A1 licence upgrade for an older rider...
Big125
PostPosted: 11:59 - 20 Jun 2014    Post subject: A1 licence upgrade for an older rider... Reply with quote
I contacted the DVSA (When did that change?) a couple of days ago asking about what I need to do to change my A1 to an A licence (took my tests last year after Jan on my 125). I was after info on this day course to upgrade.
Here is the response bear in mind I'm 35.
"Thank you for your email dated 18 June.
I can confirm that if you wish to upgrade from an A1 licence to an A licence, without progressive access, you will be required to sit a theory test, followed by your module one and then module two. Your module one certificate will be valid for the duration of your theory test.
However, if you wish to upgrade via progressive access, you will have to wait until you have held your A1 for two years and then will be able to take an A2 module one and module two. You would then be required to wait a further two years before upgrading to a category A. If you upgrade via progressive access, your module one certificate will be valid for two years."
WTF? I have to wait another 18 months before I can go to an A2 then another 2 years to go to an A?! but I could retake my theory and go for an A next week??
This makes absolutely no bloody sense!
wr6133
PostPosted: 12:15 - 20 Jun 2014    Post subject: Reply with quote
Aged 35 you can just do DAS for A. Either a course or somehow get a qualifying bike legally to the Mod1 and 2 and use it. Not sure if you need theory again I'm fairly certain you don't though.
They have just copy pasted you some standard reply.
Teflon-Mike
tl;dr
PostPosted: 12:29 - 20 Jun 2014    Post subject: Reply with quote
That's my understanding to; BUT look here:-
https://www.gov.uk/government/uploads/system/uploads/attachment_data/file/278344/dsa-routes-to-your-motorcycle-licence.pdf
According to thier flow charts, via 'progressive access' previouse licences exempt Mod 1's not Theories, which seems daft; but still; so according to their flow chart, all he need do, if he has still got Theory pass cert and its still in date, is book and test an A3 Mod 2 and pass it.... some-how though, I suspect the 'system' would probably baulk if he tried.
Best advice I can offer is go book a DAS course. Let them sort it with the DVSA!
Hokum
PostPosted: 12:50 - 20 Jun 2014    Post subject: Reply with quote
Christ that all looks like a right mess.
"Nah mate you'll have to give us £30 to take your A, or we'll make you wait for 2 years for no bleedin reason so you can take the same ruddy test on a slightly bigger bike and then wait another 2 years for another bigger bike..."
Should be
Take tests if under 19/20 you get an A1 then at 20 you get an A2 automatically then at 24 you get an A.
It's the same bloody test so it shouldn't matter which bike you take it on.
What happened to the CBT+ type thing they were going to do for people wanting to upgrade?
I'm guessing they realised people could be squeezed for more money this way...
I also think that the A1 should cover bikes up to 250cc class which are still learner bikes in some countries! Also it would promote commuting on the cheap.
Sane: To know when you are doing something crazy.
PostPosted: 13:24 - 20 Jun 2014    Post subject: Re: A1 licence upgrade for an older rider... Reply with quote
That is the wording of the various legislation, a point which I've made before.
The thing is, I'm pretty sure that people have been rocking up for A2 / A tests with their original theory pass in hand (from within 2 years) and everything is fine.
The thought that passing A1 somehow invalidates your current theory pass just...
Welcome to Whitehall.
Just go straight for A, sod doing theory again.
Hokum
PostPosted: 13:52 - 20 Jun 2014    Post subject: Reply with quote
Even schools aren't very clear..
From https://www.1stopinstruction.com/acceleratedaccesseastlondon.html
"If you have held an A1 Motorcycle Licence for 2 years, then you can only upgrade to DAS if you satisfy the minimum age requirement for which is 24."
Which suggests you can go from A1 to A, but then...
"However, there is 1 scenario where you may have to re-take your theory. If you reach the minimum age requirement for the next category before you have held your existing licence for 2 years, then you can obviously take the test on that category as you meet all the requirements, but because you haven't held the lower category licence for 2 years yet, you will need to make sure that your motorcycle theory is still valid. If your motorcycle theory has expired, then you will either have to re-take your theory test or wait until you have held your existing motorbike licence for 2 years before upgrading via the progressive access route."
So it's as clear as mud.
Northern Monkey
PostPosted: 14:16 - 20 Jun 2014    Post subject: Re: A1 licence upgrade for an older rider... Reply with quote
I passed my A1 about a month before my A. Even DSA Derek didn't know if he was interested in my theory test result or not.
He just wrote the number in the box because he couldnt be bothered to check it out
PostPosted: 17:10 - 21 Jun 2014    Post subject: Reply with quote
Its all good lads. I've had a chat with the boss about this very thing. He can go straight on to DAS as long as he is over 24. Any school that tells you otherwise is trying to get more money out of you. The DAS rules still apply even though he has a full smaller capacity licence.
PostPosted: 18:49 - 21 Jun 2014    Post subject: Reply with quote
Or are repeating what the DVSA are saying, which is technically correct.
Yes, but the question is whether he needs to do another theory, as you would do if you'd gone straight to DAS.
