| lingeringstin... |
 lingeringstin... Spanner Monkey
 Posted: 11:35 - 06 Jun 2014 Post subject: Surely not... |
Here’s some interesting carburetor waffle, not that anybody cares anymore. But that’s always the way- old technologies reach their working zenith at pretty much exactly the same time they become obsolete due to a NEW and IMPROVED method of doing the same thing.
For instance the recording and playback quality of cassette tape finally became CD quality, what with all that Dolby and other science thrown in, at pretty much the same time as CD’s became the new thing. I remember how after all the arseache of tape hiss and background noise I was finally, eventually, truly amazed at what could be done with an inexpensive cassette deck.
I skipped CD recording and went straight to digital multi tracking on a shitty laptop which was WAY easier to do. But it didn’t nullify the point that tape had, in it’s final days, finally achieved perfection for recording quality.
But I digress.
I’ve been using a petrol/diesel mix for fuel for some time now and over the years have had the opportunity to extensively play with mixture ratios and carb tweaks, and I’ve noticed something. There seems to be a certain Perfect Ratio where the mix has the best of both worlds, and just a very tiny shift one way or the other in the ratio makes a noticeable difference to the way my particular engine performs.
Bear in mind that my primitive two stroke MZ engine has pretty much ONE moving part and very little room for fancy performance tweaking, and my bastardized SU carb is basically nothing but an open air tube with an adjustable fuel leak where the mixture of fuel to air is adjusted by a flat bottom slide and a certain taper of needle. No other helper jets or airways of any kind. Not even an idle circuit.
I don’t have any idea what my compression is but I’ve experimented with it over the years and have tweaked it to a point that seems to work best, which as far as I can tell is a bit higher than it would be normally but not extreme at all.
And as for my homemade expansion chambers, well that’s gone all round the houses over the years to come back to basically bog standard MZ dimensions for best overall road use so that’s nothing much to consider.
So after years of riding and tweaking and thinking and stinking I have now come to the conclusion that on MY bike, with THAT compression and THAT carb set up THAT way, the perfect petrol to diesel ratio seems to be exactly 4.77 liters of petrol (bog standard unleaded) to one liter of diesel.
The strange thing is that if I alter that ration even slightly, such as only putting in 4.70 petrol or being a bit lax with my diesel measurements, I can actually notice the difference. Too much petrol in the mix thins the fuel which leads strangely to more smoke, less “lugging power" (the ability to stay in a gear for a wider range of speeds) and less mileage, and too much diesel leads to more smoke and the carb running lean which just does what a carb does that’s running too lean.
In the event of misjudging my fuel mixture I do have the ability to reach down and tweak my SU jet tube nut on the fly, which raises or lowers the jet tube in relation to the needle. That’s a sort of “get by” measure that means I’m in no danger of overheating the engine or of being stranded or something, but it’s not ideal. The best thing is to be very careful to hit exactly the 4.77/1 ratio (red diesel slightly different).
This gives the best performance on my bike, and the fuel economy drops considerably if I muck up this perfect ratio. There really does seem to be a perfect spot where if the mix is JUST right it performs way better than if it’s even slightly out. Perhaps there’s some rocket science as to why but all I know is THAT mix works for ME at THIS point in time under THESE conditions.
That may or may not be the case on any other two stroke contraption, but then again it MIGHT be. This could give a performance advantage for such applications where any size of two stroke engine in employed. Pause for thought and consider lawnmower racing, radio controlled aircraft, vintage bike racing, competition chainsaws, etc.
Now, I know the age of carbs is long past and nobody cares anymore. But I just thought you might want to keep that little bit of hard earned, long researched Secret Fuel Ratio alchemy in mind the next time you’re discussing random engine minutia with a dinosaur in a flat hat smoking a pipe round a camp stove.
Of course I’m sure the whole idea of liquid petroleum fuel will soon be old hat, but I for one am glad to have had the opportunity to dabble in Satan’s Piddle. Of course I’m certain that given half a chance treehuggers from the future would probably come back in a time machine to muck it all up, the bastards.
