kmx 125 wont start help please?
laing27
PostPosted: 17:47 - 29 May 2014    Post subject: kmx 125 wont start help please? Reply with quote
everything was perfectly okay when I got it until I was riding. And it cut out then has started making a strange sound when engine is turned over there is no kick start but when trying to bump start back wheel doesn't lock up. please help
dangerousdave
PostPosted: 22:08 - 31 May 2014    Post subject: Re: kmx 125 wont start help please? Reply with quote
Sounds like you've lost compression due to a seizure. Wouldn't try and run it like that.
Take the cylinder off and check the condition of piston, rings and cylinder walls.
1988 Kawasaki KMX 200
Previous: Yamaha YZF1000, ZZR600, KMX200, DT50, KX80, CG125, PF50
Boxing
PostPosted: 02:34 - 01 Jun 2014    Post subject: Reply with quote
Why isn't there a kick start?
I wonder if the strange noise is a piston slap. My bikes have always started when I've killed the topend though.
How many miles has the bike done without a topend rebuild? Have you checked the 2T tank to see if it's empty? Also make sure the auto lube works if that's what you're using. Mine failed on a country lane at 60MPH. Will never use one again. Laughing
dangerousdave
PostPosted: 07:36 - 01 Jun 2014    Post subject: Reply with quote
Compression has gone, you will have either broken rings, or a hole in the piston. Either way, sharp edges scraping up and down the cylinder wall is going destroy your engine,
Cylinder off, check it all out, replace damaged parts
Don't ride it until done else you'll just kill it!!!
The last post was made 11 years, 215 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.22 - MySQL Queries: 14 - Page Size: 39.19 Kb