Basic bloody common sense says no. DVSA corporate say yes, because apparently whichever muppet drew up the legislation didn't think of this. DVSA Derek doesn't seem to care, fortunately.
CyrilSwan
PostPosted: 22:42 - 21 Jun 2014    Post subject: Reply with quote
I actually emailed the dsa about this. I'm 31 and have an A1 license. They said that I do not need to re sit the theory test. Just need to do the mods.
Current: Honda 2015 MSX125.
Previous: Honda 2012 CBF125.
PostPosted: 01:53 - 22 Jun 2014    Post subject: Reply with quote
I'll ask tomorrow. I'm in the yard so will get it confirmed.
Big125
PostPosted: 11:54 - 23 Jun 2014    Post subject: Reply with quote
Hi all, Well my theory expired in May, so I may/may not be buggered if the DVSA say I do/don't need to retake a theory.
I agree with MC though, the theory test and the practical tests are the same test no matter the bike.
I mean if the A licence had motorway driving or something I could imagine why there would be a difference but there isn't.
I know people don't want 17 year olds on 1 litre rocket ships but they should just age limit it if need be.
Hokum
PostPosted: 12:28 - 23 Jun 2014    Post subject: Reply with quote
The once proposed "CBT+" upgrade from A1 to higher capacities do kind of make sense.
You have a whole day to learn the differences from an A1 to a full A bike, harsher engine breaking, and the possibly massive weight differences.
Actually showing you how to pick up a heavy bike would be a help. 125's are light and you can do it wrong and not hurt yourself but the same on a 600+ could throw your back out.
Other handling things could be covered, like rev matching, and advanced cornering techniques could be touched on.
Does anything on the 3rd Directive actually say you can't take the test on a 125 and get a full A?
Hetzer
PostPosted: 13:07 - 23 Jun 2014    Post subject: Reply with quote
It's harder to learn to ride a horse. Do they need to take various tests before going out on the queen's highway? Tax and insurance?
The civilised world is run by fucktards with crooked agendas.
"Hi, my name's Tim. I'm 17 but have passed my car test and daddy can pay for the insurance...can I has 700bhp Ferrari?"
"Yes".
Fucktards.
PostPosted: 13:10 - 23 Jun 2014    Post subject: Reply with quote
Yes. That's its explicit intent, that you have to sit the A2 or A tests on bigger bikes. There was an explanatory memo that went out that was practically frothing that people were getting full licenses on a 125.
However, the implicit intent seems to be a training route upgrade, that "CBT+". 7 hours, assessment, off you go.
However, there was also the option of test, and Whitehall (under zanuLabor) of course went for that one, then gold plated to be a full re-test of both modules.
Utterly bizarrely, our reason for full re-tests vs a 7 hour training course (that could be farmed out to ATBs like the regular CBT) was, get this, "cost". The mind boggles as to their "thought" processes.
dydey90
PostPosted: 13:54 - 23 Jun 2014    Post subject: Re: A1 licence upgrade for an older rider... Reply with quote
When I turn 24 I'll have had my A2 for about 13 months. Does this mean that I should[ need a theory test certificate when I upgrade?
Is taking my existing certificate all good by the book or is it a bit wobbly?
map
Mr Calendar
PostPosted: 14:16 - 23 Jun 2014    Post subject: Re: A1 licence upgrade for an older rider... Reply with quote
I'm looking at the DSA flowchart now as I looked it up for my lad and the A1 or A2 test.
For A2 holders if 24 or over if A2 held for less than 2 years and you have a valid theory test certificate then you need to pass 2 part test on larger motorcycle at least 595cc and at least 40Kw (that'd be 53.6bhp). That'll get you Category A and you can then ride any size of motorcycle.
Just states if you hold a valid theory test certificate. So if inside 2 years self destruction date you should be good to go.
If A2 held for more than 2 years just go straight to pass 2 part test, do not even think about theory test.
Hokum
From A2 to full A I think it's 2 years OR you have to retake the theory if out of date according to the PDF TEF linked.
map
Mr Calendar
PostPosted: 14:22 - 23 Jun 2014    Post subject: Re: A1 licence upgrade for an older rider... Reply with quote
That's what I was looking at in my above post. Just states valid theory test certificate. So if still valid (i.e. theory passed less than 2 years ago) from taking A2 (or whatever before) then it's still valid.
FWIW the pdf from TEF's post - see page 5
Copycat73
PostPosted: 17:33 - 23 Jun 2014    Post subject: Reply with quote
me think..your cynicism has been at the steroids again.... Thinking
caveat emptor
Hetzer
PostPosted: 17:56 - 23 Jun 2014    Post subject: Reply with quote
The power of accurate observation is commonly called cynicism by those who have not got it.
Copycat73
PostPosted: 18:48 - 23 Jun 2014    Post subject: Reply with quote
better to speak the language of the common people than be ignored.
caveat emptor
Hetzer
PostPosted: 20:48 - 23 Jun 2014    Post subject: Reply with quote
Oh, I think I'd rather be ignored. Nothing I say is for the ears of the "common people". They might listen (between episodes of Eastenders) but they'll never hear.
The last post was made 12 years, 119 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.45 - MySQL Queries: 13 - Page Size: 142.34 Kb