(ominous music plays, voiceover)
"On the evening of September 29, 1913, Rudolf Diesel boarded the post office steamer Dresden in Antwerp on his way to a meeting of the Consolidated Diesel Manufacturing company in London. He took dinner on board the ship and then retired to his cabin at about 10 p.m., leaving word to be called the next morning at 6:15 a.m.
In the morning his cabin was empty and his bed had not been slept in, although his nightshirt was neatly laid out and his watch had been left where it could be seen from the bed. His hat and overcoat were discovered neatly folded beneath the afterdeck railing.
Ten days later, the crew of the Dutch boat Coertsen came upon a corpse floating in the North Sea near Norway. The body was in such an advanced state of decomposition that it was unrecognizable, and they did not bring it aboard. Instead, the crew retrieved personal items (pill case, wallet, I.D. card, pocket knife, eyeglass case) from the clothing of the dead man, and returned the body to the sea.
On October 13, these items were identified by Rudolf's son, Eugen Diesel, as belonging to his father."
I’m saying nothing. |
| Conzar |
 Conzar World Chat Champion
| nowhere.elysium |
 nowhere.elysium The Pork Lord
| goto10 |
 goto10 World Chat Champion
| Rogerborg |
 Rogerborg nimbA
 Posted: 12:31 - 06 Jun 2014 Post subject: |
Sorry, zoned out, was he on about the Superdream being the bestest bike ever? ____________________ Biking is 1/20th as dangerous as horse riding.
| Shinigami |
 Shinigami World Chat Champion
| stinkwheel |
 Posted: 12:50 - 06 Jun 2014 Post subject: |
Good to see you and stinkybob are still alive and well.
I was thinking about both of you at the diesel bike rally last weekend. I'm sure you'd have had a great time arguing with the diesel lot about how your bike can't possibly work.
Are you still running it with urine injection? Did you find thge previous nights alcohol intake affected the stoichiometry? ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Nope. |
 Nope. World Chat Champion
| The Shaggy D.A. |
 The Shaggy D.A. Super Spammer
| Rogerborg |
 Rogerborg nimbA
 Posted: 14:12 - 06 Jun 2014 Post subject: |
I dunno, he does LIKES his CAPS. But didn't mention the Benly once, so I guess that's conclusive. ____________________ Biking is 1/20th as dangerous as horse riding.
| stinkwheel |
| nowhere.elysium |
| stevo as b4 |
| Jenks |
 Jenks World Chat Champion
| Rogerborg |
 Rogerborg nimbA
 Posted: 12:37 - 07 Jun 2014 Post subject: |
Is he taste-testing the stuff first? ____________________ Biking is 1/20th as dangerous as horse riding.
| Timmeh |
 Timmeh World Chat Champion
| merquis00 |
 merquis00 Nova Slayer
| lingeringstin... |
| G |
 G The Voice of Reason
 Posted: 23:29 - 15 Jun 2014 Post subject: |
From what I can, it's concluded that when people move on to a new technology, the old technology which is no longer being worked upon isn't improved any more, is at it's "peak".
Not sure that actually needed pointing out?  |
| Shaft |
 Shaft World Chat Champion
| Rogerborg |
 Rogerborg nimbA
 Posted: 08:44 - 16 Jun 2014 Post subject: |
Electric vehicles, for one. ____________________ Biking is 1/20th as dangerous as horse riding.
| MarJay |
 MarJay But it's British!
| Pete. |
 Pete. Super Spammer
 Posted: 11:51 - 16 Jun 2014 Post subject: |
Sorry, but anyone who uses 'but I digress' as a standalone paragraph sets alarm bells ringing right from the off.
Apart from that, who would be surprised that changing the mix ratio by a measly 17% would have an effect on how it runs? And as for red diesel running different to white, well - LOL. ____________________ a.k.a 'Geri'
| stinkwheel |
| lingeringstin... |
The last post was made 12 years, 25 days ago. Instead of replying here, would creating a new thread be more useful? |
