Jumping out of 4th gear
Conzar
PostPosted: 09:24 - 27 Jun 2014    Post subject: Jumping out of 4th gear Reply with quote
Hello guys,
I would like to ask whether it sounds reasonable to you if only the 4 the gear on a 1998 CBR6 gearbox might be worn out.
What happens is you shift to 4th apply the gas and it will either jump immediately back to 3rd or hit a false neutral like the clutch is slipping, self select 3rd and then it will bang it back into 3rd.
I used to get this very occasionally before like i wasn't shifting into 4th hard enough, but now it doesn't want to stay in gear - except on downshifting and engine braking.
Only thing i have changed is the oil
Have i deaded the gearbox? Thinking
Current ride: ZX6R 636 ------- Previous:KTM EXC 450 Supermoto --- ZX6R B1H --Hornet 600--CBR 600--SV650
11:05:35 Rob Fzs: i just wanna own an rd350 valve before they send us to war with durkadurkastan
el_oso
PostPosted: 11:29 - 27 Jun 2014    Post subject: Reply with quote
sounds like worn dogs if it's just that gear. If that is the case then yes. You could take it apart and replace, but it's probably cheaper to buy a new engine facotring in the cost of gaskets/seals and also time to do something like this.
Duke 390
Car: Jeep Wrangler 4.0L
RhynoCZ
PostPosted: 11:35 - 27 Jun 2014    Post subject: Reply with quote
Do you shift gears firmly/strongly enough?
When you just stroke the lever, it'll jump down or into neutral on most bikes and older it is more easy it happens.
Conzar
PostPosted: 11:41 - 27 Jun 2014    Post subject: Reply with quote
I noticed it a few days ago and thought it maybe due to my chain being a bit slack, i then noticed it was just in 4th gear, new chain and sprockets are going on tomorrow.
I see this maybe a opportunity to slap a early Fireblade lump in it Very Happy
The last post was made 11 years, 217 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.25 - MySQL Queries: 14 - Page Size: 39.96 Kb
