vfr 400 nc30 no spark.
steveh
PostPosted: 14:33 - 08 Jun 2014    Post subject: vfr 400 nc30 no spark. Reply with quote
Ive got my mrs's vfr taking up room on my bench due to a very strange electrical fault, and cannot for the life of me find out why!
Basically she went to Tesco, parked up, came out, and the bike wouldn't fire, later found out to have no spark.
Its getting 12v to the CDI, the coils, and all earths are good, the CDI is working as i tested it on a friends bike just before he sold it.
there is good continuity from pulse coils>CDI and from CDI>coils.
Coil packs, on both sides of the windings test okay.
The pulse coils (2 off) are supposed to read between 450-550ohms each. mine were measuring 413/418ohms, so i suspected those, a friend of mine had a set off a spare engine that "he was told was running"
Across either side, they tested 421/420ohms, not much better than mine, but i tried them anyway, no spark.
Im starting to think that ive got two bad pulse coils, but cant see this being very likely!
im temped to try find another wiring harness, and or another set of pulse coils, the bike is totally standard, and has had no wiring modifications atall, i cannot see why it wont run, ive bypassed the kill switch, the ignition barrel, and the clutch switch.
(there is no side stand switch)
Really need this bike sorting, as we have a rally at the end of the month.
if anyone can give me any ideas to try, i will be very greatfull, or if anyone has a loom or pulse coils that would be a great help!
many thanks, Steve.
Carvel
PostPosted: 15:03 - 08 Jun 2014    Post subject: Reply with quote
Well the coils are separate front and rear so I cant imagine they would fail out of the blue at the same time.
You have missed the golden rule with electrical issues which is to check the fuses.
steveh
PostPosted: 15:39 - 08 Jun 2014    Post subject: Reply with quote
sorry forgot to mention ive checked those, and powers to and from, its not the fuses, and i dont mean the HT coils, i mean the pulse coils/pickups in the generator casing.
If i hadnt tried the CDI on another bike id be suspecting that, christ knows what it is.. the likelihood of it being two pairs of pulse coils, is fairly low i would of thought... tempted to rip the wiring harness off the bike and start digging into it..
Carvel
PostPosted: 15:52 - 08 Jun 2014    Post subject: Reply with quote
Yeah sorry I misread what you said. In that case i'd be ripping into the loom and checking for a short somewhere.
nowhere.elysium
The Pork Lord
PostPosted: 16:21 - 08 Jun 2014    Post subject: Reply with quote
Check all the earth points. Don't forget that the starter solenoid has its own fuse with it, too.
steveh
PostPosted: 17:11 - 08 Jun 2014    Post subject: Reply with quote
fuses all checked, plus i wouldnt get dash lights if that fuse had blown, tried putting extra earths in to frame/engine, still no joy.
Started digging into the harness in the usual wear points, internal wires are mint, no sign of wear, or water ingress.
open to any suggestions, as im fecking stumped.
moonzoomer
PostPosted: 17:59 - 08 Jun 2014    Post subject: Reply with quote
Try replacing the battery with a known good one, also check kill switch.
steveh
PostPosted: 18:22 - 08 Jun 2014    Post subject: Reply with quote
kill switch has been checked for continuity, and also bypassed, battery is A1 condition, and i have a mains transformer on the battery designed for motorcycles.
ive put it away for today, pulling my hair out.
nowhere.elysium
The Pork Lord
PostPosted: 18:36 - 08 Jun 2014    Post subject: Reply with quote
Does it get as far as actually turning over? If not, then I'd be looking at tearing into the switchgear.
moonzoomer
PostPosted: 18:42 - 08 Jun 2014    Post subject: Reply with quote
https://i1142.photobucket.com/albums/n604/mawlarky/nc30_zps4efed27b.jpg
steveh
PostPosted: 19:27 - 08 Jun 2014    Post subject: Reply with quote
motor spins fine, all lights and everything works (apart from the spark)
Im really heading towards these pick-ups, but the chances of 4 independently wired pickups all dying seems abit far fetched?!
wish i could find a set of known good ones!
steve.
nowhere.elysium
The Pork Lord
PostPosted: 19:29 - 08 Jun 2014    Post subject: Reply with quote
Corrosion in the 5-pin white plug? I was bitten by that exact same problem today, as it goes; I couldn't start my GS in the middle of the High Beach car park - after checking all the earth points, I ended up pulling apart the headlamp bowl, and lo and behold - shitloads of crufty goodness in the plug that attaches the switchgear to the rest of the loom.
moonzoomer
PostPosted: 19:39 - 08 Jun 2014    Post subject: Reply with quote
steve.
Brother has a few of these bikes, poor starting or no sparks was always down to a poor/weak battery, these bikes are very sensitive to battery condition regardless of how good the battery seems to be yet I have used a couple of the brothers old NC30 batteries on other bikes with no problems.
steveh
PostPosted: 19:41 - 08 Jun 2014    Post subject: Reply with quote
Im really praying for green death in a connector, but there isnt any signs of decay! i tore into the harness around the headstock to check the condition of it, and it looks like what you'd expect from a 10 plate bike... its kept in decent nick, and hasnt had any bodgery at all, this is whats annoying... i think im going to phone electrex.uk to have them pulse coils tested, as my mrs needs it for two weeks time as were going away on the bikes.
There is a gap of 10 years, 49 days between these two posts...
Leon.davibe
PostPosted: 10:14 - 25 Jul 2024    Post subject: Reply with quote
Sorry for the necro
Leaving it here cause i had a problem like this
Since the nc30 uses a wasted spark it fires at 2 spark plugs
i had a randomly misbehaving plug (did not know it at the time)
Bike would have no spark, by chance it was left rear plug which was the the one i used to check for spark , it would not start carbs known good
So knew it was spark, the moment i would observe the spark via screwdriver it would be spark and the bike would start
I could nevwr sus out why it would stop sparking and once o checked for spark it would start
Until that plug failed totally, replaced it have not had the problem since
Electricity takes the easiest route so both rear cylinders would be dead because the spark flowed via the faulty plug to ground
Hence why cdi runs fine on different bike
The last post was made 1 year, 197 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 3.12 - MySQL Queries: 13 - Page Size: 88.97 Kb
