| reddeviljp |
 reddeviljp Trackday Trickster
| bugeye_bob |
 bugeye_bob World Chat Champion
| Itchy |
 Itchy Super Spammer
 Posted: 15:55 - 02 Jun 2014 Post subject: |
Fork seals are coming to the end of their lives.
You have two options:
#1 Change them and the bushes which will cost £10 per side in parts and £80 in labour from a mechanic* changing them involves putting the bike on a stand (or hanging it from roof beams), removing brake callipers + wheel. Undoing bolts on the top and bottom, then undoing the triple clamps at the top and bottom. Then pulling them out, then slide hammering, if it works it comes out if it doesn't it means heating them or sticking them in a vice and pulling them apart getting fork oil all over yourself taking the old bushes and seals off, gentling putting new ones on, filling with oil then reassembling them.
(*something I believe is worth it as I nearly impaled myself separating the stanchions from the fork legs)
#2 Ignore it, like I did, at which the fork seals burst while I was riding a fast twisty road, meaning no front brake. I then rode around with a bag wrapped around the top of the fork leg to keep the oil off my brake disc, eventually went to point #1 (do not forget to change the bushes too). ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
| stinkwheel |
 Posted: 16:05 - 02 Jun 2014 Post subject: |
Or there could just be muck/dust stuck under the fork seal. In which case you can get a bit of thin plastic (margarine tub lid is good) and shove it down between the seal and the fork leg to dislodge the dust and let it seal again.
Or you can buy a bit of thin plastic called a sealmate and do the same thing. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Rogerborg |
 Rogerborg nimbA
 Posted: 16:17 - 02 Jun 2014 Post subject: |
| stinkwheel wrote: | shove it down between the seal and the fork leg to dislodge the dust and let it seal again. |
This has sorted three different seals for me, for multiple thousands of miles of continued use.
No, it won't always work, but it takes 5 minutes to try, especially if your fork leg isn't pitted. If it is, that's a whole different issue and you should sort it before replacing a seal that'll just get torn up again. ____________________ Biking is 1/20th as dangerous as horse riding.
| reddeviljp |
| delsol |
 delsol World Chat Champion
| Slacker24seve... |
 Slacker24seve... World Chat Champion
 Posted: 19:18 - 02 Jun 2014 Post subject: |
The parts (seals and oil) cost buttons. If you can find a suitable seal driver (PVC waste pipe, massive socket etc) its not that hard. ____________________ Triumph Daytona 675 track bike + girlfriend's Honda Hornet 600
Banger rallies are ace |
| Rogerborg |
 Rogerborg nimbA
Might as well have a go. Lift the dust seal up, run a strip of plastic around between the leg and the oil seal, wipe the leg down, bounce the suspension and see if there's still oil getting past. It's nearly as quick to do as to type. ____________________ Biking is 1/20th as dangerous as horse riding.
| Islander |
 Islander World Chat Champion
| TUG |
 TUG World Chat Champion
 Posted: 03:27 - 03 Jun 2014 Post subject: |
Just change the seal, cleaning the seal with a seal mate or other has never worked for me and the if a little bit of dirt has caused this much oil loss you're going to need oil anyway so what's the point? Just change the seal on that side or both it's a good day of a job if you're a noob or run into issues or a couple of hours if your hand with spanners.
There are plenty of tutorials online but if your going to DIY it then buy one of these:
https://www.motorcycle-superstore.co.uk/4844/i/motion-pro-fork-oil-level-tool
The reason: Although you might know the correct ml of oil to put in, there might be a few ml still in the leg and not putting to correct air gap in a leg will cause handling anomalies.
I must say that replacing your fork oil in both legs at once is the best course of action, it's cheap and will make your bike handle a lot better if the current oil is piss like. ____________________ Haz ER-5, innit! |
| Rogerborg |
 Rogerborg nimbA
| TUG |
| stinkwheel |
| Islander |
 Posted: 08:36 - 03 Jun 2014 Post subject: |
And for me on several bikes.  |
| reddeviljp |
 Posted: 10:46 - 03 Jun 2014 Post subject: |
Thanks for all your helpful answers, folks.
When it gets to a nice, warm day I'll use the film down the seal trick that I've watched being done but if that doesn't work then I'll book it in at the bike centre and prepare for a few hours work changing everything.  ____________________ Bike: 1993 CB400 SuperFour - 1999 Yamaha FZS600 - DAS passed 7/11/13 - Working my way towards a Yamaha FZ1. |
| TUG |
| Vincent |
 Vincent Banned
 Posted: 20:13 - 03 Jun 2014 Post subject: |
How many people replace the dust seals when doing the oil seals? If dirt's getting behind the oil seal from above, I'm guessing the dust seal is past its best?
Other reasons apart from worn seal for leaking:
Worn bushes. These are normally two teflon coated collars that fit on the outside of the lower part of the stantion. One near the bottom, and one just under the seal. They provide a "snug" fit for the stantion to slide inside the fork leg and wear over time. Replacement requires splitting the forks which can be a bit awkward.
Too much oil or air. On air assisted forks, they usually have a small amount of pressure. Some folk pump them up like a tyre  ____________________ Space Is Deep |
| Jim Mc |
 Jim Mc Nearly there...
| davebike |
 davebike World Chat Champion
 Posted: 07:42 - 04 Jun 2014 Post subject: |
Only real cure for pitted forks is new stanchions or your ones re-cromed not cheap ____________________ Dave
NC750Xdct + others at work !
davebike1@gmail.com |
| Islander |
The last post was made 11 years, 235 days ago. Instead of replying here, would creating a new thread be more useful? |
