Stuck Rear Axle
Saltire
PostPosted: 14:51 - 24 May 2014    Post subject: Stuck Rear Axle Reply with quote
Ive got it to come out about an inch or so, been grasping it with wrenches and tugging at it like fook but it won't budge.
No jobs a simple one with this bike. Laughing Needing some tips/tricks if anyone has any.
doggone
PostPosted: 14:57 - 24 May 2014    Post subject: Reply with quote
It's unusual you can go a little way then it stops.
Absolutely sure nothing else is retaining it?
Needs lube, and tap it back in and out plus twist a few times, then try driving it from the threaded side if 100% sure nothing is holding it.
Lightly supporting the wheel might help.
map
Mr Calendar
Can you not use a drift to help hammer it out?
Metal bar, extension bar or wood dowel slightly less diameter than axle.
Might help having someone support reared wheel.
Or use a ratchet strap around wheel and seat to support it.
Saltire
PostPosted: 15:05 - 24 May 2014    Post subject: Reply with quote
Yeah positive nothing else is holding it. Tappings not enough I had to hammer it pretty hard to get it out as far as it is, I've got something under the wheel to take the weight off and I've been applying WD40 to either side all to no avail.
I like the drift + ratchet strap idea though. I'll give it a whack. Razz (Dad joke intended)
moonzoomer
PostPosted: 20:58 - 24 May 2014    Post subject: Reply with quote
Does the axle rotate when fully home? if so I have used a cordless drill attached to the threaded end of the axle to spin it while spraying with WD40 to remove rust and crud, the axle should be a lot freer after a couple of minutes spinning.
Robby
Dirty Old Man
PostPosted: 23:31 - 24 May 2014    Post subject: Reply with quote
Offer it independence. With any luck it'll fuck right off.
Saltire
PostPosted: 20:41 - 28 Jun 2014    Post subject: Reply with quote
It has been and it wants it, but the frames refusing to let it go without a fight. Wink
The last post was made 11 years, 209 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.64 - MySQL Queries: 17 - Page Size: 57.92 Kb
