Claud 14.7 to 1 |
Claud 14.7 to 1 World Chat Champion
Posted: 13:42 - 19 Jul 2004 Post subject: Lumpy idle + electics = GRRRRR |
When i put lights on, indicators, and brake light. Idle speed goes lumpy, and eventually engine will cut out. i have to open the throttle slightly., to keep it alive
When i turn off the electrics it is better. It seems to be worse once the engine it hot, ie ive been riding for a while.
i replace the reg/rec with a brand new Heavy duty unit, about 2 months ago.
I think the carbs need balancing anyway, but is it right that the electrics should make the problem even worse??? revs perfectly, arbeit a sloppy pick up sometimes, when the revs die down a bit. idle sucks.
cbr400 gullarm. Thank you!
ps anyone got any vacum gauges. Im in Potter Bar, Hertforshire... |
Guest |
Guest Brolly Dolly
Claud 14.7 to 1 |
Guest |
Guest Brolly Dolly
Claud 14.7 to 1 |
Posted: 09:56 - 20 Jul 2004 Post subject: |
Yer the carbs may need a balance, but when the elctrics go on, the problem is noticeably different... And it cuts ont eventually . The problem is worse when there is a high ammount of electrics on.
Battery charges fine, and starts with plenty fo juice.
Thanks for replys. More help appreciated. |
Guest |
Guest Brolly Dolly
Claud 14.7 to 1 |
Posted: 17:49 - 20 Jul 2004 Post subject: |
Quote: | The more electrical load you ask the generator for, the more it'll pull the revs down on the engine as it tries to supply it. Couple that with carbs that are out of synch, even by a little bit, and you're asking for the engine to cut out.
Clean the flaot bowls out, check the float height and then balance the carbs (I'm assuming your valve clearances are ok?). |
I think that with the carbs being a bit out, and the electrics being on, you may be right with your first point.
Bowls are perfect, i had one off and it was perfect, also they were done by a garage, before i got the bike a few 000 miles ago.
Floats are adjusted automatically . Valve clearances sound ok, so i dont suspect them.
I recon the carbs being balances is the cheapest/best method to use to illiminate the problem. Thank you.
If anyones has more to add, fee free. |
The last post was made 19 years, 287 days ago. Instead of replying here, would creating a new thread be more useful? |
