 Mac999 Derestricted Danger
 Posted: 22:11 - 20 Jun 2014 Post subject: No lights working on dt 125 |
Hi guys its driving me mad:( just had a bottom end refurb ) so I've put the engine back into the frame.all good starts up fine
But then noticed that I've got no headlights or back light or high beam light on the clocks and there's no instrument back light either.
The indicators work
The neutral lights one
Oil light as well
Brake light works
Ive disconnected every connection box
I've checked the fuse
I've checked all the wording behind the headlight as well
It was all working fine until I removed the engine
Could it be the stator?
I've run a headlight bulb of the battery and it lights up so thought it wouldn't be the stator  |
 Timmeh World Chat Champion
 Posted: 22:14 - 20 Jun 2014 Post subject: |
Indicators and clock warning lights run off the battery
the rest is unreg AC straight off the engine.
Check your stator connections.
 ____________________ GSXR400 x2 | '94 RVF400 | '93 TZR125 4DL (again)
20:48:18 Temeluchus: comp you hunk of smouldering homos3x you |
