Why did I drop my bike?
Cuchulain
PostPosted: 18:37 - 30 May 2014    Post subject: Why did I drop my bike? Reply with quote
This morning on my usual route to work on my Xj6n I'm pulling up to a junction where visability is poor. I'm rolling up to the line, can't see anything so just start to pull away when a cyclist comes suddenly into view on the right. He's carrying some speed as it's down hill so I quickly brake and before you know it I've toppled over.
I know it's not a particularily uncommon thing for newer riders to do but I can't really pinpoint what i did wrong and I was hoping some experienced folk might be able to shed some light on why this happens and how to avoid it.
CBT 15/6/2011 Theory Test Passed 6/2/2012 Module 1 Passed 11/6/2012
Module 2 Passed!!! 19/6/2012
SQL
PostPosted: 19:04 - 30 May 2014    Post subject: Reply with quote
Brake sharp and lose balance
Karlbristol
PostPosted: 19:08 - 30 May 2014    Post subject: Reply with quote
This ^
If you grab at the front brake at low speeds you will inevitably loose balance. If your travelling at slow speeds it's best practise to only use your rear brake or use both but with a heavier preference on the rear. This way your bake will stay more stable and won't nosedive causing you to shift your weight/become unbalanced.
Is there much damage?
Other than bruised pride are you ok?
Currently riding: GSX650
Currently own but rarely drive: Boring family '12 plate VRS Octavia estate
Cuchulain
PostPosted: 19:49 - 30 May 2014    Post subject: Reply with quote
Karlbristol wrote:
This ^
Ah okay, more rear break makes sense. I think I need to calibrate mine as it's very soft at the moment so I hardly ever use it.
No real damage thankfully. The hand guard took the brunt of it. It's an '09 model and has been used and abused in all weathers so it's not in showroom condition anyway.
I'm fine thanks.
Nexus Icon
PostPosted: 19:53 - 30 May 2014    Post subject: Reply with quote
Did you forget to put a foot down when you came to a stop?
It sounds daft but my now wife did that on her cbt a few years ago. I laughed. A lot. I felt a bit mean but I couldn't help it.
Greetings from Shitsville!
barrkel
PostPosted: 01:06 - 31 May 2014    Post subject: Reply with quote
There's nothing wrong with using the front fairly sharply at low speed - as long as you're dead straight. Something you'll learn is to make sure you're straight before doing significant braking. I seldom use the rear on my VFR unless it's wet and I want to eliminate transmission slop when turning into junctions on slippy roads.
What happens when you're leaned over is that you're steering a little bit into the turn, and that's part of what's keeping you upright. The front wheel has, via forward motion, a torque effect on the roll angle of the bike - this is why countersteering works.
When you brake, you're trying to stop the front wheel turning. But the road wants it to keep on moving. This has the effect of pushing back in exactly the same direction that the steering is pointed in. If you're dead straight, then everything is fine, all the force is trying to slow you down (and potentially put you into a stoppie).
But if your steering is at an angle (like in a turn), this force has a sideways component applied at the bottom of the bike. It's like pulling a rug out from underneath you.
The solution is to steer deeper into the turn (so you countersteer upright) and then apply the brakes with straight steering. But this is something you'll learn instinctively over time.
There's also a planning aspect. When you're on a bike with a high centre of gravity, you can't afford to make as many speculative moves that get aborted upon better observation. You need to make observations sooner, before you decide to move.
The situation is different on a scooter, which has a very low centre of gravity - they're much easier to hold up if braking while turning, which is part of the reason they're better for cities, where timely, total observation is not always possible when making progress.
PostPosted: 09:47 - 31 May 2014    Post subject: Reply with quote
Root problem was giving way to a pedalist.
Ribenapigeon
PostPosted: 20:40 - 31 May 2014    Post subject: Reply with quote
Damn right.
trevor saxe-coburg-gotha
PostPosted: 20:59 - 31 May 2014    Post subject: Re: Why did I drop my bike? Reply with quote
None of my bikes have twin rotors, and even though I've ridden a cbf600 a good few times, I was still taken aback by how instantly grabby the twin disc brakes were on this ER6 I rode. And this was just the careful "sensitive squeeze while we're on the car park just to get a feel of this thing" type of braking. If I'd been out on the road and something had've happened I would either have done the mother of all endos or else lost the front before I knew it.
Needless to say, when I *did* get off the car park and on my way I was ultra careful - and I understood why people use just two fingers.
tl;dr - grab the front brake = binning
BakesBeans
PostPosted: 17:48 - 01 Jun 2014    Post subject: Reply with quote
At those junctions where there is a blind spot, or difficult to see, it's best to always come to a complete stop anyway.
Current: Kawasaki ZX636
Previous Bike: Honda CBR600F ABS, Yamaha XJ6 F Diversion ABS, Honda VFR400 NC30
The last post was made 12 years, 139 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.98 - MySQL Queries: 14 - Page Size: 71.7 Kb
