| Author |
| gavcarter |
 gavcarter Could Be A Chat Bot
 Posted: 19:12 - 30 Jun 2014 Post subject: Checking Wheels after a Bash |
Okay so you've wheelied wrong, hit something or got a 2nd hand wheel off ebay - either way you want to know if its straight.
All you need for this is a magnetic dial indicator, the correct axle, and either a strong vice or a decent sized sheet of wood....
Take the axle and either drill a hole in a sheet of wood that is a nice tight fit ( so the axle will stand up straight by itself ) or grasp it in a vice, upright. I went for the vice
Slide wheel over the axle, ( needs bearings in! ) and put the indicator base onto the remainder of the axle, with bit of jigging and poking you can get the indicator onto the rim of the wheel, you should take your measurements as close to 90 degrees as possible to avoid inaccuracy.....
https://i1072.photobucket.com/albums/w375/gavcarter12/IMG_20140630_114928_zps47714028.jpg
Zero the dial and draw a line down the tire in marker and slowly turn the wheel and keep an eye on the indicator, it will flick and flutter over corrosion and dirt or bubble paint, so try and get the rim nice an clean. You should go once round looking for the HIGHEST reading, and once round looking for the LOWEST.
The difference is the AXIAL runout.
https://i1072.photobucket.com/albums/w375/gavcarter12/IMG_20140630_114917_zpsa7db6c0c.jpg
With a bit more jigging and poking you can get the dial indicator ( although I couldn't get mine quite at 90 degrees because it hit the spokes) onto the inside of the wheel and repeat the above noting highest and lowest reading.
https://i1072.photobucket.com/albums/w375/gavcarter12/IMG_20140630_115012_zpscb587c48.jpg
the difference here is the RADIAL run-out
Hope this is of help to some, and was cool little mini project for me today, along with the forks whilst waiting in for deliveries  |
| Back to top |
| Teflon-Mike |
 Teflon-Mike tl;dr
| Back to top |
| kramdra |
 kramdra World Chat Champion
 Posted: 23:49 - 30 Jun 2014 Post subject: |
A short post from Tef
Also good for checking brake discs for warp. Ive got a couple of indicators, but no mount
I assume the locations you have measured are not machined surfaces so will have quite a large variation in metal thickness, plus paint (which is very thick)/corrosion etc.. Best place to check is perhaps the tyre bead? I assume that would be machined after casting, although it would also be painted. |
| Back to top |
| gavcarter |
| Back to top |
| gavcarter |
| Back to top |
The last post was made 12 years, 102 days ago. Instead of replying here, would creating a new thread be more useful? |
