Derbi gpr seizing
mikej100
PostPosted: 18:58 - 17 May 2014    Post subject: Derbi gpr seizing Reply with quote
Chaps...
First posting so go easy on me.
My son has a Derbi GPR50 2005 that ran fine for most of the year he owned it then one day it seized with the piston detonating the head.
So i bought a cyclinder repair kit and rebuilt it ,again it ran fine but after only 2 days it seized again...gutted!!
So that was last November and after sitting in the shed for the winter i've finally got enough enthusiasm to tackle it again before selling it on.
I suspect the oil pump may not be working can anybody tell me how i can check it is working correctly?
Any other ideas/comments as to what may have caused this would be welcome as i'd really like to sell it on knowing it's going to behave itself.
Thanks
Mike.
PS anybody interested in a decent 2005 GPR50 MoT'd to Nov 14 new brakes ,chain ,sprockets,rear tyre less than 100 miles some where near 600 quid would do.
nathan k
PostPosted: 22:20 - 18 May 2014    Post subject: Reply with quote
Premix tank, remove oil feed to the carb. When running oil should drip out the pipe slowly. It won't look like much but it goes a long way.
Being a 50cc...What modifications have been done to it?
A combination of tuning parts could cause an extremely lean running condition.
mikej100
PostPosted: 09:17 - 19 May 2014    Post subject: Reply with quote
Hi nathan...
No mods whatsoever,its compltely standard.
It has been suggestedto me that the cause may be down to it running lean but the underside of the orginal piston is sooted.
Thanks for the tip regarding the oil pump i'll try that once i get it back together and running.
It's been a while since i did any premixing any suggestion as to the best ration oil/fuel to use?
Mike.
Inked
PostPosted: 02:02 - 20 May 2014    Post subject: Reply with quote
Did you check the crank for play when you had the bore off?
mikej100
PostPosted: 22:41 - 29 May 2014    Post subject: Reply with quote
Ok,latest is i've put everything back together and running on premix it starts and runs really good.
I've pulled the oil feed pipe from the oil pump and at 3000 rpm all i get is a very very small drip every few seconds but it's hardly noticable even if i hold the pump fully open by hand it doesn'tseem to push out much ,i can't believe that it is enough to pump up the pipe to feed the carb sufficiently.
Is this normal?What should i expect to see coming from the pump
I'm also going to purge the oil system and run it on fully synthetic,would this make any difference?
Thanks again chaps
Mike.
trisers
PostPosted: 22:54 - 29 May 2014    Post subject: Reply with quote
If it's any help my old Honda H100 oil pump produced a drip of oil every two or three seconds at a fast idle say 1500 rpm?
bodger
PostPosted: 07:22 - 30 May 2014    Post subject: Reply with quote
Hi Mike
Its been a few years since I ran a two stroke, but the oil pump usually has a metering line scored on the quadrant wheel, the operating cable connects to..When the throttle is wide open the line should line up with one on the oil pump body.
To adjust the flow, simply adjust the actuating cable accordingly.
Hope this makes sense.
Good luck.
The last post was made 11 years, 250 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.57 - MySQL Queries: 14 - Page Size: 57.03 Kb
