN am I going to get to RIDE!"
There is an awful lot in CBT, and its all on a script provided by the Driving Standards Agancy, and the instructor HAS to go through the whole lot, regardless of what you may or may not know or think you know already; and those 'so bludy obviouse' things at the start, LIKE wheeling a bike about the car-park, DO have quite a few nuggets of very useful info in them; and when you get your own bike; DAFTLY your first 'crash' is MOST likely to be, wheeling the bike up your own drive! Listening to the instructor, and actually picking up that one 'tip' about standing the right side of the bike, finding the proper hand-holds, can save you that expensive pride and joy shattering first 'fumble'.
And THAT is what CBT is all about; getting some-one who might never even have more than glanced at a motorbike before, clued up enough that they can wheel a bike out of a garage, check its legal for them to ride; check its safe for them to ride; suit up 'appropriately' to ride it; and then potter out onto the road on it; with 'some' basic level of competence, that they at least know the basics and aren't a complete danger to themselves and others.
And the lessons start SO simple... but drill down into more detailed stuff very quickly... THEN jump to the next topic; like I said; machine handling... by the time you have thought "YEah YEah, but when am I going to get to RIDE!?" bit about finding the right hand hold, or where to push to go backwards or how to balance bike to get it on the stand, could have been missed... so don't get frustrated; pay attention, you WILL get to the 'fun' bits, and quickly.... but instructor HAS to go through the script like the government has told him, and its not ALL 'so simple' and so 'obvious', so dont dismiss anything as irrelevent too quickly.
OK... so after familiarisation and basic machine handling... you'll get to do some riding... and again, will start slowly... starting the engine.... turning it off again... Mounting the machine. The 'Safety Position'.. how to sit on the bike at rest... THEN you will have an exercise (on a geared bike) about the clutch and finding the biting point... then you will learn to launch, pulling away.. and you will get to ride ten feet or so at a time..... in a straight line.... BASIC.
But excersizes will 'build' and can build quickly depending how fast you pick it all up; and you will start riding round in circles and then you will start riding around the cones, then changing gear, then changing gear and slowing down, and stopping, etc etc etc...
And within a couple of hours, you'll probably be tackling simulated junctions and things like that, and by lunch-time; they'll be looking to take you on the road... and by that time, you ought to be able to 'ride' a motorbike... and dealing with traffic will be the main concern... and on the road, they'll be getting you used to real road situations and riding at higher speeds, and a LOT of it will be where to look, and not what levers to tug or push or prod... you'll be doing that intuitively by then.
So, here and now; enjoy the view!
Relax; life's too short and too full of stuff to fret about without wasting nervous energy going out LOOKING for stuff to worry about, before you have to.
You don't have to know fuck-all before your CBT, other than you know fuck-all... AND everything you NEED to know, will be taught on CBT, and you'll have some-one there who can not just tell you how to do stuff, but show you, and let you try and help you if you struggle. THAT is what its for. Its your First lesson.
If you wanted to learn Karate, you wouldn't be going to the first class, expecting to take your Black-Belt exam! You'd turn up expecting to be told what the belts were; how to tie them, how to put your dressing gown on properly; how to make a fist and stuff, wouldn't you?
CBT is the same. Its NOT a test; its your first lesson.
Go do, and enjoy - its supposed to be 'fun'.
And here and now, enjoy not REALLY having anything you HAVE to worry about.
I'm more tau than zen when it comes to bikes; but either way; it is an activity that can have a lot of philosophical parallels to 'life'... end of the day you are sat on a machine held up by hundreds of competing forces, rushing at the world very fast; part passenger, part pilot, and while we might 'think' we are in control... reality is there is only SO much we actually have real influence over, and its all about managing 'balance' and finding 'harmony' amongst competing forces... like life!
And chances are, you'll come back from CBT with SO much inspiration and so many REAL things to worry about, if you have any thought about what you are worrying about now, it will be 'I don't know WHY I was worried about THAT"
Back to top; when at bottom of the mountain; enjoy the view; don't try climbing before you got the ropes!
We can waste our lives in worry; Trick is to worry about the stuff that NEEDS to be worried about and NOT sweat the small stuff. Works for bikes, works in 'life'. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
The last post was made 12 years, 157 days ago. Instead of replying here, would creating a new thread be more useful? |
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 0.92 - MySQL Queries: 14 - Page Size: 109.27 Kb
